Civil Engineering Association Software Software Product Bentley Products Bentley PowerSurvey V8i (SELECTSeries 3) 08.11.09.493
Threads: 1,118
06-20-2013, 05:21 AM
[Image: 96852749237035115667.jpg]
[Image: 57888310181477912873.jpg]
PowerSurvey is a comprehensive survey data management solution. It provides surveying professionals with a complete set of survey-specific tools for both InRoads and GEOPAK. Built on MicroStation PowerDraft, the software directly processes the data from your field survey device and automatically displays the resulting graphics onscreen. You can then manipulate the data using PowerSurvey's editing, reduction, and adjustment tools.
- Data Collector Support
PowerSurvey communicates with all industry-leading data collectors. Connect your data collector directly to a personal computer, laptop, or tablet PC and use PowerSurvey to manage the survey data. PowerSurvey can also upload GEOPAK or InRoads data to the data collector for field stakeout procedures.
- Customizable Feature-Driven Processing
PowerSurvey supports extensive feature databases that detail the representation of each survey shot or feature β€” including symbolization, labeling, DTM control, and more. The feature database is completely user-definable and ensures standardization from the field surveyor to designer. As you process data, the software draws points and features in accordance with the feature table specified. With this powerful capability, you can generate drawings onsite β€”immediately after the survey has been collected β€” for in-field verification.
- Survey Data Adjustments
Editing and adjusting your survey data is an intuitive process when you use PowerSurvey. The software employs industry-standard routines to quickly make geometry adjustments and finalize your data. PowerSurvey offers least squares, compass rule, and transit rule adjustments. You can visually inspect the adjusted data and complete the topographic drawing in both DGN and DWG formats. The data can then be shared with the members of the project team that are using either GEOPAK or InRoads.
- Interactive Coordinate Geometry
Bentley PowerSurvey includes integrated coordinate geometry (COGO) tools. This valuable toolset enables you to perform offset commands, intersections, traverse, and many other geometry commands. Additionally, you can leverage the data generated with other modules of the InRoads and GEOPAK families of products.
[-] The following 9 users Like BennyP's post:9 users Like BennyP's post
  β€’ Dell_Brett, jokerβ„’, ykhackhack, oanm2000, josephwsl, malc, chaplin, Mohammad6299, cenlara
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
03-19-2014, 07:09 AM
Bentley PowerSurvey V8i (SELECTSeries 3) 08.11.09.674
[Image: comments.png]
Not tested.
[-] The following 1 user Likes Mohammad6299's post:1 user Likes Mohammad6299's post
  β€’ Dell_Brett
  Bentley gINT Pro Plus V8i (SELECTSeries 1) 08.30.03.223 cace-01 4 13,517 07-03-2023, 05:23 PM
Last Post: OSHO
  Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.70 RajaK 5 18,239 12-31-2017, 06:07 AM
Last Post: reagan_liu
  Bentley AECOsim Building Designer V8i (SELECTSeries 3) 08.11.09.376 BennyP 1 8,305 05-15-2017, 08:12 AM
Last Post: wisamnn
  Bentley SewerGEMS V8i (SELECTSeries 4) 08.11.04.54 emmi 2 10,223 12-23-2016, 04:29 AM
Last Post: balimela
  Bentley PowerCivil V8i (SELECTSeries 2) 08.11.07.614 BennyP 1 8,140 12-13-2016, 07:15 PM
Last Post: oanm2000
  Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.33 er.shyams 6 23,919 01-15-2016, 08:39 AM
Last Post: RajaK
  Bentley HAMMER V8i (SELECTSeries 4) 08.11.04.50 BennyP 2 8,756 09-01-2015, 01:42 PM
Last Post: er.shyams
