Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8110-1:1997 Structural use of concrete. Code of practice for design and constructi
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Likes: 4,964 in 638 posts
Given Likes: 3501
06-17-2010, 04:41 AM
BS 8110-1:1997 Structural use of concrete. Code of practice for design and construction
Standard Number BS 8110-1:1997
Title Structural use of concrete. Code of practice for design and construction
Status Superseded, Withdrawn
Publication Date 15 March 1997
Withdrawn Date 16 April 2010
Replaced By BS EN 1992-1-1:2004
Replaces BS 8110:Part 1:1985
Amended By AMD13468 (TO BS8110-1 : 1997) AMD9882 AMD 16016 November 2005. AMD 17307 August 2007.
Supersedes Draft 00/108426 DC05/30135242 DC95/105430 DC
Descriptors Concretes, Construction materials, Buildings, Structures, Structural design, Loading, Reinforced concrete, Strength of materials, Framed structures, Beams, Slabs, Structural members, Shear stress, Columns, Walls, Stability, Stairs, Foundations, Reinforcement, Prestressed concrete, Precast concrete, Composite construction, Composition, Durability, Concrete mixes, Curing (concrete), Formwork, Finishes, Movement joints, Grouting
Note: This is the final BS8110 issued inlcuding all four admendments. Would think this is worth for collection even for non british based structural concrete designers. This standard has been around for 25 years and served many nations beyond UK in their developments.
concrete solution advocate
[-] The following 13 users Like concreteok's post:13 users Like concreteok's post
  • Grunf, michaelsoe, vvvv, Dell_Brett, super_engineer, zrilek, sangxd80, Nilupa, tunaungkyaw, kurokuma, batisxuta, cx_oem, warbeast
 peixoto
Portugal
User ID: 6963
Threads: 51
Likes: 968 in 114 posts
Given Likes: 1492
06-17-2010, 07:36 AM
To get the full package, you can get part 2 and 3 of BS8110 here
As you can see, this norm was replaced by BS EN 1992-1-1, but is usefull anyway!
[-] The following 14 users Like peixoto's post:14 users Like peixoto's post
  • Grunf, vvvv, concreteok, Dell_Brett, zrilek, sangxd80, deltalead, batisxuta, cx_oem, simanta, odiclas, spy008, blaze, lednar_ved
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
06-22-2012, 04:44 AM
[-] The following 15 users Like miquan's post:15 users Like miquan's post
  • Jackass, kowheng, Andrew seah, Grunf, 3fan, peixoto, concreteok, zrilek, maad59, cordoba123, seriousboy, malc, knrsa, Wijono, learner20
 miquan
Vietnam
User ID: 631
Threads: 204
Given Likes: 1331
09-22-2012, 10:10 AM
BS 8110-1 1997 With Amd 2007
[-] The following 11 users Like miquan's post:11 users Like miquan's post
  • blaze, zrilek, Jackass, andersen3, Trishu999, lisine, malc, lednar_ved, tang1942, kirankumarklk, Mohammad6299
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
03-18-2014, 12:06 PM (This post was last modified: 03-18-2014, 02:30 PM by Dell_Brett.)
BS 8110-1: 1997: Structural use of concrete - Part 1: Code of practice for design and construction
Size: 2.2 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 1998 | Pages: 172 | ISBN: 0580262081
[Image: 54194342033015897371.jpg]
This part of BS 8110 gives recommendations for the structural use of concrete in buildings and structures, excluding bridges and structural concrete made with high alumina cement. The recommendations for robustness have been prepared on the assumption that all load-bearing elements, e.g. slabs, columns and walls are of concrete. In a structure where concrete elements such as floor slabs are used in conjunction with load-bearing elements of other materials, similar principles are appropriate but, when adequate robustness is provided by other means, the ties recommended by this code may not be required.
[Image: comments.png]
All watermarks are removed.
MODERATOR NOTE:
Refer to post below for PART 2:
Refer to post below for PART 3:
[-] The following 5 users Like Mohammad6299's post:5 users Like Mohammad6299's post
  • lisine, Dell_Brett, vardan, arshiakh, zrilek
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
03-18-2014, 06:41 PM
Size: 1.1 MB | Format: PDF | Quality: Unspecified
[-] The following 1 user Likes arshiakh's post:1 user Likes arshiakh's post
  • Dell_Brett
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Given Likes: 3501
03-19-2014, 01:14 AM (This post was last modified: 03-19-2014, 01:15 AM by concreteok.)
A summary to this thread up to date (hope mod(s) can do some editing here). thanks in advance.
#2 dead link
#3 active link. full 3 parts updated with latest AMD. part 1 scanned file.
#4 active link. part 1 updated with latest AMD, preprint file.
#5 & 6 part 1 with only AMD up to year 2002.
special thanks to miquan for the great effort to update this thread.
[-] The following 1 user Likes concreteok's post:1 user Likes concreteok's post
  • Mohammad6299
 Mohammad6299
User ID: 42302
Threads: 261
Given Likes: 4212
03-19-2014, 05:13 AM (This post was last modified: 03-19-2014, 05:17 AM by Mohammad6299.)
BS 8110-1 1997: Structural use of concrete - Part 1: Code of practice for design and construction
(Incorporating Amendments Nos. 1, 2, 3 and 4)
Size: 2.17 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2007 | pages: 168 | ISBN: 978058059893
[Image: 11193648848247905891.jpg]
[-] The following 7 users Like Mohammad6299's post:7 users Like Mohammad6299's post
  • concreteok, malc, Dell_Brett, zrilek, Magico, learner20, uetian19
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 7,894 05-29-2024, 12:10 PM
  BS EN 1992-1-2: Eurocode 2. Design of concrete structures-Structural fire design poolmand 0 3,320 01-14-2024, 10:04 AM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,788 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,803 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,328 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,594 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,115 07-31-2021, 07:54 PM
Last Post: monter
