Civil Engineering Association eBooks Structural Books Steel SCI P363 Steel building design - design data - blue book (amended may 2011)
Threads: 49
01-29-2013, 06:07 AM
Author: The Steel Construction Institute | Size: 4.97 MB | Format: PDF | Quality: Original preprint | Publisher: The Steel Construction Institute | Year: 2011 | pages: 591 | ISBN: 978-1-85942-186-4
[Image: 47772849020925942417.jpg]
This publication presents design data derived in accordance with the following Parts of Eurocode 3
and their National Annexes:
 BS EN 1993-1-1:2005: Design of steel structures. Part 1-1: General rules and rules for
buildings.
 BS EN 1993-1-5:2006: Design of steel structures. Part 1-5: Plated structural elements.
 BS EN 1993-1-8:2005: Design of steel structures. Part 1-8: Design of joints.
Where these Parts do not give all the necessary expressions for the evaluation of data, reference is
made to other published sources.
The resistances in this publication have been calculated using the partial factors for resistance
given in the UK National Annexes for the Eurocodes (NA to BS EN 1993-1-1:2005 as published in
December 2008, NA to BS EN 1993-1-5:2006 aspublished in May 2008 and NA to BS EN 1993-1-8:2005 as published in November 2008). The partial factors are listed in Section 5.1. The other
parameters given in the National Annex that have been used when calculating member resistances
are given in the relevant section of this publication.
The following structural sections are covered in this publication:
 Universal beams, universal columns, joists, bearing piles, parallel flange channels and
structural tees cut from universal beams and universal columns to BS 4-1
 Universal beams and universal columns produced by Tata Steel* but not included in BS 4-1
 Asymmetric Slimflor® beams (ASB) produced by Tata Steel*
 Equal and unequal angles to BS EN 10056-1
 Hot-finished structural hollow sections to BS EN 10210-2
 Cold-formed structural hollow sections to BS EN 10219-2
Section ranges listed cover sections that are readily available at the time of printing.
Reprint - May 2011
Several corrections have been made, including clarification in the explanatory notes. Ratios used
for the classification of tees and cold formed sections have been corrected. The only changes to
tabulated member resistances are the shear resistances of parallel flange channels. A few minor
formatting errors have been corrected in the design tables.
[-] The following 20 users Like andersen3's post:20 users Like andersen3's post
  • jcbv, blaze, kowheng, abhijit, st77bel, peixoto, vvvv, apocalipse, araza023, slowet, ting tsai huang, seriousboy, ziggywas1, hignacio43, malc, warbeast, Dell_Brett, Nilupa, zrilek, bigone
Threads: 49
01-29-2013, 09:40 AM
try this:
pass:
  • Dell_Brett, Nilupa, zrilek, bigone
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
01-17-2014, 07:33 PM
SCI P363 Steel building design - Blue book (Updated March 2013)
[-] The following 21 users Like Mohammad6299's post:21 users Like Mohammad6299's post
  • vardan, ykhackhack, isurya, toa011, gulilero, jcbv, cace-01, agelos100, malc, oanm2000, Andrew seah, hatkam, bigone, bosskoj, eliseo.as, Dell_Brett, peixoto, PinkPant, cristi, yanburak, zrilek
 vinnunsam
User ID: 3932
Threads: 34
Likes: 1,281 in 116 posts
Given Likes: 457
02-23-2014, 07:42 AM
SCI P363 Steel Building Design Design Data
Size: 1.34 MB | Format: PDF | Quality: Unspecified | Publisher: The Steel Construction Institute and The British Constructional Steelwork Association Ltd | Year: 2013 | pages: 61 | ISBN: 978-1-85942-186-4
[Image: 58457267860669200038.jpg]
This publication presents design data derived in accordance with the following Parts of Eurocode 3 and their National Annexes:
 BS EN 1993-1-1:2005: Design of steel structures. Part 1-1: General rules and rules for buildings.
Where these Parts do not give all the necessary expressions for the evaluation of data, reference is made to other published sources.
The resistances in this publication have been calculated using the partial factors for resistance given in the UK National Annexes for the Eurocodes (NA to BS EN 1993-1-1:2005 as published in December 2008, NA to BS EN 1993-1-5:2006 as published in May 2008 and NA to BS EN 1993-1-8:2005 as
The other parameters given in the National Annex that have been used when calculating member resistances are given in the relevant section of this publication.
[-] The following 16 users Like vinnunsam's post:16 users Like vinnunsam's post
  • Andrew seah, jcbv, vardan, subin91, Dell_Brett, malc, vvvv, gulilero, draluka, hignacio43, yanburak, sacem, zrilek, harsono, Munykong, Aviator
  Australia Steel Institute - Design capacity tables for structural steel leong8929 5 7,088 12-26-2022, 10:41 AM
  Steel Building Design: Concise Eurocodes jamildear4u 3 5,384 12-02-2021, 02:23 PM
Last Post: babakfeyzi
  Australia Steel Ins Design example for multistorey composite steel framed building leong8929 2 3,696 01-18-2020, 05:45 PM
Last Post: monter
  Fatigue Design of Steel and Composite Structures: Eurocode 3: Design of Steel Structu asim99 3 4,061 04-30-2019, 01:29 PM
Last Post: carolinandra
  Tower Design: Design of Steel Structures chandbaba 3 5,827 02-15-2017, 10:04 AM
Last Post: ingab
  Steel Building Design: Worked examples for students rami1976 0 2,073 11-12-2015, 10:39 PM
  ETABS manual - Seismic design of steel building accordance to Eurocode 3 and 8 aslam 5 4,611 01-06-2015, 01:49 PM
Last Post: jcoronellr
