Civil Engineering Association eBooks Structural Books Steel Behavior of Long Links in Eccentrically Braced Frames - Engelhardt, M D; Popov, E P
Threads: 49
02-26-2013, 09:08 AM (This post was last modified: 02-26-2013, 03:13 PM by usman.)
Engelhardt, Michael D.; Popov, Egor P. - Behavior of Long Links in Eccentrically Braced Frames
Author: Engelhardt, Michael D.; Popov, Egor P. | Size: 59.6 MB | Format: PDF | Quality: Scanner | Publisher: UNIVERSITY OF CALIFORNIA AT BERKELEY | Year: 1989 | pages: 414
[Image: 76824871789340444042.jpg]
This report describes an experimental investigation and associated studies on the behavior of long, flexural yielding links in seismic-resistant Eaentrically Braced Frames (EBFs). EBFs provide ductile behavior under severe earthquake loads by restricting yielding to beam segments called "links". Short, shear yielding links are preferred because of their demonstrated excellent plastic rotation and energy dissipation capacities. Longer, flexural yielding links, however, can offer important architectural advantages and have been used on a number of recently constructed EBFs. Little experimental data has been available on the behavior of long links under cyclic loading.
The central focus of this report is an experimental investigation on fourteen 213 scale subassemblages subject to cyclic loads. The subassemblages model a portion of a single-diagonal EBF with the rinks attached to the columns. 'The testing program showed that the dominant failure mode for long links attached to columns is fracture of the link flange at the link-to-column connection. Rased on this experimental program, the recommendation is made that long links attached to columns not be used in EBFs. The test results suggest, however, that long links located between two braces can provide acceptable perfamance, although short Iinks are still preferred for best overall performance.
Because of the very high axial force and bending moment typically carried by the beam segment outside of the link, this member can buckle before link inelastic rotation is fullydeveloped, with a consequent loss in the overall system perfomance. Problems with the beam can be avoided by adhering to capacity design principles. A preliminary design procedure based on capacity design concepts is developed for the beams and braces of an EBF.
Based on the findings of this investigation, combined with the results of previous EBF research, preliminary design recommendations are provided for the use of long links not attaclled to columns. Included are recommendations on the design yield strength, ultimate strength, plastic rotation capacity and stiffening requirements for long links. The testing program has also demonstrated the suitability of selected brace-to-link connection details for use in EBFs with long or short links.
This book was posted in this thread closed with dead link
and a version of 127MB
This version is 59.6MB OCR pdf
[-] The following 11 users Like andersen3's post:11 users Like andersen3's post
  β€’ blaze, vvvv, ssobhan, ting tsai huang, vardan, Dell_Brett, carolinandra, cristi, malc, asim99, bigone
Threads: 49
12-17-2013, 06:12 AM (This post was last modified: 12-17-2013, 06:21 AM by andersen3.)
version OCR pdf
password:
  β€’ bigone, subin91, Dell_Brett, chrono146
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
01-10-2014, 08:36 PM
Author: Engelhardt, Michael D.; Popov, Egor P | Size: 59.8 MB | Format: PDF | Quality: Unspecified | Publisher: UNIVERSITY OF CALIFORNIA AT BERKELEY | Year: 1989 | pages: 414
[-] The following 2 users Like arshiakh's post:2 users Like arshiakh's post
  β€’ Dell_Brett, zrilek
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
12-26-2015, 03:55 PM
PinkPant
[-] The following 11 users Like PinkPant's post:11 users Like PinkPant's post
  β€’ mgdario, amindoxiti, jcbv, cace-01, bridgeengineer, Jackass, malc, slowet, oanm2000, Dell_Brett, scorpion07
  Seismic Design of Buckling-Restrained Braced Frames carolinandra 0 2,078 02-17-2013, 05:37 PM
Last Post: carolinandra
  SCI P183: Design of Semi-continuous Braced Frames ir_71 2 2,561 11-15-2012, 04:37 PM
Last Post: ssobhan
  Steel Building Design: Medium Rise Braced Frames ir_71 2 3,380 01-28-2012, 08:52 PM
Last Post: jokerβ„’
  behavior of long links in eccentrically braced frames preceptor 0 2,678 11-29-2009, 07:55 PM
Last Post: preceptor
  Seismic Behavior of Steel Buildings with Combined Rigid and Semi-Rigid Frames preceptor 2 3,943 11-20-2009, 12:26 AM
Last Post: oanm2000
