Civil Engineering Association eBooks Structural Books Steel Steel frame design - lecture
 bashir999
Khan999
Scotland
User ID: 23118
Threads: 51
Likes: 1,023 in 69 posts
Given Likes: 166
04-28-2011, 08:54 PM (This post was last modified: 04-28-2011, 09:46 PM by Dell_Brett.)
1. Steel frame design
Size: 0.86 MB | Format: PDF | Year: 1991 | pages: 7
Abstract
Focuses on long span structures for commercial buildings. Covers: composite construction, grid size, design methods and codes, long span alternatives, openings in webs of composite beams, castellated beams, stub girders, haunched beams, tapered beams, composite trusses, parallel beam systems, vibration response, vertical cores, fire protection and future systems.
[-] The following 33 users Like bashir999's post:33 users Like bashir999's post
  â€¢ lednar_ved, ISTRAKTURA, jferrer, yucapareja, oanm2000, dinu69in, malc, erimajus, phanbao, kowheng, seriousboy, ruaumoko, vvvv, almadar12, sodapas, zrilek, Jackass, robertsas, taifur, duazo2009, subin91, simanta, narendra, yeka, jahanara, kvtasp, slowet, ting tsai huang, knrsa, Nilupa, yohanga, portal61, techno
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-12-2011, 02:46 PM
[-] The following 8 users Like kvtasp's post:8 users Like kvtasp's post
  â€¢ Dell_Brett, carolinandra, Pinkto, Nilupa, jcbv, cristi, simanta, techno
Threads: 49
12-18-2013, 10:39 AM
new links
password:
  â€¢ Andrew seah, Dell_Brett, ykhackhack
 stlooi
User ID: 28624
Likes: 1 in 1 posts
Given Likes: 3
11-13-2014, 02:10 AM
mirror please
  â€¢
  Steel Frame Design Examples febo927 1 2,273 05-28-2018, 01:57 PM
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 2,111 05-13-2016, 12:35 PM
Last Post: Dobblo
  Advanced Analysis in Steel Frame Design - Guidelines for Direct Second-Order Inelasti asim99 1 2,547 07-07-2014, 03:08 AM
Last Post: i_kabir
  SCI P103: Electric lift installations in steel frame buildings ir_71 2 2,709 12-18-2013, 12:24 PM
Last Post: bigone
  Recommended Seismic Design Criteria for New Steel Moment-Frame Buildings asim99 0 1,993 01-16-2013, 12:47 AM
  Eurobuild in Steel - Comparison of the Design of a Portal Frame ir_71 1 2,852 11-22-2012, 05:50 AM
  Modification of Existing Welded Steel Moment Frame Connections for Seismic Resistance we_mbm 0 1,785 02-07-2012, 02:00 PM
Last Post: we_mbm
