Civil Engineering Association eBooks Journals, Papers and Presentations Influence of diagonal braces in RCC multi-storied frames under wind loads: A case stu
11-25-2013, 04:36 PM
Influence of diagonal braces in RCC multi-storied frames under wind loads: A case study
Author: Suresh P , Panduranga Rao B , Kalyana Rama J.S | Size: 3.6 MB | Format: PDF | Quality: Unspecified | Publisher: NTERNATIONAL JOURNAL OF CIVIL AND STRUCTURAL ENGINEERING Volume 3, No 1, 2012 | Year: 2012 | pages: 13
[Image: 00701445941135377495.png]
Structures are classified as rigid and flexible. Tall structures are more flexible and susceptible to vibrations by wind induced forces. In the analysis and design of high-rise structures estimation of wind loads and the inter storey drifts are the two main criteria to be positively ascertained for the safe and comfortable living of the inhabitants. Estimation of wind loads is more precise with gust factor method. Inter storey drift can be controlled through suitable structural system. The present investigation deals with the calculation of wind loads using static and gust factor method for a sixteen storey high rise building and results are compared with respect to drift. Structure is analyzed in STAAD Pro, with wind loads calculated by gust factor method as per IS 875-Part III with and without X- bracings at all the four corners from bottom to top.
[-] The following 13 users Like TAFATNEB's post:13 users Like TAFATNEB's post
  • blaze, vardan, sodapas, malc, faros3000, gulilero, andersen3, subin91, cace-01, Diquan, slowet, milova, ruaumoko
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,307 10-08-2014, 02:06 PM
  Influence of Structural Parame ters to the Seismic Collapse Resistance of RC Frames i TAFATNEB 0 4,138 04-18-2014, 05:39 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 1 5,586 11-28-2013, 12:06 PM
  Seismic design of steel structures with buckling-restrained knee braces asim99 1 5,341 04-06-2013, 06:49 PM
Last Post: arshiakh
  Stitch Spacing and Local Buckling in Seismic‐Resistant Double‐Angle Braces asim99 0 3,829 04-03-2013, 04:46 PM
  Challenges in the computation of lower-bound buckling loads for tanks under wind pres asim99 0 3,747 04-02-2013, 11:39 PM
  e-Analysis of High-Rise Buildings Subjected to Wind Loads ivanveliki 1 6,547 01-29-2012, 07:07 AM
Last Post: kvtasp
