Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 325.12: Guide for Design of Jointed Concrete Pavements for Streets and Local Road
 Padrino
User ID: 8329
Threads: 1
Likes: 18 in 1 posts
Given Likes: 29
10-23-2013, 06:39 PM (This post was last modified: 05-08-2023, 10:59 AM by Administrator.)
ACI 325.12R-02 Guide for Design of Jointed Concrete Pavements for Streets and Local Roads
Author: ACI Committee 325 | Size: 1.3 MB | Format: PDF | Quality: Unspecified | Publisher: American Concrete Institute | Year: 2002 | pages: 32 | ISBN: 9780870310768
[Image: 11337605729864601460.jpg]
This guide provides a perspective on a balanced combination of pavement thickness, drainage, and sub-base or subgrade materials to achieve an acceptable pavement system for streets and local roads. Such concrete pavements designed for low volumes of traffic (typically less than 100 trucks per day, one way) have historically provided satisfactory performance when proper support and drainage conditions exist. Recommendations are presented for designing a concrete pavement system for a low volume of traffic and associated joint pattern based upon limiting the stresses in the concrete or, in the case of reinforced slabs, maintaining the cracks in a tightly closed condition. Details for designing the distributed reinforcing steel and the load transfer devices are given, if required.
The thickness design of low-volume concrete pavements is based on the principles developed by the Portland Cement Association and others for analyzing an elastic slab over a dense liquid subgrade, as modified by field observations and extended to include fatigue concepts.
This post has been made by CivilEA Post-Generator v2.2.0[url=http://postgen.civilea.com/index.html][/url]
[-] The following 18 users Like Padrino's post:18 users Like Padrino's post
  â€¢ oanm2000, Albert, malc, Dell_Brett, Jackass, uncblue, subin91, jacs1976, cace-01, lisine, mgdario, maijuji, lasalleguy, isurya, eliseo.as, zrilek, learner20, er.shyams
 Rapaig
User ID: 20672
Threads: 2
Likes: 119 in 16 posts
Given Likes: 160
11-19-2013, 07:07 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 4 users Like Rapaig's post:4 users Like Rapaig's post
  â€¢ Dell_Brett, oanm2000, zrilek, learner20
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
11-22-2014, 04:38 AM
concrete solution advocate
[-] The following 9 users Like concreteok's post:9 users Like concreteok's post
  â€¢ blaze, PinkPant, Quantumm, learner20, oanm2000, Munykong, simanta, Mohammad6299, Dell_Brett
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Given Likes: 3501
02-28-2015, 02:05 AM
[-] The following 8 users Like concreteok's post:8 users Like concreteok's post
  â€¢ GMianG, amindoxiti, malc, PinkPant, Dell_Brett, oanm2000, bridgeengineer, milova
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
03-27-2015, 07:58 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
Use forum regular pass
PinkPant
[-] The following 6 users Like PinkPant's post:6 users Like PinkPant's post
  â€¢ amindoxiti, Dell_Brett, oanm2000, knrsa, ykhackhack, sacem
Likes: 8,311 in 1,373 posts
Given Likes: 94
05-08-2023, 10:58 AM
ACI PRC-325.12-02: Guide for Design of Jointed Concrete Pavements for Streets and Local Roads (Reapproved 2019)
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  â€¢ babakfeyzi, PinkPant, Dell_Brett
  ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels poolmand 0 1,999 01-17-2024, 07:27 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 2,054 11-26-2023, 11:51 AM
  ACI 551.2: Design Guide for Tilt-Up Concrete Panels ascetic19 3 3,702 05-09-2023, 12:46 PM
  ACI 440.1: Guide for the Design and Construction of Structural Concrete Reinforced wi poolmand 0 1,893 05-08-2023, 01:39 PM
  ACI 371: Guide for Analysis, Design, & Construction of Elevated Concrete & Composite lisine 3 4,189 05-08-2023, 12:20 PM
  ACI 543: Guide To Design, Manufacture, and Installation of Concrete Piles ir_71 2 3,332 05-08-2023, 11:04 AM
  ACI 349.2: Guide to the Concrete Capacity Design (CCD) Method robertsas 4 5,819 05-08-2023, 10:16 AM
