10-17-2010, 11:29 AM
ACI Journal (Journal Proceedings January-April 1983 vol 80 issue 1-2)
#1 Design of Concrete Brackets: On the Application of the Truss Analogy
#2 Effects of Fiber Content and Damaging Load on Steel Fiber Reinforced Concrete Stiffness
#3 Laboratory Evaluation of Ultrasonics for Crack Detection in Concrete
#4 Computer Nonlinear Analysis of Reinforced Concrete Structures
#5 Radial Tension Strength of Pipe and Other Curved Flexural Members
#6 Rapid Method for Evaluating Bending Moments in a Reticulated Plane Frame Subjected to Lateral Loads
#7 Lateral Stiffness of Flat Plate Structures
#8 Proposed Revisions to: Code Requirements for Nuclear Safety Related Concrete Structures (AC1 349-80) and Commentary on ACI 349-80
#9 Moment Rotation Characteristics of Flat Plate and Column Systems
#10 Early Age Temperature Effects on Concrete Strength Prediction by the Maturity Method
#11 Capacity of Concrete Block Masonary Prisms under Eccentric Compressive Loading
#12 Warping of Reinforced Concrete Slabs Due to Shrinkage
#13 Uncertainty Analysis of Creep and Shrinkage Effects in Concrete Structures
#14 Fracture Model for Fiber Reinforced Concrete
#15 Some Recent Methods for the Design of Steel, Reinforced Concrete, and Composite Steel-Concrete Columns in the U.K.
8,65 Mb
