Civil Engineering Association Software Software Product Bentley Products RAM Structural System V8i Version: 14.05.04.00
 marion33
Poland
User ID: 15632
Threads: 28
Likes: 501 in 66 posts
Given Likes: 885
10-24-2013, 07:12 AM (This post was last modified: 11-24-2014, 12:47 PM by Dell_Brett.)
RAM Structural System V8i (Version: 14.05.04.00 Date: 9/12/2013)
The RAM Structural System is a specialized engineering software tool for the complete analysis, design, and drafting of both steel and concrete buildings. It optimizes workflows through the creation of a single model by providing specialized design functions for buildings and by providing thorough documentation.
RAM Structural System allows for the analysis and design of a building using a single model. The entire structure can be modeled, including decks, slabs, slab edges and openings, beams, columns, walls, braces, spread and continuous footings, and pile caps. This full structural model increases designer confidence and creates an efficient environment when dealing with changes.
The RAM Structural System increases productivity by performing the tedious and time-consuming functions specific to the design of a building such as calculation of live load reductions and lateral load calculations for wind and seismic. In addition, designs are optimized for both concrete and steel.
Your competitive advantage is realized with the thorough documentation. RAM Structural System automatically provides steel material takeoffs and detailed and summary reports of design calculations and drawings. And for BIM, RAM Structural System offers bidirectional integration with CADstudio and Bentley’s Structural Modeler, Structural Documentation Center, and Autodesk's Revit Structure.
[-] The following 15 users Like marion33's post:15 users Like marion33's post
  β€’ zrilek, Williams, oanm2000, Rodmo376, shaker, nickycruz, narendra, promo8, ykhackhack, Visitante, Quantumm, bigone, Mohammad6299, shark, haze
 dl4all
User ID: 41680
Threads: 12
Likes: 210 in 26 posts
Given Likes: 137
02-11-2014, 08:38 PM
Bentley RAM Structural System V8i v14.06.01.00
[Image: 27373541948088435827.jpg]
including Bentley RAM Concept V8i v05.01.01.10
The RAM Structural System is a specialized engineering software tool for the complete analysis, design, and drafting of both steel and concrete buildings. It optimizes workflows through the creation of a single model by providing specialized design functions for buildings and by providing thorough documentation. RAM Structural System allows for the analysis and design of a building using a single model. The entire structure can be modeled, including decks, slabs, slab edges and openings, beams, columns, walls, braces, spread and continuous footings, and pile caps. This full structural model increases designer confidence and creates an efficient environment when dealing with changes. The RAM Structural System increases productivity by performing the tedious and time-consuming functions specific to the design of a building such as calculation of live load reductions and lateral load calculations for wind and seismic. In addition, designs are optimized for both concrete and steel. Your competitive advantage is realized with the thorough documentation. RAM Structural System automatically provides steel material takeoffs and detailed and summary reports of design calculations and drawings. And for BIM, RAM Structural System offers bidirectional integration with CADstudio and Bentley’s Structural Modeler, Structural Documentation Center and Autodesk's Revit Structure.
RAM Concept lets structural engineers model, analyze, and design virtually any cast-in-place geometry, no matter how complex. Efficiency and quality control are realized through the advanced analysis and design tools for reinforced and post-tensioned concrete slabs and mats. Integration allows for analysis and design of a multi-story concrete structure therefore streamlining workflows.
[-] The following 23 users Like dl4all's post:23 users Like dl4all's post
  β€’ ykhackhack, Albert, aslam, Quantumm, bigone, simanta, Visitante, nickycruz, andyspak2, oanm2000, cybermad, blaze, Ivan_1980, Mohammad6299, zrilek, jcbv, Dell_Brett, odiclas, pjcivil, mecheil.edwar, mohcivil, haze, lokitosamax
 ykhackhack
United States
User ID: 36960
Likes: 3,670 in 707 posts
Given Likes: 8693
03-23-2014, 06:41 AM
Mirror
Quote:Thanks to Original uploader.
use winrar 5 & forum password
@lahuta:
[-] The following 23 users Like ykhackhack's post:23 users Like ykhackhack's post
  β€’ Mohammad6299, Dell_Brett, arshiakh, ting tsai huang, jcbv, oanm2000, simanta, Andrew seah, cybermad, mecheil.edwar, nickycruz, kneth, oreslaw, mohcivil, andyspak2, Vincwilson, bigone, melekeen, techno, chenamoy, abdulazizk, promo8, spat
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
11-24-2014, 11:41 AM (This post was last modified: 11-24-2014, 11:52 AM by bigone.)
RAM Structural System V8i x64 Beta 1
(Version: 14.07.00.00 Date: 11/7/2014 )
setup file only
32 bit ,FileSize: 136.94 MB
64 bit ,FileSize: 172.56 MB)
[-] The following 6 users Like bigone's post:6 users Like bigone's post
  β€’ haze, oanm2000, TAFATNEB, Mohammad6299, JOGAR71, oreslaw
 bigone
User ID: 4505
Threads: 85
Given Likes: 7145
03-16-2015, 04:46 PM (This post was last modified: 03-16-2015, 04:48 PM by bigone.)
(Version: 14.07.00.05 Date: 2/20/2015 FileSize: 141.87 MB)
setup file only
[-] The following 3 users Like bigone's post:3 users Like bigone's post
  β€’ TAFATNEB, oanm2000, zrilek
07-22-2015, 06:32 PM
Bentley RAM Structural System V8i (SELECTSeries 7) 14.07.01.01 | 321.7 mb
[Image: 49442613120641001577.jpeg]
Bentley Systems Incorporated, the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released the V8i (SELECTSeries 7) version 14.07.01.01 of RAM Structural System, is the only fully integrated engineering software with complete building analysis, design, and drafting for BOTH steel and concrete structures.
- RAM Structural System allows for the analysis and design of a building using a single model. The entire structure can be modeled, including decks, slabs, slab edges and openings, beams, columns, walls, braces, spread and continuous footings, and pile caps. This full structural model increases designer confidence and creates an efficient environment when dealing with changes.
- The RAM Structural System increases productivity by performing the tedious and time-consuming functions specific to the design of a building such as calculation of live load reductions and lateral load calculations for wind and seismic. In addition, designs are optimized for both concrete and steel.
- Your competitive advantage is realized with the thorough documentation. RAM Structural System automatically provides steel material takeoffs and detailed and summary reports of design calculations and drawings. And for BIM, RAM Structural System offers bidirectional integration with CADstudio and Bentley’s Structural Modeler, Structural Documentation Center, and Autodesk's Revit Structure.
Used by thousands of design firms, steel fabricators, and educators, from one-person firms to some of the largest E&C companies in the world, the RAM Structural System is helping to redefine how engineers work.
RAM Structural System V8i Release 14.07 New Features and Enhancements:
  β€’ zrilek, araza023, LIUKANADA, oanm2000, bridgeengineer, bigone, ykhackhack, ting tsai huang, Hengki, nyungaw, caifan
  RAM Structural System 26 poolmand 0 324 10-18-2026, 07:59 AM
  Bentley RAM Structural System v24 poolmand 0 3,276 10-08-2024, 08:47 AM
  Bentley RAM Structural System v23 poolmand 0 4,258 10-04-2023, 08:19 AM
  RAM Structural System CONNECT Edition V15 Update 11 er.shyams 0 5,566 10-16-2018, 10:00 AM
Last Post: er.shyams
  RAM Structural System CONNECT Edition V15 Update 8 er.shyams 0 4,982 05-01-2018, 01:59 PM
  RAM Structural System CONNECT Edition 15.03.00.00 TAFATNEB 0 5,613 10-28-2016, 08:30 AM
  RAM Structural System v8i BennyP 9 24,003 04-26-2013, 11:51 AM
Last Post: ykhackhack
