Civil Engineering Association eBooks Structural Books Finite Element Methods Continuous and Discontinuous Modelling of Fracture in Concrete Using FEM
 cace-01
User ID: 15651
Threads: 440
Likes: 10,522 in 867 posts
Given Likes: 7468
10-14-2013, 02:21 PM
Author: Jacek Tejchman, ‎Jerzy Bobiński | Size: 42 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2012 | pages: 419 | ISBN: 3642284620
[Image: 67574596668347190284.jpeg]
The book analyzes a quasi-static fracture process in concrete and reinforced concrete by means of constitutive models formulated within continuum mechanics. A continuous and discontinuous modelling approach was used. Using a continuous approach, numerical analyses were performed using a finite element method and four different enhanced continuum models: isotropic elasto-plastic, isotropic damage and anisotropic smeared crack one. The models were equipped with a characteristic length of micro-structure by means of a non-local and a second-gradient theory. So they could properly describe the formation of localized zones with a certain thickness and spacing and a related deterministic size effect. Using a discontinuous FE approach, numerical results of cracks using a cohesive crack model and XFEM were presented which were also properly regularized. Finite element analyses were performed with concrete elements under monotonic uniaxial compression, uniaxial tension, bending and shear-extension. Concrete beams under cyclic loading were also simulated using a coupled elasto-plastic-damage approach. Numerical simulations were performed at macro- and meso-level of concrete. A stochastic and deterministic size effect was carefully investigated. In the case of reinforced concrete specimens, FE calculations were carried out with bars, slender and short beams, columns, corbels and tanks. Tensile and shear failure mechanisms were studied. Numerical results were compared with results from corresponding own and known in the scientific literature laboratory and full-scale tests.
Thanks to Original Uploader
[-] The following 7 users Like cace-01's post:7 users Like cace-01's post
  • ssobhan, blaze, warbeast, sodapas, malc, Dell_Brett, amindoxiti
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
10-14-2013, 02:38 PM
[-] The following 4 users Like ssobhan's post:4 users Like ssobhan's post
  • 3fan, Dell_Brett, lisine, subin91
 al_frd
User ID: 382
Likes: 435 in 78 posts
Given Likes: 5
10-15-2013, 01:39 PM
[-] The following 2 users Like al_frd's post:2 users Like al_frd's post
  • brandizzo, Dell_Brett
  Finite Element and Discontinuous Galerkin Methods for Transient Wave Equations TAFATNEB 0 1,466 11-09-2016, 10:43 AM
  Modelling of Corroding Concrete Structures hich 3 2,880 03-07-2013, 02:18 AM
Last Post: Dell_Brett
  Discontinuous Galerkin Methods: Theory, Compuration and Applications mary 1 2,133 12-24-2012, 09:08 AM
Last Post: shadabg
  Discontinuous Finite Elements in Fluid Dynamics and Heat Transfer lisine 1 1,791 07-30-2012, 11:02 AM
Last Post: shadabg
