Civil Engineering Association eBooks Structural Books Steel SCI P102: Connections between steel and other materials
04-02-2011, 05:20 AM
Author: R G Ogden, R Henley | Size: 2.7 MB | Format: PDF | Publisher: SCI | Year: 1996 | pages: 96 | ISBN: 1859420044
[Image: 88186809026003942116.jpg]
Many building and refurbishment projects require structural connections between steelwork and other materials, such as concrete or masonry. This publication examines the design and construction issues implicit in these connections, and presents a range of details. Each detail is appraised in terms of its structural performance and construction qualities, and an indication is given of where the detail may appropriately be used. There are many factors that influence the form of connection details, and these vary considerably from project to project. Details are therefore presented as schematic arrangements that may be adapted to suit the requirements of individual projects. Where structural steelwork is used in conjunction with other structural materials, various connection details may be required. These include:
- e steel column connections to foundations and floor slabs;
- e steel beam connections to concrete core walls;
- e steel beam connections to concrete columns;
- e steel beam connections to masonry walls and beams.
Connection details should recognise the physical characteristics of both steelwork and the material to which the steelwork is connected. Details should generally seek to optimise structural requirements, buildability and cost. Where architectural or other criteria demand unique or specialised details beyond the scope of this publication, similar design principles will apply. However, there will usually be an additional aesthetic requirement.
Section 1 of this publication sets out performance requirements for connection between steel and other materials. Section 2 presents a range of schematic details.
[-] The following 46 users Like ir_71's post:46 users Like ir_71's post
  â€¢ kowheng, almadar12, hmwere, malc, tmstru, Mouh@ndiss, zrilek, DamaD, vvvv, jferrer, oanm2000, toa011, seriousboy, nowanda, nuttapolk, chairatpk, jaks, Ivan_1980, dinu69in, Nilupa, eliseo.as, baikur, zego2000, kmmh76, kvtasp, chrono146, Dell_Brett, ting tsai huang, miquan, NBZ1400, yeka, subin91, thebeatles, knrsa, ascetic19, warbeast, lednar_ved, avge, cristi, tavofox, mahyarov, julioreptil, tang1942, Hengki, techno, bigone
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-12-2011, 05:10 PM
[-] The following 4 users Like kvtasp's post:4 users Like kvtasp's post
  â€¢ Dell_Brett, thebeatles, slowet, bigone
Threads: 49
11-16-2012, 08:25 AM
all links dead; direct link here
[-] The following 11 users Like andersen3's post:11 users Like andersen3's post
  â€¢ Dell_Brett, zego2000, Jackass, xdesi, k2kyaw, ruaumoko, simanta, blaze, Andrew seah, bigone, zrilek
 subin91
User ID: 2232
Threads: 35
Likes: 2,192 in 111 posts
Given Likes: 4701
10-14-2013, 07:39 AM (This post was last modified: 10-14-2013, 07:54 AM by Dell_Brett.)
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 4 users Like subin91's post:4 users Like subin91's post
  â€¢ Dell_Brett, chandra1234567, vvvv, bigone
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
10-14-2013, 02:39 PM (This post was last modified: 10-14-2013, 02:47 PM by ssobhan.)
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 7 users Like ssobhan's post:7 users Like ssobhan's post
  â€¢ gulilero, malc, usman, chenamoy, bigone, febo927, levanduy
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,382 01-10-2023, 12:16 AM
Last Post: carolinandra
  Architecturally Exposed Structural Steel: Specifications, Connections, Details carolinandra 0 1,999 01-25-2019, 11:06 AM
  Design and Analysis of Connections in Steel Structures: Fundamentals and Examples amindoxiti 1 2,793 12-16-2018, 07:54 AM
Last Post: malee
  Proceedings of the Workshop on Connections in Steel Structures Flexi 4 5,239 06-14-2018, 01:14 PM
Last Post: gulilero
  SCI P101: Curtain wall connections to steel frames ir_71 3 4,110 02-27-2016, 04:51 AM
Last Post: cabpcabp
  Moment Resistant Connections of Steel Frames in Seismic Areas: Design and Reliability Grunf 4 5,590 09-07-2014, 09:44 PM
Last Post: apocalipse
  Joints in steel construction: Composite connections choonguan 3 5,181 02-19-2014, 06:40 AM
Last Post: vinnunsam
