Civil Engineering Association eBooks Journals, Papers and Presentations Second Order Effects of Gravity under Horizontal Earthquake Load and Preventive Measu
09-08-2013, 09:20 PM
Second Order Effects of Gravity under Horizontal Earthquake Load and Preventive Measures
Author: Wen-jie Niu | Size: 0.48 MB | Format: PDF | Quality: Unspecified | Publisher: INTERNATIONAL JOURNAL OF CIVIL AND STRUCTURAL ENGINEERING Volume 2, No 4, 2012 | Year: 2012 | pages: 7
[Image: 60138042478389314553.png]
Building only with shallow foundation may overturns under earthquake load. This paper
intends to investigate the building overturn principle and adopt fundamental measures to
prevent such dangers. After consider the building self-weight P.∆
effect(Second order
effect) and take the building as research object, one can find that if we increase building
foundation width and decrease building height , resistant moment R M can be larger than overturn moment o M at the rotating beginning. And the building is safe. Another way to increase the building overall stability is to use raft pile groups which are common method to prevent the overturn of building. There are two possible combined stress groups on the surface between piles top surface and building foundation bottom surface. One is compressive stress and shear stress when the earthquake acceleration is not too large. The other is tensile and shear stress when the earthquake acceleration is extremely large. To ensure the safety of the building, professional engineers can design the pile-raft connections stress not to exceed the allowable combined stress.
  • malc, Dell_Brett, gulilero, kowheng, blaze, rezart, vardan, sodapas, camto2
  FOUNDATIONS FOR INDUSTRIAL MACHINES AND EARTHQUAKE EFFECTS TAFATNEB 0 3,802 10-25-2013, 03:10 PM
  Torsional analysis of multi-storey building structures under horizontal load asim99 0 4,201 05-04-2013, 03:14 AM
  Along-Wind Load Effects on Tall Buildings asim99 0 5,788 11-28-2012, 10:20 PM
  International Symposium on Strong-motion Earthquake Effects miquan 1 4,992 10-08-2011, 02:02 PM
Last Post: miquan
