Civil Engineering Association eBooks Journals, Papers and Presentations Nonlinear Seismic Response Analysis of Realistic Gravity Dam-Reservoir Systems
09-03-2013, 07:00 AM
Author: P.G. Asteris, A.D. Tzamtzis | Size: 0.4 MB | Format: PDF | Quality: Unspecified | Publisher: International Journal of Nonlinear Sciences and Numerical Simulation 4(2003) 329-338 | Year: 2003 | pages: 10 | ISBN: Freund Publishing House Ltd
[Image: 83953694462493968611.png]
A methodology for the earthquake response analysis of concrete gravity dam-reservoir systems is
presented, giving emphasis at the development of an appropriate nonlinear model capable of reproducing the
effects on response of all the forms of nonlinearities present in a realistic system. The numerical simulation of
the displacement response history of a real-life system to a known seismic excitation has been performed
using the finite element method and specially developed interface elements have been employed to model the
discontinuities of the structure. The results obtained demonstrate that the earthquake response of the system is
significantly affected by the behaviour at the interfaces between contacting materials.
  â€¢ blaze, malc, vardan, Dell_Brett, kowheng
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,645 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,043 12-26-2014, 09:49 PM
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,242 11-15-2014, 02:07 PM
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,120 10-21-2014, 08:57 AM
Last Post: Munykong
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,086 09-05-2014, 01:46 PM
  Seismic response of earth dams: some recent developments TAFATNEB 0 4,401 08-12-2014, 09:33 AM
  Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 4,366 08-10-2014, 02:59 PM
