Civil Engineering Association eBooks Journals, Papers and Presentations Scientific journals and Research papers Full-scale Tests for Seismic Performance Verification of Steel Building Structures wi
08-31-2013, 12:21 PM
Full-scale Tests for Seismic Performance Verification of Steel Building Structures with Hysteretic Dampers
Author: Praween CHUSILP* and Keiichiro SUITA | Size: 0.84 MB | Format: PDF | Quality: Unspecified | Publisher: Annuals of Disas. Prev. Res. Inst., Kyoto Univ., No. 47 C, 2004 | Year: 2004 | pages: 14
[Image: 59015917059907473737.png]
This paper presents an innovative structural system, named weld-free system,
developed to overcome the difficulty in the quality assurance encountered in
construction of steel moment resisting frames with conventional welded connections.
The proposed structural system adopts a mechanical joint equipped with metallicyielding
damper as beam-to-column connection, wherein slip-critical joints are made by
recently developed super high-strength bolts. The structural configuration and loadcarrying
mechanism of the weld-free system are described herein. Key features of the
super high-strength bolts are also introduced. Consequently, two series of experimental
verifications of weld-free steel structures are presented. The first series was conducted
on three full-scale models of weld-free beam-column subassemblies and one base-line
specimen with conventional welded connection. The second series was performed on
the whole full-scale three-story weld-free building. The two test series clearly reveal the
efficiency of the weld-free system in enhancing large and stable hysteresis loops, while
beams and columns above the base can be proportioned to remain elastic under the
design earthquakes.
  â€¢ gulilero, malc, ykhackhack, kowheng, araza023, faros3000
  Effect of floor slabs on the seismic performance of RC frames TAFATNEB 3 8,866 07-17-2014, 08:07 AM
  Performance Based Inelastic Seismic Analysis of Buildings TAFATNEB 0 4,792 04-17-2014, 11:12 AM
  Shake table tests of under-designed RC frames for the seismic retrofit of buildings – TAFATNEB 0 4,164 09-10-2013, 02:14 PM
  SEISMIC PERFORMANCE OF SUPER TALL BUILDINGS TAFATNEB 0 4,448 09-08-2013, 08:59 PM
  Performance-Based Seismic Design Code for Buildings in Japan TAFATNEB 0 4,391 09-02-2013, 08:11 PM
  BUILDING SEISMIC PERFORMANCE TAFATNEB 0 3,598 09-02-2013, 07:40 PM
