Civil Engineering Association eBooks Journals, Papers and Presentations INFLUENCE OF SOIL CONDITIONS ON BUILDING VULNERABILITY
08-27-2013, 10:32 AM (This post was last modified: 08-27-2013, 11:53 AM by oanm2000.)
Author: CERASELA-PANSELUŢA OLARIU ,* , IOANA OLTEANU , YEUDY FELIPE VARGAS and MIHAI BUDESCU | Size: 7.3 MB | Format: PDF | Quality: Unspecified | Publisher: Universitatea Tehnică „Gheorghe Asachi” din Iaşi | Year: may 2011
Seismic risk assessment of structures is one of the key elements in estimating and reducing losses that may appear after earthquakes. Building vulnerability quantifies the damages a structure can handle under a known seismic load. Usually, structures are considered to be fixed at the base in the design process, but researchers have highlighted the importance of considering the actual soil conditions in the analysis. In this paper, a nonlinear static analysis(pushover) is performed in SAP 2000, for a reinforced concrete 2-D frameresting on different types of soils. Comparisons between capacity curves,vulnerability curves and between the failure mechanism have been performed.From these comparisons, it was possible to extract some observations concerningthe soil condition influence upon building vulnerability and seismic risk for a RC frame.
  • rezart, shadabg, gulilero, malc, daywalker, kowheng, cace-01, ykhackhack
  Vulnerability evaluation and seismic rehabilitation of steel building with semi-rigid TAFATNEB 0 3,858 05-09-2014, 10:22 AM
  Vulnerability assessment and earthquake damage scenarios of the building stock of Pot TAFATNEB 0 4,127 04-29-2014, 09:09 PM
  Modeling the Effects of Soil-Structure Interaction on a Tall Building Bearing on a Ma TAFATNEB 0 4,573 09-14-2013, 10:57 AM
  Influence of the soil–structure interaction on the fundamental period of buildings TAFATNEB 0 4,028 09-06-2013, 10:08 AM
  Soil-Structure Interaction of High-rise Building Resting on Soft Soil NAUTILUS87 2 7,451 12-28-2011, 01:41 PM
Last Post: Dell_Brett
  Non-linear seismic analysis and vulnerability evaluation of a masonry building SAP2k hazus 0 5,199 07-14-2010, 08:05 PM
Last Post: hazus
