Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis MITIGATION OF COLLAPSE RISK IN VULNERABLE CONCRETE BUILDINGS
08-25-2013, 11:50 AM (This post was last modified: 08-26-2013, 02:49 PM by oanm2000.)
Author: Lisa Matchulat | Size: 4.94 MB | Format: PDF | Quality: Unspecified
The goal of this study is to investigate the collapse risk of reinforced concrete building columns constructed prior to the mid-1970’s, subjected to cyclic lateral loading. These columns have reinforcement details deemed inadequate by modern seismic design standards, and as such are vulnerable to collapse. Testing of two full-scale, shear-critical column specimens was carried out at the NEES-MAST facility at the University of Minnesota. The test specimens had nominally identical material and reinforcement properties. The primary test variable was the applied axial load, which was held constant at 500 kips and 340 kips for the first and second specimens, respectively. The specimens were subjected to increasing lateral displacement cycles until axial load carrying capacity was lost. The thesis discusses the observed lateral and axial load resisting behavior, and analyzes the measured responses of the columns up to and beyond the lateral drift at which they were able to sustain axial load. Test results indicate that column behavior was significantly influenced by the magnitude of the applied axial load, and that the ratio of axial load to gross axial capacity of the longitudinal reinforcement is a key parameter in identifying columns in which axial failure occurs simultaneously with shear failure.
  • blaze, malc, renecorona, kowheng, cace-01, oanm2000, mgdario, apocalipse
  Assessment of Progressive Collapse Requirements for Precast Concrete Buildings TAFATNEB 0 2,094 12-13-2014, 05:08 PM
  COLLAPSE ASSESSMENT OF CONCRETE BUILDINGS: AN APPLICATION TO NON-DUCTILE REINFORCED C TAFATNEB 0 1,876 12-28-2013, 08:59 PM
  Progressive Collapse Simulation of Reinforced Concrete Structures: Influence of Desig TAFATNEB 0 2,024 11-23-2013, 01:46 PM
  Seismic Risk Assessment of Unreinforced Brick Masonry Buildings System of Northern Pa TAFATNEB 0 1,884 11-02-2013, 12:53 PM
