Civil Engineering Association eBooks Journals, Papers and Presentations Direct Strut-and-Tie Model for Prestressed Deep Beams
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
05-27-2013, 08:36 PM
Author: K. H. Tan, K. Tong and C. Y. Tang | Size: 169 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 2001 | pages: 9
The strut-and-tie method is a promising analytical tool for the design of disturbed regions where
the conventional plane bending theory does not hold. These include pile caps, corbels, frame joints, deep beams,
and so forth. This paper focuses on the application of a strut-and-tie model to prestressed deep beams. A simple
and direct model is proposed, taking the prestressing effect into consideration. The model can be used for both
pre- and posttensioned deep beams. Different configurations of web reinforcement can also be properly modeled
in the proposed approach. A comparison shows that the predictions are in good agreement with experimental
results of four case studies of 39 beams.
[-] The following 14 users Like asim99's post:14 users Like asim99's post
  â€¢ vardan, Jackass, viet2010, gulilero, kowheng, Mohammad6299, ykhackhack, malc, vvvv, blaze, chrono146, slowet, techno, sodapas
  Strut-and-Tie Model for Deep Beam Design odiclas 0 4,795 08-15-2014, 03:06 PM
Last Post: odiclas
  Interactive Mechanical Model for Shear Strength of Deep Beams (With Discussion & Clos asim99 0 4,183 05-27-2013, 08:48 PM
  Size Effect on Shear Strength of Deep Beams: Investigating with Strut-and-Tie Model asim99 0 4,507 05-27-2013, 08:44 PM
  Single-Span Deep Beams Subjected to Unsymmetrical Loads asim99 0 3,681 05-27-2013, 08:40 PM
  Strut and Tie Model for Deep Beam Design ranger 1 6,559 12-13-2012, 09:01 PM
Last Post: Grunf
