Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Books and Codes Request [REQUEST] ACI SP-17(11) The Reinforced Concrete Design Manual Volumes 1 & 2 Package
[Request] ACI SP-17(11) The Reinforced Concrete Design Manual Volumes 1 & 2 Package
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
05-20-2013, 06:08 AM (This post was last modified: 05-20-2013, 06:11 AM by bigone. Edit Reason: N/A )
Details:
Volume 1 - Columns, Deflection, Flexure, Footings, Seismic, Shear, Strut-and-tie
This manual is published in two volumes. Volume 1 includes design and analysis for columns, flexure, footings, seismic, shear, and two new chapters on deflection and strut-and-tie in accordance with ACI 318-11. Information is presented in three sections: Explanatory Material, Design Examples, and Design Aids. The Introduction of each chapter includes explanatory material that provides the engineer with concise background of the subject. The Design Examples illustrate the use of the Design Aids, which are tables and graphs intended to eliminate routine and repetitious calculations. Volume 2 (available separately) includes design and analysis for anchorage to concrete.
Volume 2
This manual is published in two volumes. Volume 2 includes design and analysis for a new chapter on anchorage to concrete in accordance with ACI 318-11. Information is presented in three sections: Explanatory Material, Design Examples, and Design Aids. The Introduction of each chapter includes explanatory material that provides the engineer with concise background of the subject. Volume 1 (available separately) includes design and analysis for columns, flexure, footings, seismic, shear, and two new chapters on deflection and strut-and-tie.
[-] The following 1 user Likes bigone's post:1 user Likes bigone's post
  â€¢ thangbomkhung
 camto2
Cambodia
User ID: 88877
Threads: 35
Likes: 1,240 in 101 posts
Given Likes: 106
09-16-2015, 04:14 PM
I see this SP 17(97), but I am not sure if it is what you want. Good luck:
[-] The following 7 users Like camto2's post:7 users Like camto2's post
  â€¢ ting tsai huang, K.Lee, malc, PinkPant, mavilladar, bigone, civilphongvan
 spiritmedal
Indonesia
User ID: 40849
Threads: 9
Likes: 18 in 10 posts
Given Likes: 21
05-10-2016, 12:57 PM
[Image: 25911769192669551271.jpg]
  • Article/eBook Full Name:
  • ACI SP-17(11) The Reinforced Concrete Design Manual Volumes 1 & 2 Package
  • Author(s):
  • ACI (American Concrete Institute)
  • Publish Date:
  • 2012
  • Published By:
Does Anyone has this pdf for volume 1 and 2?. If there is metric version, it will better.
Thanks.
  â€¢
 Dann15
United States
User ID: 100250
Likes: 0 in 0 posts
Given Likes: 9
08-03-2017, 04:13 PM
  • ACI SP-17(11): The Reinforced Concrete Design Manual Volumes 1 & 2 Package
  • Author(s):
  • ACI
  • Edition:
  • 11
  • Publish Date:
  • 2012
  • ISBN:
  • 0870319221
  • Published By:
  • ACI
  • Related Links:
  • Code:
Would anybody happen to have this version of this ACI publication? I have only found the 09 version in the forums. Any help is much appreciated.
  â€¢
 usman
User ID: 59
Threads: 131
Likes: 6,571 in 671 posts
Given Likes: 4974
08-04-2017, 03:55 PM
Follow the link for ACI SP-17(14): The Reinforced Concrete Design Handbook
[-] The following 8 users Like usman's post:8 users Like usman's post
  â€¢ mgdario, cace-01, Dann15, hatkam, K.Lee, concreteok, Diquan, psppsp
  [REQUEST] HSS Design Manual Bundle Volumes 1 + 2A + 2B + 3 +4 sabooryan 1 8,097 08-21-2025, 08:46 AM
Last Post: civilfafa
  [REQUEST] AASHTO LRFD Bridge Design Specifications for GFRP-Reinforced Concrete, 2nd Edition whysx 1 2,092 08-30-2023, 08:59 AM
  [REQUEST] Reinforced concrete design workflow to eurocode 2 anneb361 2 2,210 04-13-2022, 04:39 PM
Last Post: anneb361
  [REQUEST] CRSI Design Guide for Vibrations of Reinforced Concrete Floor Systems gulilero 3 3,775 02-28-2022, 11:45 AM
Last Post: bigone
  [REQUEST] MNL-17(21) - ACI Reinforced Concrete Design Handbook (A companion to ACI 318-19) aslam 9 5,410 05-17-2021, 12:49 PM
Last Post: deviationz
  [REQUEST] Design Guide for Reinforced Concrete Diaphragms toddyi 0 1,768 09-24-2019, 09:59 AM
Last Post: toddyi
  [REQUEST] ACI 544.6R-15 Report on Design and Construction of Steel Fiber-Reinforced Concrete El aslam 2 2,462 01-08-2019, 02:45 AM
Last Post: concreteok
