Civil Engineering Association eBooks Journals, Papers and Presentations A performance-based design approach for retrofitting regular building frames with ste
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
05-20-2013, 05:00 AM
A performance-based design approach for retrofitting regular building frames with steel braces against sudden column loss
Author: Meng-Hao Tsai | Size: 2.07 MB | Format: PDF | Quality: Unspecified | Publisher: Science Direct | Year: 2012 | pages: 11
Progressive collapse resistance of existing building structures against sudden column loss may be increased
with adequate supply of steel braces. A performance-based design approach for retrofitting regular building
frames with steel braces is proposed in this study. The retrofit design approach is developed from the pseudostatic
response analysis of an idealized elastic–plastic, single degree-of-freedom system. Analytical relationship
between the increment of collapse resistance and structural characteristics is derived to determine the design
strength and stiffness of added braces. Accuracy of the proposed approach is verified with incremental dynamic
analysis. Also, its application to multi-story buildings is demonstrated with three frame models. Conservative
performance is obtained with the design approach, especially for a larger resistance increment. An iterative
modification technique is suggested to refine the retrofit design and only a few nonlinear static iterations are
required for convergence. Nonlinear dynamic analysis results indicate that the column-loss response of the
braced frames is approximated to the performance target and thus the proposed retrofit design approach is
feasible for practical applications.
  β€’ pedzaquino, Jackass, blaze, devilmaycry, kowheng, malc, Dell_Brett, ykhackhack
 Jackass
Bolivia
User ID: 29460
Threads: 24
Likes: 1,138 in 115 posts
Given Likes: 7399
07-07-2013, 10:26 PM
Hi
Here is new link
[-] The following 4 users Like Jackass's post:4 users Like Jackass's post
  β€’ gulilero, Dell_Brett, ykhackhack, slowet
  NDN Software - Design Approach chottabhai 2 6,944 07-08-2026, 01:22 PM
Last Post: Dsg
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,647 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,365 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Performance based earthquake design using the CPT PinkPant 0 5,837 05-14-2015, 08:17 AM
Last Post: PinkPant
  Performance –Based Design emmi 2 8,055 03-24-2015, 10:10 AM
Last Post: ssobhan
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 5,206 08-10-2014, 01:15 PM
  Performance Based Earthquake Engineer ing: Application to an Actual Bridge-Foundation TAFATNEB 0 4,171 05-03-2014, 09:06 AM
