Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 1744-1:2009 Tests for chemical properties of aggregates. Chemical analysis
04-28-2012, 07:19 AM
Author: Technical Committee CEN/TC 154 | Size: 0.6 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2009 | pages: 62
[Image: 11912475133537774788.jpg]
This European Standard specifies procedures for the chemical analysis of aggregates. It specifies the reference procedures and, in certain cases, an alternative method which can be considered as giving equivalent results.
Unless otherwise stated, the test methods specified in this standard may be used for factory production control, for audit tests or for type tests.
This standard describes the reference methods used for type testing and in cases of dispute (and alternatives methods) for chemical analyses of aggregates. For the purpose of type testing and in cases of dispute only the reference method should be used. For other purposes, in particular factory production control, other methods may be used provided that an appropriate working relationship with the reference method has been established.
  â€¢ st77bel, Dell_Brett, Jackass, kowheng, vpmohammed, peixoto, mahyarov, asim99
05-16-2013, 03:06 PM
  â€¢ blaze, 3fan, Dell_Brett, utan, st77bel, andersen3, lisine, asim99, peixoto
 st77bel
Romania
User ID: 12964
Threads: 12
Likes: 432 in 86 posts
Given Likes: 696
08-04-2013, 06:18 AM
Could someone to provide the new edition EN 1744-1:2009+A1:2012 ?
  â€¢
  BS EN 1097-2:2010 Tests for mechanical and physical properties of aggregates. Methods ir_71 1 2,369 07-21-2017, 04:39 PM
  BS EN 933-8:2012 Tests for geometrical properties of aggregates. Assessment of fines. mybest 1 2,410 06-05-2014, 02:28 PM
  BS EN 933-10 Tests for geometrical properties of aggregates. Assessment of fines. Gra ir_71 1 2,567 02-24-2014, 05:16 PM
  BS EN 933-3:2012 Tests for geometrical properties of aggregates. Determination of par mybest 1 2,483 10-02-2013, 05:47 AM
  BS EN ISO 9453 2006 Soft solder alloys. Chemical compositions and forms mybest 2 2,269 02-25-2013, 07:30 AM
Last Post: arshiakh
  BS 4551:2005 Mortar — Methods of test for mortar - Chemical analysis and physical tes ir_71 1 2,587 09-29-2012, 04:37 AM
  BS EN 1097-10:2002 Tests for mechanical and physical properties of aggregates. Determ ir_71 0 1,916 08-20-2012, 02:43 PM
