Civil Engineering Association eBooks Journals, Papers and Presentations A Case Study on Excavation Stabilization Using Ground Anchors and High Pressure Injec
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
05-12-2013, 06:14 PM
A Case Study on Excavation Stabilization Using Ground Anchors and High Pressure Injection
Author: Ali Parsapajouh, Siavash Litkouhi, Bahram Amini | Size: 2.5 MB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 2012 | pages: 9
In this study, case study about excavation stabilised using anchors and
high pressure injectionis presented. The land of the project was located in the
northern zone of Tehran with shallow water table. Despite of dewatering operation,
the existence of groundwaterwas still a challenging issue concerning the construction
process.According to the pull-out tests, the gravity-grouted anchors could not satisfy
the design criteria. Therefore, the post-grouting method was employed to increase the
tensile capacity of anchors by enlarging the grout body of straight shafted gravity
grouted anchors. Finally, the loading tests were conducted and anchors locked-off at
75% of designed loads. It should be mentioned that the cast-in place concrete piles
were constructed around the excavation zone as the soldier beams. Satisfactory post
construction performance of this project proves the successful application of 3900 m
of ground anchors in 2800 m2 of excavation wall for this deep excavation.
[-] The following 7 users Like asim99's post:7 users Like asim99's post
  â€¢ maxpn3, malc, Jackass, kowheng, concreteok, kuyasipil, uetian19
  Seismic Retrofitting of Historic Masonry Buildings – Case Study Grunf 3 10,734 05-26-2016, 03:19 AM
Last Post: gulilero
  Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Co TAFATNEB 0 4,468 04-17-2014, 10:21 AM
  6-Storey Mixed Use Building in Karachi A Pilot Case Study of Seismic Assessment and R TAFATNEB 0 4,470 11-02-2013, 01:54 PM
  On the Seismic Vulnerability of Existing Buildings: A Case Study of the City of Basel TAFATNEB 0 4,019 08-27-2013, 10:44 AM
  TTM Ground Anchors, Geotechnical and ground anchor system ir_71 0 4,998 06-24-2011, 06:16 PM
  RECENT ADVANCES IN GROUND ANCHOR AND GROUND REINFORCEMENT TECHNOLOGY giguni 0 5,209 09-27-2010, 02:38 PM
Last Post: giguni
