Civil Engineering Association eBooks General Books IIW Rec. for the Fatigue Assessment of Welded Structures by Notch Stress A
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
03-04-2013, 06:18 AM (This post was last modified: 04-26-2013, 07:36 AM by Dell_Brett.)
IIW Recommendations for the Fatigue Assessment of Welded Structures by Notch Stress Analysis: IIW-2006-09
Author: Wolfgang Fricke | Size: 3 MB | Format: PDF | Quality: Unspecified | Publisher: Woodhead Publishing | Year: 2012 | pages: 48 | ISBN 10: 0857098551
[Image: 87170633100079037469.jpg]
The notch stress approach for fatigue assessment of welded joints is based on the highest elastic stress at the weld toe or root. In order to avoid arbitrary or infinite stress results, a rounded shape with a reference radius instead of the actual sharp toe or root is usually assumed.Wolfgang Fricke reviews different proposals for reference radii together with associated S-N curves. The guidelines give detailed recommendations for the numerical analysis of notch stress by the finite or boundary element method and present appropriate S-N curves for the assessment of the fatigue strength of different materials. Finally, four examples illustrate the application of the approach as well as the variety of structures which can be analyzed and the range of results which can be obtained from different models. Published in Association with the International Institute of Welding (IIW).
[-] The following 5 users Like asim99's post:5 users Like asim99's post
  â€¢ blaze, kowheng, jcbv, Dell_Brett, zrilek
 asim99
User ID: 9774
Threads: 461
Given Likes: 377
03-04-2013, 01:54 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 3 users Like asim99's post:3 users Like asim99's post
  â€¢ Dell_Brett, malc, slowet
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 2 users Like Dell_Brett's post:2 users Like Dell_Brett's post
  â€¢ andersen3, shadabg
  Assessment, evaluation, and repair of concrete, steel, and offshore structures carolinandra 0 1,687 04-15-2019, 01:24 PM
Last Post: carolinandra
  Nondestructive techniques for the assessment and preservation of historic structures carolinandra 0 1,765 12-20-2018, 03:03 PM
  IIW Recommendations on Methods for Improving the Fatigue Strength of Welded Joints Ii asim99 0 1,730 03-04-2013, 06:25 AM
  Fatigue Assessment of Welded Joints by Local Approaches, Second Edition rendel_© 3 2,985 05-02-2012, 02:04 AM
Last Post: david-smith
  TRIBO-FATIGUE Wear-Fatigue Damage and its prediction ir_71 0 1,656 04-13-2011, 07:38 AM
  Condition Assessment of Aged Structures abudabeeja 1 2,398 02-15-2011, 06:54 AM
