Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 562: Code Requirements for Evaluation, Repair, and Rehabilitation of Concrete
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
02-28-2013, 06:59 PM (This post was last modified: 05-06-2023, 10:45 AM by Administrator.)
ACI 562-12: Code Requirements for Evaluation, Repair, and Rehabilitation of Concrete Buildings
Author: ACI Committee 562 | Size: 898 KB | Format: PDF | Quality: Original preprint | Publisher: American Concrete Institute | Year: 2012 | pages: 60 | ISBN: 0870317784
[Image: 11664797166632828604.png]
This code provides the minimum requirements for the evaluation, repair, rehabilitation, and strengthening of existing concrete buildings and, where applicable, in non-building structures. The code is comprised of both prescriptive and performance requirements. Commentary is provided for both the prescriptive and performance requirements and is intended to provide guidance to the licensed design professional and referenced sources for additional information the material presented in the code provisions. The code and commentary is intended for use by individuals who are competent to evaluate the significance, limitations of its content and recommendations, and who will accept responsibility for the application of the material it contains.
[-] The following 23 users Like junaid's post:23 users Like junaid's post
  β€’ Quantumm, vardan, arshiakh, usman, malc, Hengki, ting tsai huang, kowheng, cace-01, Dell_Brett, portal61, pedzaquino, abouferass88, toa011, mahyarov, yutt, oanm2000, civilchin, bigone, Ernest0, tomtumx, ykhackhack, alohaloha
 junaid
User ID: 402
Threads: 197
Given Likes: 983
04-24-2013, 03:12 PM
[-] The following 16 users Like junaid's post:16 users Like junaid's post
  β€’ pezhmankhan, mr.nicus, simanta, Dell_Brett, tomtumx, ykhackhack, malc, mgdario, araza023, arceon, ir_71, bigone, civilgr, cosminupt, shadabg, sacem
Threads: 274
Likes: 12,075 in 1,233 posts
04-24-2013, 03:15 PM
[-] The following 11 users Like pezhmankhan's post:11 users Like pezhmankhan's post
  β€’ spiderthan, devilmaycry, tomtumx, ykhackhack, oanm2000, Ultra Zone, wa_sin_29, bigone, rezart, cosminupt, simanta
 essenza
User ID: 865
Threads: 39
Likes: 296 in 111 posts
Given Likes: 294
06-11-2014, 07:43 AM
I've check, all links above are dead, pls can someone reuplaod this.
Tks b4
[-] The following 1 user Likes essenza's post:1 user Likes essenza's post
  β€’ pmg814
06-12-2014, 05:16 PM
ACI 562-13 Code Requirements for Evaluation, Repair, and Rehabilitation of Concrete Buildings (ACI 562-13) and Commentary
Author: ACI Committee 562 | Size: 0.3 MB | Format: PDF | Quality: Original preprint | Publisher: ACI | Year: 2013 | pages: 59 | ISBN: 9780870318085
[Image: 96275679415854629007.jpg]
This code provides minimum requirements for the evaluation, repair, rehabilitation, and strengthening of existing concrete buildings and, where applicable, nonbuilding structures.
This code does not provide complete design procedures or construction means and methods. The code comprises both prescriptive and performance requirements. Commentary is provided for both the prescriptive and performance requirements, and is intended to provide guidance to the licensed design professional and referenced sources for additional information on the material presented in the code provisions.
The code and commentary is intended for use by individuals who are competent to evaluate the significance and limitations of its content and recommendations, and who will accept responsibility for application of the material it contains.
The materials, processes, quality control measures, and inspections described in this code should be tested, monitored, or performed as applicable only by individuals holding the appropriate ACI Certifications or equivalent.
[-] The following 28 users Like ir_71's post:28 users Like ir_71's post
  β€’ Mohammad6299, malc, vardan, Rapaig, jfjdm, tomtumx, concreteok, subin91, simanta, Dell_Brett, PinkPant, vvvv, ting tsai huang, zrilek, Jackass, ssobhan, oanm2000, essenza, aslam, mgdario, ykhackhack, pezhmankhan, uncblue, araza023, bigone, shaker, Wijono, faros3000
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
07-29-2014, 03:03 PM
ACI 562M-13: Code Requirements for Evaluation, Repair, and Rehabilitation of Concrete Buildings and Commentary (Metric)
Author: ACI Committee 562 | Size: 313 KB | Format: PDF | Quality: Original preprint | Publisher: American Concrete Institute (ACI) | Year: 2013 | Pages: 59 | ISBN: 9780870318139, 0870318136
[Image: 40823251013788752157.jpg]
The ACI 562 code provides standard requirements for evaluating existing concrete buildings and then the subsequent structural repair, rehabilitation, and strengthening of those buildings.
This code provides rules for a preliminary evaluation that determines the "design basis code" that is, if the building can be repaired based on the ACI 318 version used in the original design, or if the repair needs to comply with the current ACI 318. The code provides rules for determining strength of in-situ material, performing structural analysis, designing repairs for strength and durability, requirements for stability and shoring of construction, and inspection and testing of repairs. Commentary provides application guidance as well as references for additional information.
[-] The following 25 users Like Mohammad6299's post:25 users Like Mohammad6299's post
  β€’ ssobhan, pezhmankhan, amindoxiti, zrilek, cace-01, usman, malc, Dell_Brett, araza023, knrsa, bigone, inge911, Jackass, kiskertlugas, ASEC, simanta, milova, atram, salahcivil, xdesi, f_slikken, Wijono, harsono, zego2000, spat
 Mohammad6299
User ID: 42302
Threads: 251
Given Likes: 4212
07-29-2014, 03:06 PM
The updated version of this standard is posted here:
ACI 562-13: Code Requirements for Evaluation, Repair, and Rehabilitation of Concrete Buildings and Commentary
[-] The following 3 users Like Mohammad6299's post:3 users Like Mohammad6299's post
  β€’ zrilek, malc, bigone
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
02-19-2016, 09:50 AM
Use regular forum pass.
PinkPant
[-] The following 18 users Like PinkPant's post:18 users Like PinkPant's post
  β€’ amindoxiti, Jackass, oanm2000, Wijono, faros3000, Hengki, ykhackhack, Dell_Brett, bridgeengineer, rezart, harsono, Rodmo376, David Rosa, GMianG, pedzaquino, sacem, pram, spat
Likes: 8,311 in 1,373 posts
Given Likes: 94
ACI CODE-562-21: Assessment, Repair, and Rehabilitation of Existing Concrete Structures - Code and Commentary
Author(s)/Editor(s): ACI Committee 562 | Size: 12.94 MB| Format: PDF| Quality: Scanner| Year: 2021| pages: 88
[Image: 24087184315308139448.png]
ACI CODE-562-21, β€œAssessment, Repair and Rehabilitation of Existing Concrete Structuresβ€”Code Requirements and Commentary,” was developed to provide design professionals a code for the assessment of the damage and deterioration, and the design of appropriate repair and rehabilitation strategies. The Code provides minimum requirements for assessment, repair, and rehabilitation of existing structural concrete buildings, members, systems and, where applicable, nonbuilding structures. ACI CODE-562-21 was specifically developed to work with the International Existing Building Code (IEBC) or to be adopted as a stand-alone code.
assessment; bond; corrosion; damage; durability; evaluation; existing structure; fiber-reinforced polymer (FRP); interface bond; licensed design professional; maintenance; rehabilitation; reliability; repair; strengthening.
  β€’ babakfeyzi, Umer.Aleem, PinkPant, milova
  ACI 318.2: Building Code Requirements for Concrete Thin Shells ir_71 7 6,925 12-06-2025, 11:30 AM
  [CivilEA Exclusive] ACI PRC-325.13-25: Concrete Overlays for Pavement Rehabilitation poolmand 0 932 12-06-2025, 11:03 AM
  [CivilEA Exclusive] ACI/PCI 319: Structural Precast Concrete β€”Code Requirements and Commentary poolmand 2 8,021 09-16-2025, 11:03 AM
  ACI 318: Building Code Requirements for Structural Concrete and Commentary robertsas 81 53,454 08-17-2025, 10:45 AM
  [CivilEA Exclusive] ACI 563: Repair of Concrete in Buildingsβ€”Specification poolmand 0 3,055 04-19-2025, 12:51 PM
  [CivilEA Exclusive] ACI SP-364: Serviceability and Performance Evaluation of Concrete Bridges and Structu poolmand 0 2,721 04-19-2025, 12:42 PM
  [CivilEA Exclusive] ACI 349: Code Requirements for Nuclear Safety Related Concrete Structures andersen3 5 6,322 12-15-2024, 06:33 AM
