Civil Engineering Association eBooks Journals, Papers and Presentations A new energy and momentum conserving algorithm for the non-linear dynamics of shells
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-19-2013, 05:33 PM
Author: J. C. Simo, N. Tarnow | Size: 1.27 MB | Format: PDF | Quality: Unspecified | Publisher: Wiley | Year: 1994 | pages: 23
A numerical time-integration scheme for the dynamics of non-linear elastic shells is presented that simultaneously and independent of the time-step size inherits exactly the conservation laws of total linear, total angular momentum as well as total energy. The proposed technique generalizes to non-linear shells recent work of the authors on non-linear elastodynamics and is ideally suited for long-term/large-scale simulations. The algorithm is second-order accurate and can be immediately extended with no modification to a fourth-order accurate scheme. The property of exact energy conservation induces a strong notion of non-linear numerical stability which manifests itself in actual simulations. The superior performance of the proposed scheme method relative to conventional time-integrators is demonstrated in numerical simulations exhibiting large strains coupled with a large overall rigid motion. These numerical experiments show that symplectic schemes often regarded as unconditionally stable, such as the mid-point rule, can exhibit a dramatic blow-up in finite time while the present method remains perfectly stable.
[-] The following 6 users Like asim99's post:6 users Like asim99's post
  â€¢ jcbv, kowheng, blaze, Dell_Brett, malc, Mohammad6299
  A DISPLACEMENT-BASED ADAPTIVE PUSHOVER ALGORITHM FOR ASSESSMENT OF VERTICALLY IRREGUL TAFATNEB 0 3,992 04-09-2014, 05:51 PM
  A parametric study of linear and non-linear passively damped seismic isolation system TAFATNEB 0 4,097 08-28-2013, 10:45 AM
  Spatial rainfall estimation by linear and non-linear co-kriging of radar-rainfall and arshiakh 0 4,002 04-08-2013, 06:06 PM
Last Post: arshiakh
  Dynamic stability of non-linear shells of revolution under consideration of the fluid mybest 0 3,962 06-12-2012, 02:50 PM
Last Post: mybest
  A Constant Displacement Iteration Algorithm for Nonlinear Static Push-Over Analyses Veggeta 0 4,351 11-25-2010, 07:27 PM
Last Post: Veggeta
