Civil Engineering Association eBooks Structural Books Concrete Reinforced Concrete Design to Eurocode 2
 ivanveliki
User ID: 1250
Threads: 38
Likes: 886 in 110 posts
Given Likes: 480
04-22-2009, 07:33 PM (This post was last modified: 03-18-2011, 09:56 AM by Grunf.)
[Image: 54873925729478160118.jpg]
Paperback: 434 pages
Publisher: Palgrave MacMillan; 6th edition (August 2007)
Authors
Author(s): Mosley, W.H.; Hulse, R.; Bungey, J.H.
SUMMARY
"Reinforced Concrete Design", now in its 6th edition, provides a straightforward and practical introduction to the principles and methods used in the design of reinforced and pre-stressed concrete structures. This book contains many worked examples to illustrate the various aspects of design involved. Fully revised and updated to conform to the final Eurocode 2, students and practitioners alike will find it a concise guide both to the basic theory and to design procedures. Preface - Notation - Properties of Reinforced Concrete - Limit State Design - Analysis of the Structure - Analysis of the Section - Shear, Bond and Torsion - Serviceability, Durability and Stability Requirements - Design of Reinforced Concrete Beams - Design of Reinforced Concrete Slabs - Column Design - Foundations and Retaining Walls - Pre-stressed Concrete - Composite Construction
missing pages 343&365;
[-] The following 71 users Like ivanveliki's post:71 users Like ivanveliki's post
  β€’ Dell_Brett, Dell_Brett, Administrator , Administrator , paulocs, paulocs, Dorogon, Dorogon, dizz, rendel_Β©, DamirDz, golpesar, civil, amira, cristi, drambo, storm2, Grunf, kowheng, highcivil, robertsas, novelsus, theanhpe, toa011, super_engineer, igor1234, oanm2000, engrezi, gini7998, vardan, hapsea, vedranius, jorgeramos, Nilupa, planeti_x, pm81, killerbee, Adam Smith, rkce, thebeatles, sodapas, DamaD, rezart, Trishu999, ersin, axee1980, ilgar, Petrit, sangxd80, blaze, Clouseau, cheo.smith, erthqkengnrβ„’, andersen3, musssa, yanburak, quannh, techno, zimmermannn, catacod, Quantumm, gulilero, nyilay, lisine, vvvv, paitaconst, tang1942, smrutigandh.42, bigone, harsono, bridgeengineer
Threads: 307
05-28-2010, 08:12 AM (This post was last modified: 01-03-2011, 01:55 PM by Grunf.)
Additional info:
# Paperback: 424 pages
# Publisher: Palgrave MacMillan; 6th edition (August 2007)
# ISBN-10: 0230500714
# ISBN-13: 978-0230500716
πŸ‘‰ CLICK HERE πŸ‘ˆ no pass 56 mb pdf file quality scanned @ 150 dpi
Comments on book:
Photos
There are no real life photos in this textbook.
Diagrams
There is extensive use of line diagrams in this book.
Drafting
There is no exclusive chapter on engineering drafting / drawing. However, in certain parts of the text, there is a discussion on the topic, Anchorage Bond and Curtailment of Rebars and in this chapter, the author presented the Simplified Rules for Curtailment of Bars in Beams (similar to the code of practice).
Examples
From my observation, there is at most one example for each topic discussed. For instance, when the author discussed ribbed slabs, he would then present an example on ribbed slab. When the author discussed the topic on waffle slabs, another example would follow, etc.
Beams
In chapter 7, the author presented the design and analysis of beams. Beams that require / do not require compression reinforcements are discussed. Beams that are subjected to moment redistribution are also discussed in this chapter. The designs of shear links and also bent-up bars are also presented. A section on cantilever beams and also corbels is also in this chapter. Finally, beams subjected to torsion are also discussed.
Slabs
In chapter 8, the author presented the design and analysis of slabs. The slabs that were discussed in this chapter are one-way slab, two-way slab, flat slabs, ribbed slabs, waffle slabs and hollow block floors together with an appropriate example. Punching shear analysis and design is also discussed in this chapter with an example.
There is a small section on the design of stairs in this chapter and an example of the design of a stairs spanning longitudinally is presented.
At the end of this chapter, the Yield Line & Strip Method and Hillerborg Strip Method are presented.
Foundations
The author presented with calculation examples of pad footing, combined footing, strip footing and the design of pile cap. Strap footing and raft foundations are also discussed.
If you like this publication, CivilEA's Team strongly suggest you to buy it! Support the authors!
[-] The following 24 users Like Grunf's post:24 users Like Grunf's post
  β€’ highcivil, robertsas, concreteok, chenamoy, cve_jule, toa011, ikoleci, oanm2000, ruaumoko, planeti_x, draluka, geotecnico, jorgeramos, Dell_Brett, Adam Smith, thebeatles, sodapas, rezart, erthqkengnrβ„’, musssa, Nilupa, gulilero, Clouseau, darkdkay
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
01-03-2011, 12:09 AM
[-] The following 16 users Like Dell_Brett's post:16 users Like Dell_Brett's post
  β€’ gatob, usman, thebeatles, Grunf, oanm2000, rezart, cordoba123, Padrino, Trishu999, einarmag, fashion, blaze, erthqkengnrβ„’, Nilupa, gulilero, Clouseau
Threads: 307
03-18-2011, 11:48 AM
πŸ‘‰ CLICK HERE πŸ‘ˆ Uploaded: Mar/18/2011, File Size: 51.18 MB, RAR'd single PDF (paginated, NOT searchable text)
[-] The following 20 users Like Grunf's post:20 users Like Grunf's post
  β€’ rezart, kowheng, kaci, ilgar, malc, usman, vandongvt, zrilek, Clouseau, concreteok, oanm2000, Dell_Brett, erthqkengnrβ„’, Nilupa, kmmh76, buha, kirananvekar, Jackass, nektari0s, gulilero
 foxxx2010
Lithuania
User ID: 31627
Threads: 13
Likes: 2,013 in 182 posts
Given Likes: 753
04-20-2012, 10:06 AM
[-] The following 15 users Like foxxx2010's post:15 users Like foxxx2010's post
  β€’ mkbreaker, stosto6666, kowheng, warbeast, gulilero, ssi3k, Dell_Brett, jackpotjoe, Nilupa, stigtg, gianniorlati, harsono, thebeatles, blaze, Clouseau
Threads: 154
07-06-2012, 11:26 AM
Mirror Links :
[-] The following 12 users Like shadabg's post:12 users Like shadabg's post
  β€’ SCREAM7890, Dell_Brett, versiondemo, isurya, we_mbm, cristi, malc, stigtg, Nilupa, Andrew seah, pousin, Clouseau
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
03-13-2013, 11:55 PM
6th Ed.
[-] The following 4 users Like asim99's post:4 users Like asim99's post
  β€’ Dell_Brett, malc, Nilupa, Clouseau
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
03-14-2013, 08:07 AM (This post was last modified: 03-14-2013, 08:36 AM by Dell_Brett.)
direct links; 56 MB
MODERATOR NOTE:
Removed duplicate links, non English links and not useful link
[-] The following 9 users Like ssobhan's post:9 users Like ssobhan's post
  β€’ stigtg, seriousboy, eliseo.as, albani, Nilupa, Andrew seah, subin91, Mohammad6299, Clouseau
Threads: 274
Likes: 12,075 in 1,233 posts
04-09-2013, 03:03 PM
[-] The following 7 users Like pezhmankhan's post:7 users Like pezhmankhan's post
  β€’ rezart, 3fan, gianniorlati, TurboXUser, krupp, kelin, Clouseau
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
#10
08-07-2014, 03:33 PM (This post was last modified: 08-07-2014, 03:35 PM by Mohammad6299.)
Reinforced Concrete Design to Eurocode 2, 6th Edition
[-] The following 16 users Like Mohammad6299's post:16 users Like Mohammad6299's post
  β€’ oanm2000, PinkPant, cace-01, malc, Dell_Brett, zrilek, amindoxiti, milova, promo8, agarciam2, bridgeengineer, jcbv, chenamoy, gulilero, paulocs, Clouseau
Pages (2): 1 2 Next »
  Design and Detailing of Low-Rise Reinforced Concrete Buildings Base on ACI318-14 poolmand 1 3,953 10-14-2024, 07:54 AM
  Reinforced Concrete Design sabooryan 7 8,221 04-29-2024, 05:01 AM
  Design of Reinforced Concrete Silo Groups carolinandra 2 4,505 04-25-2023, 10:31 AM
  Illustrated Design of Reinforced Concrete Buildings (Design of G+3 Storeyed Buildings poolmand 3 5,457 12-29-2022, 06:01 AM
Last Post: amaranu
  Guidelines for the Simplified Design of Structural Reinforced Concrete for Buildings killoobilloo 3 6,832 12-28-2022, 09:55 PM
  CEB: Seismic Design of reinforced concrete structures for controlled inelastic respon lamkin 8 6,626 12-26-2022, 10:50 AM
  Reinforced and prestressed Concrete Design to EC2 - The complete Process gianniorlati 3 3,629 12-20-2022, 08:37 AM
Last Post: Dell_Brett
