Civil Engineering Association eBooks Journals, Papers and Presentations SCI P129: Building Design using Cold Formed Steel Sections: Fire Protection
04-18-2011, 05:23 AM
Size: 2 MB | Format: PDF | Publisher: SCI | Year: 1993 | pages: 39 | ISBN: 1870004973
[Image: 79273584677383891843.jpg]
The fire resistance of cold formed sections is affected by the strength retention of the steel at elevated temperatures and the rate of heating of the thin steel section. Fire protection to cold formed sections may be of three forins depending on the materials used:
1. Planar protection as in floors and walls
2. Box protection
3. Profile protection.
Guidance is presented for the fire resistance of protected sections in floors or walls acting as compartment boundaries, i.e. planar protection. In this case, heat is applied from one side only and the floors or walls must satisfy the necessary insulation criterion. This guidance is based on manufacturers’ data for gypsum plasterboard and related materials.
The thickness of fire protection for conventional beams and columns is determined by using the method given in BS 5950: Part 8 for extending the existing data for hot rolled sections to cover the use of cold formed sections. Design tables are presented for typical materials and section sizes. A design summary is included at the rear of the publication which identifies the main fire protection requirements for cold formed steel sections in floors, walls and as individual beams and columns.
  β€’ kowheng, malc, maad59, blaze, vvvv, Dell_Brett, toa011, seriousboy, zrilek, pezhmankhan, monter, bigone
Threads: 49
04-08-2013, 06:42 AM
all links are dead; new link here:
  β€’ blaze, slowet, Dell_Brett
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
12-18-2013, 08:42 AM
SCI_P129 Building Design using Cold Formed Steel Sections Fire Protection_1993-1870004973.pdf
[-] The following 2 users Like bigone's post:2 users Like bigone's post
  β€’ Dell_Brett, Jackass
  Fire resistance assessment of steel structures mowafi3m 1 5,961 06-19-2015, 12:21 PM
Last Post: Dell_Brett
  Design of Cold Formed Steel Unequel Angle Compression Members darkdkay 2 7,244 10-15-2014, 10:51 PM
Last Post: KhaLed-S.E
  Strength of Embedded Steel Sections as Brackets - Alan H. Mattock and G. H. Gaafar pssst 1 5,065 10-23-2013, 02:29 PM
Last Post: deviationz
  A GUIDE TO FIRE & ACOUSTIC DATA FOR STEEL FLOOR, WALL & ROOF ASSEMBLIES ir_71 3 7,433 09-16-2013, 05:49 PM
Last Post: mowafi3m
  Dynamic Testing of Single- and Double-Story Steel-Sheathed Cold-Formed Steel-Framed S asim99 0 4,297 05-09-2013, 04:35 AM
  Column Tests of Cold-Formed Steel Non-Symmetric Lipped Angle Sections darkdkay 3 8,060 04-09-2013, 08:17 AM
  NIST: Fire Protection of Structural Steel in High-Rise Buildings ir_71 1 5,219 04-08-2013, 07:00 AM
