Civil Engineering Association eBooks Journals, Papers and Presentations Equivalent slenderness ratio for built-up members
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
04-05-2013, 03:36 AM
Author: MURRAYC . TEMPLEA ND GHADAE LMAHDY | Size: 270 KB | Format: PDF | Quality: Unspecified | Publisher: Canadian Journal of Civil Engineering | Year: 1992 | pages: 4
Built-up struts that buckle about an axis perpendicular to the plane of the connectors should be treated as a "built-up"
member as opposed to a "simple" member. This mode of buckling causes shear and moments in the connectors which
deform the connectors. These deformations increase the lateral deformation of the member and hence affect the load carrying
capacity. To account for this effect the easiest method is to use an equivalent slenderness ratio such as the
one included in the Canadian Standard. This note outlines the derivation of the equivalent slenderness ratio equation,
discusses when it should and should not be used, and includes a numerical example. A rewording of the applicable
clause in the Canadian Standard is suggested.
[-] The following 7 users Like asim99's post:7 users Like asim99's post
  • Dell_Brett, malc, ykhackhack, slowet, kowheng, tluc, Quantumm
  Buckling of built-up compression members in the plane of the connectors asim99 2 7,163 12-12-2014, 04:39 PM
Last Post: Veggeta
  Slenderness ratio of main members between interconnectors of built-up compression mem asim99 0 3,904 04-05-2013, 03:40 AM
  Design Rules of Built‐Up Members in Load and Resistance Factor Design asim99 0 4,115 04-03-2013, 04:22 PM
