Civil Engineering Association eBooks Journals, Papers and Presentations Stitch Spacing and Local Buckling in Seismic‐Resistant Double‐Angle Braces
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
04-03-2013, 04:46 PM
Author: Farhang Aslani and Subhash C. Goel | Size: 2.8 MB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1991 | pages: 22
The behavior of back-to-back double-angle bracing members subjected
to out-of-plane buckling under severe cyclic load reversals is investigated.
Eight full-size bracing members made of double angles of A36 steel with welded
stitches and end gusset plates were tested under large cyclic deformations representative
of severe earthquakes. Two types of section configuration were investigated,
which included conventional and strengthened back-to-back sections. The
first specimen was designed according to the current design practice, and the effects
of stitch spacing and width-thickness ratio were studied by changing those
parameters in subsequent specimens. The tests showed that early fracture due to
severe local buckling of the outstanding legs was the common mode of failure of
conventional back-to-back angles. Local buckling was so dominant that stitch spacing
did not play a major role. Smaller width-thickness ratio reduced the severity
of local buckling, leading to an increase in ductility and energy dissipation capacity.
Strengthening of conventional back-to-back angles by welding two inclined
plates did not improve member response because of asymmetrical buckling.
  • ssobhan, jcbv, malc, kowheng, Umer.Aleem, blaze, Dell_Brett, tluc
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,235 10-08-2014, 02:06 PM
  Constructing Seismic Resistant Masonry Houses in Indonesia RyanRS 0 4,221 07-19-2014, 04:44 AM
Last Post: RyanRS
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 1 5,494 11-28-2013, 12:06 PM
  Influence of diagonal braces in RCC multi-storied frames under wind loads: A case stu TAFATNEB 0 4,095 11-25-2013, 04:36 PM
  Experimental and analytical study of the inelastic behavior of double angle bracing m arshiakh 0 3,544 04-07-2013, 06:49 AM
Last Post: arshiakh
  Seismic design of steel structures with buckling-restrained knee braces asim99 1 5,269 04-06-2013, 06:49 PM
Last Post: arshiakh
  Cyclic Out‐of‐Plane Buckling of Double‐Angle Bracing asim99 0 3,877 04-03-2013, 04:44 PM
