Civil Engineering Association eBooks Journals, Papers and Presentations Design Rules of Built‐Up Members in Load and Resistance Factor Design
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
04-03-2013, 04:22 PM (This post was last modified: 04-03-2013, 04:30 PM by asim99.)
Author: Lian Duan and Wai-Fah Chen | Size: 680 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1988 | pages: 11
The AISC-LRFD (American Institute of Steel Construction-Load and
Resistance Factor Design Specification for Structural Steel Buildings) Specification
provides rules for design of built-up members. The slenderness ratios of built-up
members that may buckle out-of-plane, say, about the Y-Y axis for a two-back-toback-
angle member are discussed. Based on the LRFD equation (E4-1) and the
usual concept of the effective length factor, a modification of the slenderness ratios
(Kl/r)m for built-up members as given in the present LRFD Specification is proposed.
The proposed formula with local effective length factor Km is concise, simple,
and physically clear. It is consistent with the effective length factor recommended
by the LRFD Specification, and has only one equation considering the
effects of shear and connectors on buckling of built-up members. The calculated
results of the proposed formula are found to be in good agreement with available
test results.
  • Dell_Brett, Quantumm, usman, jcbv, malc, kowheng, ykhackhack, bigone
  NIST: Best Practice Guidelines for Structural Fire Resistance Design of Concrete and ir_71 2 8,069 03-19-2017, 09:43 PM
Last Post: Dell_Brett
  Buckling of built-up compression members in the plane of the connectors asim99 2 7,265 12-12-2014, 04:39 PM
Last Post: Veggeta
  Design of Cold Formed Steel Unequel Angle Compression Members darkdkay 2 7,185 10-15-2014, 10:51 PM
Last Post: KhaLed-S.E
  Slenderness ratio of main members between interconnectors of built-up compression mem asim99 0 3,953 04-05-2013, 03:40 AM
  Equivalent slenderness ratio for built-up members asim99 0 4,173 04-05-2013, 03:36 AM
  An Alternate Method for Design of Reinf. Concr. Flex. Members odiclas 0 3,865 06-27-2011, 03:49 PM
Last Post: odiclas
  Stress Intensity Factor and Limit Load Handbook ir_71 0 4,014 05-30-2011, 05:47 AM
