Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] AISC Papers
[Request] AISC Papers
 devilmaycry
User ID: 27027
Threads: 54
Likes: 232 in 63 posts
Given Likes: 460
03-16-2013, 09:29 AM (This post was last modified: 03-16-2013, 09:36 AM by Dell_Brett.)
  • Article/eBook Full Name: Simple Nonlinear Static Analysis Procedure for Progressive Collapse Evaluation
  • Author(s): Wenjun Guo and Ramon Gilsanz
  • Published By: AISC
  • Related Links:
  • Article/eBook Full Name: Progressive Collapse Analyses of 2D Steel Framed Structures with Different Connection Models
  • Author(s): Lim, Joonhong; Krauthammar, Theodor
  • Related Links:
[-] The following 1 user Likes devilmaycry's post:1 user Likes devilmaycry's post
  â€¢ PSMUSACALA
 apocalipse
Portugal
User ID: 41527
Threads: 65
Likes: 790 in 87 posts
Given Likes: 922
04-03-2013, 03:27 PM
Dear members,
I am looking for the following paper:
Analytical Criteria for Stitch Strength of Built-Up Compression Members
Authors:
Aslani, Farhang; Goel, Subhash C.
Abstract:
In the buckled configuration of a built-up compression member, shear force is developed between individual components due to secondary moments caused by P-deffect. AISC-ASD1 requires that stitches be designed such that they have adequate strength to resist the shear force developed between individual components. AISC-LRFD2 also has a similar requirement (see Section E4, p. 6-40). However, neither specification gives a procedure to calculate the shear force developed between individual components in a buckled configuration. This paper presents a derivation of analytical equations to calculate the shear force developed between individual components of built-up struts in buckled configuration. The equations are presented for two cases. First, for the case in which only the first buckling load is of interest. Second, for the case in which, in addition to the first buckling load, post-buckling bending is involved such as in seismic-resistant design. The proposed equations are general enough so that they are applicable to any end condition including the two extreme cases of hinged-and fixed-end conditions. The proposed equations are verified analytically and experimentally. For analytical verification, the results from the proposed equations are examined for the extreme cases of end conditions and separation between the components. For experimental verification, test results by the authors are used.3,4 The stitch strength required for some test specimens are calculated according to the proposed equations. The results are compared with actual strength provided by the stitch welds of the corresponding specimens. It was found that specimens which suffered unsymmetrical buckling and/or post-buckling behavior did not have adequate stitch strength according to the proposed equations.
regards,
apocalipse
  â€¢
  [REQUEST] AISC papers devilmaycry 47 23,375 09-13-2016, 05:05 PM
Last Post: spiritmedal
