Civil Engineering Association eBooks Journals, Papers and Presentations Fatigue analysis of roof cladding under simulated wind loading
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
03-31-2013, 04:31 PM
Author: K. Suresh Kumar, T. Stathopoulos | Size: 245 KB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 1998 | pages: 13
Several damage mitigation studies have concluded that wind-induced fatigue may be responsible
for the extensive damage to roof cladding. This paper presents the application of the
recently proposed novel simulation methodology, capable of generating both Gaussian and
non-Gaussian wind pressure ßuctuations, in the fatigue analysis of roof cladding. After establishing
the simulated fatigue characteristics of roof pressures, the total fatigue loading has been
estimated by integrating the long-term wind climate with the simulated fatigue characteristics of
roof pressures. Simulated results are compared with predictions made by Rayleigh, Gaussian
and Weibull models as well as German and British recommendations. The study indicates that
non-normality can signiÞcantly increase the rate of fatigue damage accumulation, and, if
neglected, it can result in non-conservative fatigue life estimates
[-] The following 4 users Like asim99's post:4 users Like asim99's post
  • malc, sodapas, kowheng, slowet
  Long-term fatigue analysis of multi-planar tubular joints for jacket-type offshore wi TAFATNEB 1 6,143 06-19-2016, 12:48 AM
Last Post: englandboy
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,128 10-21-2014, 08:57 AM
Last Post: Munykong
  Loading Pattern and Spatial Distribution of Dynamic Wind Load and Comparison of Wind TAFATNEB 0 4,623 09-05-2014, 01:40 PM
  [ASCE] Buckling Analysis of a Long‐Span Roof Structure Collapsed during Construction mybest 1 6,177 04-08-2014, 11:35 AM
Last Post: Mohammad6299
  Simulated earthquake motions compatible with prescribed response spectra kowheng 2 8,545 02-23-2014, 07:38 PM
Last Post: highcivil
  Dynamic Behaviour under Wind Loading of a 90 m Steel Chimney asim99 1 5,614 07-30-2013, 03:16 PM
Last Post: Dell_Brett
  Wind pressures and buckling of cylindrical steel tanks with a conical roof asim99 0 4,014 04-02-2013, 11:42 PM
