Civil Engineering Association Software Software Product Bentley Products Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial)
Threads: 1,118
03-30-2013, 05:20 AM
[Image: 40939378652672708495.gif]
STAAD.Pro is a general purpose structural analysis and design program with applications primarily in the building industry - commercial buildings, bridges and highway structures, industrial structures, chemical plant structures, dams, retaining walls, turbine foundations, culverts and other embedded structures, etc. The program hence consists of the following facilities to enable this task.
Graphical model generation utilities as well as text editor based commands for creating the mathematical model. Beam and column members are represented using lines. Walls, slabs and panel type entities are represented using triangular and quadrilateral finite elements. Solid blocks are represented using brick elements. These utilities allow you to create the geometry, assign properties, orient cross sections as desired, assign materials like steel, concrete, timber, aluminum, specify supports, apply loads explicitly as well as have the program generate loads, design parameters etc.
Analysis engines for performing linear elastic and pdelta analysis, finite element analysis, frequency extraction, and dynamic response (spectrum, time history, steady state, etc.).
Design engines for code checking and optimization of steel, aluminum and timber members. Reinforcement calculations for concrete beams, columns, slabs and shear walls. Design of shear and moment connections for steel members.
Result viewing, result verification and report generation tools for examining displacement diagrams, bending moment and shear force diagrams, beam, plate and solid stress contours, etc.
Peripheral tools for activities like import and export of data from and to other widely accepted formats, links with other popular softwares for niche areas like reinforced and prestressed concrete slab design, footing design, steel connection design, etc.
A library of exposed functions called OpenSTAAD which allows you to access STAAD.Pro’s internal functions and routines as well as its graphical commands to tap into STAAD’s database and link input and output data to third-party software written using languages like C, C++, VB, VBA, FORTRAN, Java, Delphi, etc. Thus, OpenSTAAD can be used to link in-house or third-party applications with STAAD.Pro.
Includes Staad Foundation 05.03.00.32
[Image: tips.png]
Of course for VIP Struceng crack works.
[-] The following 35 users Like BennyP's post:35 users Like BennyP's post
  β€’ milvio, ennson, Dell_Brett, alilo, aslam, oanm2000, jokerβ„’, bigone, amareen2000, nanban, rendel_Β©, jakng, Williams, malc, cace-01, subin91, zrilek, ykhackhack, karthikeyans3d, nickycruz, vardan, Limpias72, er.shyams, devilmaycry, vvvv, grgr, lednar_ved, tolesa54, nibbi, jacky899, jaks, rezart, mibaksh, harsono, julioreptil
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
08-15-2013, 10:07 PM
No limits to creativity
[-] The following 48 users Like jokerβ„’'s post:48 users Like jokerβ„’'s post
  β€’ Williams, malc, pingfan2, asim99, maad59, pezhmankhan, ajaymr, chandra1234567, milvio, cace-01, subin91, kirankumarklk, raja, Rainbow, solidslither001, oanm2000, Diquan, zrilek, ykhackhack, araza023, seriousboy, karthikeyans3d, uncblue, hatkam, amareen2000, freemini, nickycruz, alilo, Dell_Brett, vardan, verongskey, taifur, Limpias72, psppsp, ASEC, er.shyams, eliseo.as, vvvv, piyush86, lednar_ved, urdanetanp, bigone, chottabhai, awgawhtoo80, jaks, narendra, mibaksh, harsono
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
08-19-2013, 04:55 PM
patched some files of SectionWizard, only remplace the files
[-] The following 26 users Like jokerβ„’'s post:26 users Like jokerβ„’'s post
  β€’ Rainbow, karthikeyans3d, cace-01, Dell_Brett, malc, mahyarov, verongskey, Andrew seah, taifur, Limpias72, psppsp, araza023, eliseo.as, zrilek, devilmaycry, vvvv, piyush86, grgr, lednar_ved, urdanetanp, bigone, awgawhtoo80, jaks, mibaksh, julioreptil, harsono
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
09-09-2013, 04:40 AM
Staad Pro V8i ( Select Series 4 ) 20.07.09.31
[Image: 31916663129946946066.jpg]
New Crack. SteadyState Analysis in Staad is working.
Some Other Bentley Products can be activated with this patch. See the Image
[Image: tips.png]
For instructions see READ for STAAD.Pro.txt file
[-] The following 28 users Like asim99's post:28 users Like asim99's post
  β€’ pezhmankhan, alilo, verongskey, malc, ykhackhack, jokerβ„’, Dell_Brett, araza023, ASEC, zrilek, ssobhan, Williams, wksaw73, taifur, Rainbow, bigone, Andrew seah, varmap, wanwin, subin91, ranger, Diquan, nibbi, terrorruban, jaks, narendra, mibaksh, julioreptil
Threads: 274
Likes: 12,075 in 1,233 posts
09-09-2013, 05:23 AM (This post was last modified: 09-09-2013, 05:23 AM by pezhmankhan.)
Mirror for New Medicine (Post #4)
[-] The following 12 users Like pezhmankhan's post:12 users Like pezhmankhan's post
  β€’ alilo, Rainbow, zrilek, Williams, eliseo.as, taifur, bigone, varmap, subin91, jacky899, nickycruz, julioreptil
  Bentley STAAD.Pro Advanced 2024 poolmand 0 5,733 09-15-2024, 06:01 AM
  Bentley STAAD.Pro CONNECT V23 poolmand 0 6,381 10-02-2023, 09:01 AM
  STAAD.Pro V8i SELECTseries 5, build 20.07.10.64 coxxxyboy 9 28,743 07-07-2023, 02:35 AM
Last Post: Arigato
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 23,101 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley gINT Pro Plus V8i (SELECTSeries 1) 08.30.03.223 cace-01 4 13,624 07-03-2023, 05:23 PM
Last Post: OSHO
  Bentley.STAAD.PlanWin.V8i.v14.0.5 kirankumarklk 0 5,304 05-08-2018, 12:30 PM
Last Post: kirankumarklk
  Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.70 RajaK 5 18,374 12-31-2017, 06:07 AM
Last Post: reagan_liu
