Manual for Quality Control for Plants and Production of Glass Fiber Reinforced Concrete Products
Size: 1.6 MB | Format: PDF | Quality: Original preprint | Publisher: PCI | Year: 2009 | pages: 183 | ISBN: 0-937040-82-7
This manual has been prepared as a guideline for the manufacture of glass fiber reinforced concrete.
Note: MNL-130-10 will be effective for all GFRC (Group and Category G) PCI Plant Certification audits after July 1, 2010.
N4: Extracts from Codes and Standards, State of the Art Report
Size: 10.2 MB | Format: PDF | Quality: Original preprint | Publisher: PCI | Year: 1999 | pages: 47 | ISBN: 2-88394-044-4
Category: Guide (part 1), technical report (part 2) and state-of-the-art report (part 3)
Year: 2000
As a background for an extension of the CEB/FIP Model Code 1990 (MC 90) it delivered firstly Bulletin 4. Similarly to what has been done before in the field of High Strength / High Performance Concrete the present guide identifies the lacunae in the existing MC90 and proposes supplementary or alternative solutions to be applied for lightweight aggregate concretes. The technical report identifies the research needs resulting from those clauses of MC 90 which need amendment, and for which more basic research should provide a better understanding of mechanical, physical and chemical processes. The state-of-art report documents 33 application examples of projects world-wide.
N5: Protective Systems Againts Hazards-Nature and Extent of the Problem-Technical report
Size: 3.8 MB | Format: PDF | Quality: Original preprint | Publisher: PCI | Year: 1999 | pages: 60 | ISBN: 2-88394-045-2
This report is the first of an intended series of three reports on structural protective systems against hazards.
N6: Special Design Considerations for Precast Hollow Core Floors-Guide to good pracrtice
Size: 7.0 MB | Format: PDF | Quality: Original preprint | Publisher: PCI | Year: 2000 | pages: 176 | ISBN: 2-88394-046-0
Special design considerations for precast prestressed hollow core floors. Guide to good practice
