Civil Engineering Association eBooks Structural Books Concrete Reinforced Concrete Structures Corrosion Monitoring
 timosi™
User ID: 3890
Threads: 138
Likes: 5,532 in 394 posts
Given Likes: 1812
09-24-2009, 01:56 AM (This post was last modified: 09-24-2009, 01:58 AM by timosi™.)
File 1:This paper reviews all the electrochemical and nondestructive techniques from the point of view of corrosion assessment and their applications to bridges,buildings and other civil engineering structures.Reinforced concrete structures have the potential to be very durable and capable of withstanding a variety of adverse environmental conditions.
[Image: o9e49wo9mfwh18ffych.png]
File 2:In this paper the protection of reinforcing steel in new and existing reinforced
concrete structures by using migration corrosion inhibitors (MCI) and corrosion protective materials (CM) which contain MCI is discussed. The composition and criteria of quality for products and systems for protection and repair of new and existing reinforced concrete structures is discussed too.It is also described the procedure of the restoration with the MCI-inhibitors and materials contended this inhibitors of the reinforced concrete structures of the module no.3 on the
wharf mo. 5 in the harbour Ploče.
protection and repair of reinforced concrete stuctures
[Image: 25yuedijq52lun2yrrbd.png]
Download Links:
[-] The following 3 users Like timosi™'s post:3 users Like timosi™'s post
  • zrilek, zrilek, Nilupa
  CEB: Seismic Design of reinforced concrete structures for controlled inelastic respon lamkin 8 6,473 12-26-2022, 10:50 AM
  Corrosion of Steel In Concrete: Understanding, investigation and repair Grunf 12 8,964 12-25-2022, 10:10 PM
Last Post: carolinandra
  Reinforced Concrete Structures: Analysis and Design ska51 6 6,470 11-07-2022, 11:56 AM
Last Post: haniakkari
  Corrosion and Protection of Reinforced Concrete carolinandra 0 1,671 06-12-2021, 01:49 PM
  Durability of Reinforced Concrete Structures Dobblo 0 1,665 04-13-2020, 04:38 PM
Last Post: Dobblo
  Design Guide for Economical Reinforced Concrete Structures 2016 A guide to assist des sabooryan 1 2,294 01-11-2020, 08:53 AM
  Steel Corrosion in Concrete: Fundamentals and Civil Engineering Practice asim99 1 2,457 10-01-2019, 08:43 AM
