Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 12859:2011 Gypsum blocks - Definitions, requirements and test methods
10-22-2011, 08:54 AM
Author: CEN/TC 241 | Size: 0.74 MB | Format: PDF | Publisher: CEN | Year: 2011 | pages: 37
[Image: 99975734934317287524.jpg]
This European Standard specifies the characteristics and performance of gypsum blocks with smooth faces for which the main intended uses are construction of non-load bearing partitions or independent wall linings and the fire protection of columns, lift shafts, shafts for services, etc. Gypsum blocks are not used to build ceilings.
It covers the following performance characteristics related to the essential requirements:
- reaction to fire;
- resistance to fire;
- direct airborne sound insulation;
- release of dangerous substances;
to be measured according to the corresponding European test methods, as well as:
- thermal resistance
to be calculated from the thermal conductivity values given in 4.3.2.
It describes the reference tests for technical specifications.
This European Standard covers also additional technical characteristics that are of importance for the use and
acceptance of the product by the construction industry:
- convenience classes for density;
- convenience classes for pH.
It provides for the evaluation of conformity of the product to this European Standard. This European Standard does not cover gypsum blocks of thickness less than 50 mm or gypsum storey height units.
  â€¢ Dell_Brett, kowheng, datagap, blaze, Grunf, zrilek, Jackass, asim99, peixoto
Threads: 49
03-12-2013, 02:00 PM
all links dead; reposted here:
password:
  â€¢ blaze, asim99, Dell_Brett, 3fan, peixoto
12-27-2014, 05:30 PM
  â€¢ Jackass, knrsa, Dell_Brett, PinkPant, hodzicemir
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
12-27-2014, 10:34 PM
Use official pasword
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 1 user Likes Veggeta's post:1 user Likes Veggeta's post
  â€¢ PinkPant
  ISO 22762-1: Elastomeric seismic-protection isolators Part 1: Test methods poolmand 0 2,956 11-16-2024, 01:18 PM
  BS 6717:2001 Precast, unreinforced concrete paving blocks — Req and test meth ir_71 2 3,085 07-22-2019, 06:55 AM
Last Post: concreteok
  BS EN 14411:2006 Ceramic tiles — Definitions, classification, characteristics and mar ir_71 1 2,926 05-11-2019, 08:38 AM
  BS EN 1340/AC:2006 Concrete kerb units - Requirements and test methods ir_71 2 3,145 07-22-2017, 07:41 AM
  BS EN 1338:2003 Concrete paving blocks. Requirements and test methods mybest 5 4,749 02-28-2016, 12:56 PM
  BS EN 196-5:2011 Methods of testing cement Part 5: Pozzolanicity test for pozzolanic ir_71 1 2,286 04-14-2015, 05:03 PM
Last Post: Veggeta
  BS 1377 PARTS 1 TO 9 : 1990 - Methods of Test for Soils for Civil Engineering Purpose Gabemzaman 5 7,203 01-24-2014, 06:02 PM
Last Post: jacs1976
