Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Seismic Design and Assessment of Bridges: Inelastic Methods of Analysis and Case Stud
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
03-11-2013, 04:03 AM (This post was last modified: 03-11-2013, 04:07 AM by asim99.)
Seismic Design and Assessment of Bridges: Inelastic Methods of Analysis and Case Studies
Author: Andreas J Kappos, M. Saiid Saiidi, M. Nuray Aydinoglu, Tatjana Isakovic | Size: 5.9 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 2012 | pages: 233 | ISBN: 9789400739420
[Image: 34604048983306475128.jpg]
The book focuses on the use of inelastic analysis methods for the seismic assessment and design of bridges, for which the work carried out so far, albeit interesting and useful, is nevertheless clearly less than that for buildings. Although some valuable literature on the subject is currently available, the most advanced inelastic analysis methods that emerged during the last decade are currently found only in the specialised research-oriented literature, such as technical journals and conference proceedings. Hence the key objective of this book is two-fold, first to present all important methods belonging to the aforementioned category in a uniform and sufficient for their understanding and implementation length, and to provide also a critical perspective on them by including selected case-studies wherein more than one methods are applied to a specific bridge and by offering some critical comments on the limitations of the individual methods and on their relative efficiency. The book should be a valuable tool for both researchers and practicing engineers dealing with seismic design and assessment of bridges, by both making the methods and the analytical tools available for their implementation, and by assisting them to select the method that best suits the individual bridge projects that each engineer and/or researcher faces.
[-] The following 12 users Like asim99's post:12 users Like asim99's post
  • usman, kowheng, pezhmankhan, aslam, ssobhan, Dell_Brett, lisine, cordoba123, gulilero, miquan, Grunf, peixoto
 rami1976
User ID: 34597
Threads: 341
Likes: 9,524 in 1,138 posts
Given Likes: 1388
03-09-2017, 03:36 PM
for uploadboy link only
  • amindoxiti, cace-01, gulilero, Dell_Brett, oanm2000
  Inspection, Evaluation and Maintenance of Suspension Bridges Case Studies RyanRS 3 2,748 10-01-2018, 04:51 PM
Last Post: febo927
  Bridges: Analysis, Design, Structural Health Monitoring, and Rehabilitation, 2 editio ibg0203 3 2,729 07-05-2018, 04:51 AM
Last Post: axcel
  Analysis and Design of Bridges febo927 0 1,731 07-04-2018, 12:09 PM
Last Post: febo927
  Bridge Engineering: Classifications, Design Loading, and Analysis Methods pezhmankhan 0 2,047 06-25-2018, 06:15 AM
Last Post: pezhmankhan
  Failed Bridges: Case Studies, Causes and Consequences hich 4 4,164 12-10-2015, 04:40 PM
Last Post: bridgeengineer
  Seismic Design Aids for Nonlinear Pushover Analysis of Reinforced Concrete and Steel lamkin 12 8,586 11-23-2015, 03:22 PM
Last Post: ibg0203
  Computer Aided Analysis and Design of Bridges & Flyovers melekeen 2 2,897 11-21-2014, 09:17 AM
