Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Study on Reinforced Concrete Frame with Solid Infill Masonry using Artificial Neural
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
03-04-2013, 04:31 PM
Study on Reinforced Concrete Frame with Solid Infill Masonry using Artificial Neural Network (ANN) RC Infill Wall Model in ANSYS (Ajay Gupta)
Author: Er Ajay Gupta | Size: 2 MB | Format: PDF | Quality: Unspecified | Publisher: TRIBHUVAN UNIVERSITY | Year: 2011 | pages: 82
[Image: 59912334584745246559.jpg]
Despite being the most common construction practice throughout the ages, infills have not found the space it deserves, in the structural design. There is lack of proper and easy method to consider the effect of the in-filled. So, this research is a small effort in the search of the alternative approach for analyzing the infill frames. The FEM Models are normally incapable of considering all the effecting factors such as
non-linear behavior of the infill materials, lack of fit, non-homogeneity of the materials, etc. This research gives some idea to the structural engineer how to guess initially the parameters of interest during the design of infills. Structural design process is an iterative process and an approximate initial guess can reduce the time and cost involved in the analysis. The tentative design parameters can be predicted using the Artificial Intelligence and this computing power of the modern day computers has been used to fulfill the intended purpose. The data sets, which are generated by computer from the simulation of the infill-frame structure done in sophisticated software (ANSYS v10.0) capable of non-linear analysis, are used for the training of Neural Network. Few other unique data sets are taken for the validation of the Network trained. The comparison of the results from the ANN and that of software were in reasonable agreement with each other except in few rare cases.
[-] The following 8 users Like arshiakh's post:8 users Like arshiakh's post
  â€¢ blaze, ssobhan, ykhackhack, tluc, Jackass, sodapas, tanos79, rezart
  A Study of the Progressive Degradation of Masonry Shear Walls Subjected to Harmonic L TAFATNEB 0 1,858 06-04-2014, 12:00 AM
  INFLUENCE OF MASONRY INFILL WALLS AND OTHER B UILDING CHARACTERISTICS ON SEIS MIC COL TAFATNEB 0 1,739 04-26-2014, 11:46 AM
  An analytical study of reinforced concrete beam-column joint behavior under seismic l TAFATNEB 0 1,931 04-19-2014, 08:58 AM
  A model for the non linear dynamic analysis of reinforced concrete and masonry framed TAFATNEB 0 1,854 04-02-2014, 12:42 PM
  A STUDY ON SEISMIC BEHAVIOUR OF MASONRY TOWERS TAFATNEB 1 2,313 11-20-2013, 01:54 PM
  Behavior and Vulnerability of Reinforced Masonry Shear Walls TAFATNEB 0 1,900 11-02-2013, 10:54 AM
