Civil Engineering Association eBooks Structural Books Steel SCI P180: Integral Steel Bridges - Design of a Single-span Bridge - Worked Example
04-15-2011, 05:14 AM
Author: J A WAY, E YANDZIO | Size: 0.95 MB | Format: PDF | Publisher: SCI | Year: 1997 | pages: 91 | ISBN: 1859420567
[Image: 38317988078433938242.jpg]
This publication provides a Worked Example for the design of a single-span fully integral bridge, that utilises High Modulus Pile abutments and a composite plate girder deck. It has been based on the findings of studies undertaken on steel integral bridges and steel substructures by The Steel Construction Institute since 1993.
Calculations are provided for each design stage, together with a detailed commentary explaining the background to the methods employed and the parameters chosen. Computer-based numerical techniques have been used to enable full soil-structure interaction to be considered in the analysis. A design is proposed for a reinforced concrete capping beam to provide a full moment connection between the High Modulus Piles and the deck.
[-] The following 30 users Like ir_71's post:30 users Like ir_71's post
  â€¢ kowheng, melkat, blaze, Grunf, vvvv, LadaHitam, jcbv, narendra, seriousboy, almadar12, Dell_Brett, carolinandra, toa011, oanm2000, malc, miquan, sheb101, zrilek, subin91, cristi, Nilupa, sodapas, baikur, mecheil.edwar, kmmh76, tang1942, rigid_joint, warbeast, peixoto, bigone
Threads: 49
11-16-2012, 09:53 AM
all links dead; mirror
password
[-] The following 12 users Like andersen3's post:12 users Like andersen3's post
  â€¢ Jackass, rusty, blaze, Dell_Brett, hignacio43, Quantumm, rigid_joint, KhaLed-S.E, davegabj, marion33, slowet, bigone
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
03-02-2013, 01:40 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 6 users Like arshiakh's post:6 users Like arshiakh's post
  â€¢ blaze, malc, peixoto, thesmileindark, bigone, Pinkto
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 2,057 05-13-2016, 12:35 PM
Last Post: Dobblo
  Steel Building Design: Worked examples for students rami1976 0 2,025 11-12-2015, 10:39 PM
  STEEL BRIDGES bigone 1 2,497 03-19-2015, 10:25 PM
Last Post: Veggeta
  Steel Bridges Fabrication mowafi3m 2 2,729 12-18-2013, 09:13 AM
  Steel Building Design: Worked Examples – Open Sections (SCI P364) jamildear4u 5 4,883 12-17-2013, 02:04 PM
  SCI P376 - Steel Building Design: Worked Examples for Students jamildear4u 3 2,806 10-13-2013, 08:38 AM
Last Post: vinnunsam
  Steel Truss 40 m Span - Solved Example mowafi3m 0 2,185 04-18-2013, 09:14 PM
Last Post: mowafi3m
