Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 6644:2011 Specification for the installation and maintenance of gas-fired hot wate
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
12-11-2011, 10:31 AM
BS 6644:2011 Specification for the installation and maintenance of gas-fired hot water boilers of rated inputs between 70 kW (net) and 1.8 MW (net) (2nd and 3rd family gases)
Size: 1 MB | Format: PDF | Year: 30 November 2011 | pages: 66 | ISBN: 978 0 580 71928 8
[Image: 96713583601757487506.png]
BS 6644:2011 specifies requirements for the installation, including design, inspection, commissioning and maintenance, of gas-fired hot water boilers of net rated heat inputs exceeding 70 kW but not exceeding a net heat input of 1.8 MW. Groups of boilers with individual net heat inputs of 70 kW or less, but with aggregate net heat inputs in excess of 70 kW, are also covered.
BS 6644:2011 is applicable to the installation of boilers that are designed to utilize normally distributed gases of Group H of the second family (e.g. natural gas), and gases of Group P (e.g. propane) and Group B (e.g. butane) of the third family. For the purposes of this installation standard, LPG/air mixtures are regarded as third family gases.
This British Standard is applicable to the installation of the following gas-fired hot water boilers:
Boilers supplied as a complete assembly and conforming to BS EN 656 or
BS 5978 (all parts)
Boilers supplied as a complete assembly and used in multiple boiler installations where the total net heat input exceeds 70 kW and conforming to BS EN 297, BS EN 483 or BS EN 677
Boilers and burners delivered separately and assembled on site, comprising:
- a boiler shell conforming to BS EN 303-1, BS EN 12952 (all parts),
BS EN 12953 (all parts), BS 779, BS 855 or BS 2790
- a burner conforming to BS EN 676
- an assembly conforming to BS EN 303-3 or BS 5987-1 and BS 5978-3.
This is a full revision of the standard and introduces the following principal changes:
System requirements in accordance with BS EN 12828 have been added
Details on condensing appliances and condensate removal have been added
The appliance classification types have been updated.
Contents for BS 6644:2011 includes:
Scope
Normative references
Terms and definitions
Competence and design considerations
Selection of boiler, materials and components
Installation
Inspection, commissioning and servicing
[-] The following 8 users Like mybest's post:8 users Like mybest's post
  â€¢ kowheng, Dell_Brett, vpmohammed, Jackass, malc, peixoto, araza023, kvtasp
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
12-24-2011, 06:02 PM
  â€¢
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
02-26-2013, 07:02 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 1 user Likes arshiakh's post:1 user Likes arshiakh's post
  â€¢ Dell_Brett
  BS 8888:2011 Technical product documentation and specification ir_71 1 2,554 10-27-2013, 09:56 AM
Last Post: bitsripper
  BS 6173:2009 Specification for installation and maintenance of gas-fired mybest 2 2,820 02-26-2013, 07:13 AM
Last Post: arshiakh
  BS 6798:2009 Specification for installation and maintenance of gas-fired boilers of r mybest 2 2,952 02-26-2013, 07:10 AM
Last Post: arshiakh
  BS 6700:2006 Design, installation, testing and maintenance of services supplying wate ir_71 1 3,146 09-25-2012, 05:02 AM
