Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Reports and Photos from "nisee.berkeley.edu"
[Request] Reports and Photos from "nisee.berkeley.edu"
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#121
02-17-2013, 10:05 PM
Hi friends
Please anybody can share these documents;
Local inelastic collapse of pressurised thin cylindrical steel shells under axial compression
Stress amplification in unstiffened steel silos and tanks
thanks
  â€¢
 atram
User ID: 34120
Threads: 29
Likes: 236 in 48 posts
Given Likes: 436
#122
02-19-2013, 01:18 PM
here you are:
[-] The following 3 users Like atram's post:3 users Like atram's post
  â€¢ ssobhan, malc, Dell_Brett
 ssobhan
User ID: 1054
Threads: 224
Given Likes: 2465
#123
02-20-2013, 02:24 PM
Dear friends
Please somebody can share this material;
The state of the art in infilled frames
thanks in advance
  â€¢
 arshiakh
User ID: 37777
Threads: 97
Likes: 3,224 in 617 posts
Given Likes: 214
#124
02-20-2013, 05:23 PM (This post was last modified: 02-20-2013, 06:11 PM by usman.)
Please share these documents:
Title: State-of-the-art review of highway bridge columns retrofitted with FRP jackets
Creator(s): Lan, Yi M.; Sotelino, Elisa D.; Chen, Wai F.
Date: 1998
Title: Seismic performance of RC columns strengthened with Dyneema fiber-reinforced polymer sheets
Creator(s): Wu, Zhishen S.; Gu, D. S.; Wu, G.; Hirahata, H.
Date: 2006
Title: Determination of defect criticality and the resulting performance effects of CFRP strengthened RC beams
Creator(s): Delaney, Jason C.; Karbhari, Vistasp M.
Date: [2005]
  â€¢
 atram
User ID: 34120
Threads: 29
Given Likes: 436
#125
02-21-2013, 08:01 AM
The state of the art in infilled frames:
[-] The following 5 users Like atram's post:5 users Like atram's post
  â€¢ Dell_Brett, ssobhan, arshiakh, malc, tluc
Threads: 274
Likes: 12,075 in 1,233 posts
03-20-2013, 12:59 PM
Dear Friends,
I need these reports:
Performance of seismic isolation hardware under service and seismic loading:
A study of the coupled horizontal-vertical behavior of elastomeric and lead-rubber seismic isolation bearings:
Experimental study of seismic isolation systems with emphasis on secondary system response and verification of accuracy of dynamic response history analysis methods:
  â€¢
 arshiakh
User ID: 37777
Threads: 97
Given Likes: 214
#127
03-27-2013, 09:41 AM (This post was last modified: 03-27-2013, 09:44 AM by arshiakh.)
This report is here.
Best regards
[-] The following 2 users Like arshiakh's post:2 users Like arshiakh's post
  â€¢ pezhmankhan, ssobhan
 apocalipse
Portugal
User ID: 41527
Threads: 65
Likes: 790 in 87 posts
Given Likes: 922
#128
04-06-2013, 08:57 PM (This post was last modified: 04-06-2013, 08:57 PM by apocalipse.)
Dear members,
I need this report:
Experimental and analytical study of the inelastic behavior of double angle bracing members under severe cyclic loading
Aslani, Farhang; Goel, Subhash C.
UMCE 89-5, Ann Arbor, Mich. : Department of Civil Engineering, University of Michigan, 1989-02, PDF (41 MB) (515/A84/1989)
Seventeen full-scale bracing members made of double angles in A36 steel with welded stitches and end gusset plates were tested under large cyclic deformations representative of severe earthquakes. Three types of section configuration, conventional back-to-back, strengthened back-to-back, and boxed section configuration, were investigated. Early fracture due to local buckling is the common mode of failure of conventional back-to-back angles. Strengthening of conventional back-to-back angles by welding two inclined plates does not improve member response due to unsymmetric buckling.
regards,
apocalipse
  â€¢
 arshiakh
User ID: 37777
Threads: 97
Given Likes: 214
#129
04-07-2013, 06:50 AM
[-] The following 1 user Likes arshiakh's post:1 user Likes arshiakh's post
  â€¢ apocalipse
 p_vosoughi
User ID: 1111
Threads: 2
Likes: 11 in 4 posts
Given Likes: 39
#130
04-07-2013, 12:31 PM
Dear friends,
It would be very appreciated if anybody can share this report.
An experimental study of the behavior of dual steel systems
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
thanks in advance
  â€¢
Pages (23): « Previous 1 … 8 9 10 11 12 13 14 15 16 17 18 … 23 Next »
  [REQUEST] Some useful seismic reports miquan 4 3,933 07-14-2015, 01:58 PM
Last Post: atram
