Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 5531:1988 Code of practice for Safety in erecting structural frames
02-21-2011, 05:56 AM (This post was last modified: 02-21-2011, 09:32 AM by Dell_Brett.)
Author: Technical Committee CSB/42 | Size: 1.06 MB | Format: PDF | Publisher: BSI | Year: 1988 | pages: 44 | ISBN: 0580165477
[Image: 22323120685901192864.jpg]
This code of practice makes recommendations concerning safety in erecting the principal types of structural frames, mainly in precast concrete and steel. Consideration is also given to the following:
a) space frameworks
b) timber frameworks
c) aluminium frameworks
d) plastics frameworks
This code does not include recommendations on work involved in the erection of in situ concrete frames (see BS 5975).
This code does not deal with those aspects of site safety which are generally applicable to all construction operations and for which guidance and information are readily available elsewhere (e.g. use of hand tools, ladders, etc.).
NOTE The titles of the publications referred to in this standard are listed on the inside back cover.
  â€¢ dbsimon29, kowheng, jcbv, usman, Dell_Brett, toa011, oanm2000, roaming79, Grunf, zrilek, ziggywas1, monter, imatoric, kmmh76, peixoto
Threads: 49
02-07-2013, 11:31 AM
all links dead; reposted here
password
[-] The following 9 users Like andersen3's post:9 users Like andersen3's post
  â€¢ Jackass, Dell_Brett, ting tsai huang, malc, cashdaily, narendra, peixoto, knrsa, zrilek
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,233 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,922 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,206 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,431 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,719 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,297 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,552 02-17-2021, 11:20 AM
Last Post: temp1366
