Civil Engineering Association eBooks Journals, Papers and Presentations JOURNAL OF STRUCTURAL ENGINEERING © ASCE / JANUARY - JUNE 2009
 cve_jule
Macedonia
User ID: 6973
Threads: 28
Likes: 888 in 90 posts
Given Likes: 882
12-23-2009, 02:22 PM (This post was last modified: 03-21-2010, 07:36 AM by concreteok.)
[Image: 86341193343362983108.jpg]
The Journal of Structural Engineering reports on fundamental knowledge that contributes to the state of the art and state of the practice in structural engineering. Authors discuss the art and science of structural design; investigate the physical properties of engineering materials as related to structural behavior; develop methods of analysis; and study the merits of various types of structures and methods of construction.
[Image: 32978950445523581341.jpg]
[Image: 26624569644193156679.jpg]
[-] The following 60 users Like cve_jule's post:60 users Like cve_jule's post
  • Ultra Zone, niki102, faros3000, ia_ranco, rcnet, Dell_Brett, ynopum, DamirDz, mantas1985, kowheng, jacs127, noelda2, k_civ_eng, zrilek, yakwetu, davegabj, pingfan2, yutt, rohailiyaz, babak, abudabeeja, theanhpe, cardinal85, baikur, dajabar, Haseeb Jamal, bubieng, arceon, simanta, u4406014, kristoffer_89, banky4354, ivanveliki, robertsas, Grunf, civilteam, rendel_©, hoanghiepz, Eaky, sangen, YeiYei, smar_2332, batisxuta, javier1212, avge, iceman84, yly8, mishanya, yanburak, blaze, mojtaba26, shanta, rusty, oanm2000, abinabin, sodapas, ingwlg, fer962933, ptqc06, mybest
 faros3000
Senior Member
User ID: 61
Threads: 24
Likes: 1,265 in 175 posts
Given Likes: 1793
12-23-2009, 05:59 PM
What an incredible contribution you just have posted here dear friend. This is a vivid example of the value of better posting few stuff but with an extraordinary quality. By any chance do you have the second half of the year (July-December 2009)?
THANKS again!!!
Information is not knowledge.
Albert Einstein
Threads: 57
12-24-2009, 04:45 PM
List of Journal from Post: #1
# 1
2 - Further Insights into Postbuckling of Web Panels. I; Review of Flange Anchoring Mechanism
3 - Further Insights into Postbuckling of Web Panels. II; Experiments and Verifcation of New Theory
4 - Experimental Investigation of Inelastic Cyclic Buckling and Fracture of Steel Braces
5 - Seismic Column Demands in Ductile Braced Frames
6 - Modeling of Residual Stresses in Structural Stainless Steel Sections
7 - System Identification of Alfred Zampa Memorial Bridge Using Dynamic Field Test Data
8 - Assessment of Repairs and Strengthening of a Historic Masonry Pagoda Using a Vibration-Based-Method
9 - Influence of Longitudinal Reinforcement on One-Way Shear in Slabs and Wide Beams
10 - Tests of Adhesives to Augment Nails in Wind Uplift Resistance of Roofs
11 - Counteracting Structural Loads; Treatment in ASCE Standard 7-05
# 2
1 - Prefabricated Steel Stair Performance under Combined Seismic and Gravity Loads
2 - Yield Penetration Hinge Rotation in Reinforced Concrete Beams
3 - Hysteretic Model for Reinforced Concrete Columns Including the Effect of Shear and Axial Load Failure
4 - Nonlinear Modeling of Flat-Plate Systems
5 - Framework for Multihazard Risk Assessment and Mitigation for Wood-Frame Residential Construction
6 - Performance-Based Wind Engineering for Wood-Frame Buildings
7 - Lateral Performance of Nonsymmetric Diagonal-Braced Wood Shear Walls
8 - Testing and Analysis of Steel Pipes under Bending, Tension, and Internal Pressure
9 - Finite-Strip Method for the Analysis of Cracked Plates with Application to Plate-Girder Bridges
10 - Discussion of 'Structural Monitoring and Integrity Assessment of Medieval Towers' by Alberto Carpinteri and Giuseppe Lacidogna
# 3
2 - Special Perforated Steel Plate Shear Walls with Reduced Beam Section Anchor Beams. I; Experimental Investigation
3 - Special Perforated Steel Plate Shear Walls with Reduced Beam Section Anchor Beams. II; Analysis and Design Recommendations
4 - Direct Strength Design of Cold-Formed Purlins
5 - Single-Span Deep Beams Subjected to Unsymmetrical Loads
6 - Unified Strength Model for Square and Circular Concrete Columns Confined by External Jacket
7 - Seismic Fragility Analysis and Retrofit of Conventional Residential Wood-Frame Structures in the Central United States
8 - Fully Reversed Cyclic Loading of Shear Walls Fastened with Engineered Nails
9 - Intrinsic Damping; Modeling Techniques for Engineering Systems
10 - Behavior of Reinforced and Posttensioned Concrete Members with a UHPFRC Overlay under Impact Loading
11 - U.S. Hurricane Wind Speed Risk and Uncertainty
12 - Quantitative Comparison of Optimization Approaches for the Design of Supplemental Damping in Earthquake Engineering Practice
13 - Capacities of OSB-Sheathed Light-Frame Shear-Wall Panels with or without Perforations
14 - Review of The History of the Theory of Structures—From Arch Analysis to Computational Mechanics by Karl-Eugen Kurrer
# 4
2 - Nonlinear Uniaxial Material Model for Reinforcing Steel Bars
3 - Anchorage of Longitudinal Column Reinforcement in Bridge Monolithic Connections
4 - Analytical Method for Failure of Anchor-Grout-Concrete Anchorage due to Concrete Cone Failure and Interfacial Debonding
5 - Behavior of Reinforced Concrete Box Culverts under High Embankments
6 - Experimental and Numerical Investigation of Corrosion-Induced Cover Cracking in Reinforced Concrete Structures
7 - Analytical Response and Design of Buildings with Metallic Structural Fuses. I
8 - Experimental Response of Buildings Designed with Metallic Structural Fuses. II
9 - Impact of Code Requirements in the Central United States; Seismic Performance Assessment of a Reinforced Concrete Building
10 - Seismic Risk Assessment of Gravity Load Designed Reinforced Concrete Frames Subjected to Mid-America Ground Motions
11 - Semiactive Viscous Tensile Bracing System
12 - Wind-Induced Cladding and Structural Loads on Low-Wood Building
13 - Flexural Test of a Composite Beam Using Asymmetric Steel Section with Web Openings
# 5
2 - Design of Buckling-Restrained Braced Frames Using Nonlinear Time History Analysis and Optimization
3 - Performance of a Damage-Protected Highway Bridge Pier Subjected to Bidirectional Earthquake Attack
4 - Experimental Study of a Self-Centering Beam–Column Connection with Bottom Flange Friction Device
5 - Performance-Based Seismic Design of Steel MRFs with Elastomeric Dampers
6 - Evaluation of Crack Spacing in Reinforced Concrete Shear Walls
7 - Bond Stress–Slip Model for Steel Bars in Unconfined or Steel, FRC, or FRP Confined Concrete under Cyclic Loading
8 - Performance of Steel Fibrous Reinforced Concrete Corbels Subjected to Vertical and Horizontal Loads
9 - Inhibiting Steel Brace Buckling Using Carbon Fiber-Reinforced Polymers; Large-Scale Tests
10 - Design of Steel Equal Angle Lintels
11 - Flexural Buckling of Elliptical Hollow Section Columns
12 - Design of Aluminum Alloy Flexural Members Using Direct Strength Method
13 - Predictive Models from Statistically Nonconforming Databases
14 - Predictive Models for the Median and Variability of Building Period and Damping
15 - Seismic Reliability Analysis of Diagonal-Braced and Structural-Panel-Sheathed Wood Shear Walls
16 - Strategic Network Utilization in a Wireless Structural Control System for Seismically Excited Structures
# 6
2 - The Next Step for AF&PA-ASCE 16-95; Performance-Based Design of Wood Structures
3 - Bond Model of NSM-FRP Strips in the Context of the Shear Strengthening of RC Beams
4 - Strut-and-Tie Method for CFRP Strengthened Deep RC Members
5 - Backbone Model for Confined Masonry Walls for Performance-Based Seismic Design
6 - Wood I-Joists with Excessive Web Openings; An Experimental and Analytical Investigation
7 - Strain Distribution in OSB and GWB in Wood-Frame Shear Walls
8 - Meshfree Method for Inelastic Frame Analysis
9 - Comparison and Study of Different Progressive Collapse Simulation Techniques for RC Structures
10 - Comparative Evaluation of Base-Isolated and Fixed-Base Buildings Using a Comprehensive Response Index
11 - Blast Resistance Capacity of Reinforced Concrete Slabs
12 - Gust-Front Factor; New Framework for Wind Load Effects on Structures
13 - Bridge System Performance Assessment from Structural Health Monitoring; A Case Study
14 - Stiffness Reduction Factor for Flat Slab Structures under Lateral Loads
thumbup :yes: thumbup
[-] The following 14 users Like kowheng's post:14 users Like kowheng's post
  • zrilek, faros3000, Dell_Brett, abudabeeja, Ultra Zone, cve_jule, nuttapolk, simanta, Albert, Grunf, rendel_©, oanm2000, banky4354, fer962933
 cve_jule
Macedonia
User ID: 6973
Threads: 28
Given Likes: 882
12-25-2009, 11:05 AM
(12-23-2009, 05:59 PM)faros3000 Wrote: What an incredible contribution you just have posted here dear friend. This is a vivid example of the value of better posting few stuff but with an extraordinary quality. By any chance do you have the second half of the year (July-December 2009)?
THANKS again!!!
No, I don't have that one :no: (July-December 2009). If I get it I will surely post it.
[-] The following 4 users Like cve_jule's post:4 users Like cve_jule's post
  • Dell_Brett, faros3000, Grunf, yly8
Threads: 307
03-30-2010, 05:09 AM (This post was last modified: 11-09-2010, 09:37 AM by Grunf.)
Mirror links:
👉 CLICK HERE 👈 rar 47.86 MB
If you like this book, CivilEAs' staff strongly suggest you to buy it! Support the authors!
[-] The following 14 users Like Grunf's post:14 users Like Grunf's post
  • igor1234, oanm2000, henrycv, hoanghiepz, yly8, masafi_15, vardan, civilgr, Dell_Brett, rusty, sodapas, simanta, fer962933, ptqc06
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
11-09-2010, 09:32 AM
Mirror link:
[-] The following 5 users Like 3fan's post:5 users Like 3fan's post
  • cve_jule, jcbv, Dell_Brett, oanm2000, fer962933
 fer962933
User ID: 8558
Likes: 9 in 7 posts
Given Likes: 2064
01-23-2013, 05:28 PM
All links are dead, please re upload. Thanks.
[-] The following 2 users Like fer962933's post:2 users Like fer962933's post
  • zuhalz, hamex
  The AISC Engineering Journal Archive [1964-2001] agelos100 2 8,391 03-02-2020, 01:50 AM
  ACI Structural Journal Collection essenza 23 61,330 04-21-2016, 07:41 PM
Last Post: bridgeengineer
  Deep Foundation Institute (DFI) Journal - May/June 2015 PinkPant 0 5,313 05-28-2015, 06:45 AM
Last Post: PinkPant
  AISC Engineering Journal Fourth Quarter 2014 Volume 51, No. 4 malc 1 6,917 10-15-2014, 07:26 AM
Last Post: Saze808
  ACI Materials Journal May - June 2014 V. 111 No. 3 RyanRS 0 4,339 07-12-2014, 08:07 PM
Last Post: RyanRS
  ACI Journal (Journal Proceedings January-April 1983) yanburak 2 8,240 11-01-2013, 06:13 PM
Last Post: yakwetu
  ASCE Bundle Journal for Nonlinear Stress-Strain Model (Concrete, Reinforced Bar, Stee RyanRS 0 5,028 07-27-2013, 05:13 AM
Last Post: RyanRS
