Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 318: Building Code Requirements for Structural Concrete and Commentary
 KMABD
User ID: 14195
Threads: 8
Likes: 682 in 36 posts
Given Likes: 111
#71
06-22-2019, 06:12 PM (This post was last modified: 06-22-2019, 06:13 PM by KMABD. Edit Reason: N/A )
Same as above but with copyright info appearing on the right margin on pages are removed. Use forum password
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 45 users Like KMABD's post:45 users Like KMABD's post
  β€’ hatkam, Nita1391, Veggeta, rami1976, Andrew seah, subin91, promo8, usman, kowheng, cargadory2k, simanta, temp1366, jcbv, Dell_Brett, rendel_Β©, jokerβ„’, amindoxiti, oanm2000, gulilero, pan5, shaker, betinnn, carolinandra, lisine, ascetic19, melekeen, bigone, cace-01, jaks, er.shyams, PinkPant, nhim4mat2006, faros3000, alcalan57, monter, lasalleguy, pedzaquino, pram, moh_towhid, Rami11, fbx_rdnk, jonygut, zrilek, golpesar, nibbi
Threads: 274
Likes: 12,075 in 1,233 posts
01-05-2020, 09:24 AM
ACI 318 (SI Unit)
Size: 14 MB | Format: PDF | Quality: Original preprint
[Image: 30321536903894727657.jpg]
[-] The following 38 users Like pezhmankhan's post:38 users Like pezhmankhan's post
  β€’ jcbv, araza023, Nita1391, camto2, aslam, Ernest0, ibg0203, subin91, temp1366, cheosmith, carolinandra, kowheng, tuanpecc1, malc, tomtumx, KhaLed-S.E, Aviator, zrilek, PinkPant, lisine, Dell_Brett, civilfafa, febo927, shaker, melekeen, oanm2000, pontiac, red_pool61, ali akbar, Rami11, KMABD, nhim4mat2006, Ekkaia, amindoxiti, Batman07, fbx_rdnk, jonygut, golpesar
 malee
User ID: 554
Threads: 20
Likes: 1,358 in 98 posts
Given Likes: 267
#73
01-07-2020, 12:26 AM (This post was last modified: 01-07-2020, 12:50 AM by Dell_Brett. Edit Reason: QUOTE REMOVED )
Mirror link ACI 318 (SI Unit)
[-] The following 18 users Like malee's post:18 users Like malee's post
  β€’ Dell_Brett, tuanpecc1, mohamz, rendel_Β©, zrilek, PinkPant, promo8, zego2000, gulilero, Rami11, pram, KMABD, nhim4mat2006, Ekkaia, Batman07, jonygut, cace-01, lisine
 eng donny
Indonesia
User ID: 765
Threads: 19
Likes: 1,976 in 236 posts
Given Likes: 905
#74
09-11-2020, 04:44 PM (This post was last modified: 08-24-2021, 07:51 AM by Administrator.)
ACI_318M-19
[Image: 80127215793174297068.jpg]
  • Published By: ACI Committee 318
  • Quality: Unspecified
  • Abstract: The β€œBuilding Code Requirements for Structural Concrete” (β€œCode”) provides minimum requirements for the materials, design, and detailing of structural concrete buildings and, where applicable, nonbuilding structures. This Code was developed by an ANSI-approved consensus process and addresses structural systems, members, and connections, including cast-in-place, precast, shotcrete, plain, nonprestressed, prestressed, and composite construction. Among the subjects covered are: design and construction for strength, serviceability, and durability; load combinations, load factors, and strength reduction factors; structural analysis methods; deflection limits; mechanical and adhesive anchoring to concrete; development and splicing of reinforcement; construction document information; field inspection and testing; and methods to evaluate the strength of existing structures.
    The Code was substantially reorganized and reformatted in 2014, and this Code continues and expands that same organizational philosophy. The principal objectives of the reorganization were to present all design and detailing requirements for structural systems or for individual members in chapters devoted to those individual subjects, and to arrange the chapters in a manner that generally follows the process and chronology of design and construction. Information and procedures that are common to the design of multiple members are located in utility chapters. Additional enhancements implemented in this Code to provide greater clarity and ease of use include the first use of color illustrations and the use of color to help the user navigate the Code and quickly find the information they need. Special thanks to Bentley Systems, Incorporated, for use of their ProConcrete software to produce many of the figures found in the Commentary.
    Uses of the Code include adoption by reference in a general building code, and earlier editions have been widely used in this manner. The Code is written in a format that allows such reference without change to its language. Therefore, background details or suggestions for carrying out the requirements or intent of the Code provisions cannot be included within the Code itself. The Commentary is provided for this purpose.
    Some considerations of the committee in developing the Code are discussed in the Commentary, with emphasis given to the explanation of new or revised provisions. Much of the research data referenced in preparing the Code is cited for the user desiring to study individual questions in greater detail. Other documents that provide suggestions for carrying out the requirements of the Code are also cited.
    Keywords: admixtures; aggregates; anchorage (structural); beam-column frame; beams (supports); caissons; cements; cold weather; columns (supports); combined stress; composite construction (concrete to concrete); compressive strength; concrete; construction documents; construction joints; continuity (structural); contraction joints; cover; curing; deep beams; deep foundations; deflections; drilled piers; earthquake-resistant structures; flexural strength; floors; footings; formwork (construction); hot weather; inspection; isolation joints; joints (junctions); joists; lightweight concretes; load tests (structural); loads (forces); mixture proportioning; modulus of elasticity; moments; piles; placing; plain concrete; precast concrete; prestressed concrete; prestressing steels; quality control; reinforced concrete; reinforcing steels; roofs; serviceability; shear strength; shotcrete; spans; splicing; strength analysis; stresses; structural analysis; structural design; structural integrity; structural walls; T-beams; torsion; walls; water; welded wire reinforcement.
[-] The following 22 users Like eng donny's post:22 users Like eng donny's post
  β€’ babakfeyzi, oanm2000, kowheng, faros3000, zrilek, blaze, simanta, Dell_Brett, CAMSECT, PinkPant, ascetic19, gulilero, jaks, yakwetu, pelelo, rezart, levanduy, Hengki, sodapas, pedzaquino, nhim4mat2006, vinnunsam
Threads: 769
Likes: 8,311 in 1,373 posts
Given Likes: 94
#75
09-04-2021, 09:11 AM (This post was last modified: 09-05-2021, 12:14 PM by Dell_Brett. Edit Reason: N/A )
ACI318/318R-89
| Size: 16 MB| Format: PDF| Quality: Original preprint| Publisher: ACI| Year: 1989| pages: 356
[Image: 97894395952569344381.jpg]
[Image: comments.png]
Moderator Note:
Great contribuition!
Make our forum better and well organized!
Thanks a lot (in mame of all moderators)
[-] The following 12 users Like poolmand's post:12 users Like poolmand's post
  β€’ zrilek, blaze, Administrator , PinkPant, kowheng, Dell_Brett, bitsripper, mgdario, tuanpecc1, Aviator, oanm2000, vinnunsam
Threads: 769
Given Likes: 94
#76
02-06-2024, 08:27 AM
ACI 318-19, ACI 318M-19, Changes Between ACI 318-19 and ACI 318-19(22), Latest Errata
| Size: 22.31 MB| Format: PDF| Quality: Original preprint| Year: 2023
[-] The following 11 users Like poolmand's post:11 users Like poolmand's post
  β€’ PinkPant, subin91, babakfeyzi, jcbv, ascetic19, rendel_Β©, Umer.Aleem, Dell_Brett, lisine, jokerβ„’, tahmid1971
 babakfeyzi
Semi Senior Member
Romania
User ID: 177117
Threads: 15
Likes: 626 in 97 posts
Given Likes: 1392
#77
03-29-2025, 02:30 PM
ACI CODE-318-25: Building Code for Structural Concrete- Code Requirements and Commentary (ACI CODE-318-25)
[-] The following 5 users Like babakfeyzi's post:5 users Like babakfeyzi's post
  β€’ subin91, zrilek, tomtumx, lisine, Dell_Brett
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
#78
03-29-2025, 02:46 PM
ACI CODE-318-25 - Inch-Pound Units
| Size: 34 MB| Format: PDF| Quality: Original preprint| Publisher: American Concrete Institute
Building Code for Structural Concrete Code Requirements and Commentary (ACI CODE-318-25)
No limits to creativity
[-] The following 6 users Like jokerβ„’'s post:6 users Like jokerβ„’'s post
  β€’ subin91, tomtumx, concreteok, lisine, Dell_Brett, mecheil.edwar
Threads: 769
Given Likes: 94
#79
04-19-2025, 01:02 PM
Author(s)/Editor(s): ACI Committee 318 | Size: 13.7 MB| Format: PDF| Quality: Original preprint| Year: 2025| pages: 702 | ISBN: 9781641953092
[Image: 24227815121054479703.png]
The β€œBuilding Code for Structural Concrete” (β€œCode”) provides minimum requirements for the materials, design, and detailing of structural concrete buildings and, where applicable, nonbuilding structures. The Code was developed using a consensus process and addresses structural systems, members, and connections, including cast-in-place, precast, shotcrete, plain, nonprestressed, and prestressed, construction. Among the subjects covered are: design and construction for strength, serviceability, and durability; load combinations, load factors, and strength reduction factors; structural analysis methods; deflection limits; mechanical and adhesive anchoring to concrete; development and splicing of reinforcement; construction document information; field inspection and testing; methods to evaluate the strength of existing structures; design verification using nonlinear response history analysis in Appendix A; performance-based wind design in Appendix B, and sustainability and resilience in Appendix C.
Uses of the Code include adoption by reference in a general building code, and earlier editions have been widely used in this manner. The Code is written in a format that allows such reference without change to its language. Commentary is provided for background information and further explanation of the code requirements. Cited references provide research data useful in studying technical issues in greater detail. Other references, provide greater insight into the code the requirements. Technical changes from ACI CODE-318-19 to ACI CODE-318-25 are indicated by change bars in the margins of the print and PDF versions. Technical changes from ACI CODE-318-19 to ACI CODE-318-25 may also be viewed in red highlights within the PLUS version (https://www.concrete.org/publications/aci318plus.aspx).
admixtures; aggregates; anchorage (structural); beam-column frame; beams (supports); caissons; cements; cold weather; columns (supports); combined stress; composite construction (concrete to concrete); compressive strength; concrete; construction documents; construction joints; continuity (structural); contraction joints; cover; curing; deep beams; deep foundations; deflections; drilled piers; earthquake-resistant structures; flexural strength; floors; footings; formwork (construction); hot weather; inspection; isolation joints; joints (junctions); joists; lightweight concretes; load tests (structural); loads (forces); mixture proportioning; modulus of elasticity; moments; piles; placing; plain concrete; precast concrete; prestressed concrete; prestressing steels; quality control; reinforced concrete; reinforcing steels; resilience; roofs; serviceability; shear strength; shotcrete; spans; splicing; strength analysis; stresses; structural analysis; structural design; structural integrity; structural walls; sustainability; T-beams; torsion; walls; water; welded wire reinforcement.
[-] The following 10 users Like poolmand's post:10 users Like poolmand's post
  β€’ babakfeyzi, subin91, Ultra Zone, lisine, Dell_Brett, rami1976, heogay43, mkamal82, jacky899, zrilek
 babakfeyzi
Semi Senior Member
Romania
User ID: 177117
Threads: 15
Given Likes: 1392
#80
07-18-2025, 02:07 PM (This post was last modified: 07-18-2025, 02:08 PM by babakfeyzi.)
Hi
ACI318-25 Metric edition
[-] The following 1 user Likes babakfeyzi's post:1 user Likes babakfeyzi's post
  β€’ zrilek
Pages (9): « Previous 1 2 3 4 5 6 7 8 9 Next »
  ACI 318.2: Building Code Requirements for Concrete Thin Shells ir_71 7 6,925 12-06-2025, 11:30 AM
  [CivilEA Exclusive] ACI/PCI 319: Structural Precast Concrete β€”Code Requirements and Commentary poolmand 2 8,021 09-16-2025, 11:03 AM
  [CivilEA Exclusive] ACI 349: Code Requirements for Nuclear Safety Related Concrete Structures andersen3 5 6,319 12-15-2024, 06:33 AM
  [CivilEA Exclusive] ACI 323: Low-Carbon Concrete - Code Requirements and Commentary poolmand 0 2,580 12-15-2024, 05:50 AM
  ACI 307: Requirements for Reinforced Concrete Chimneysβ€”Code and Commentary poolmand 0 2,921 02-03-2024, 06:28 AM
  ACI 440.11: Building Code Requirements for Structural Concrete Reinforced with Glass poolmand 0 2,430 01-08-2024, 08:31 AM
  ACI 437.2: Load Testing of Concrete Structures - Code and Commentary poolmand 1 3,559 11-06-2023, 05:36 AM
