Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC - Steel Design Guides
 subin91
Semi Senior Member
User ID: 2232
Threads: 35
Likes: 2,192 in 111 posts
Given Likes: 4701
#71
03-17-2024, 04:32 PM
Design Guide 24 : Hollow Structural Section Connections, Second Edtion 2024
[Image: 10487693577756646051.jpg]
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 11 users Like subin91's post:11 users Like subin91's post
  â€¢ melekeen, civilfafa, zrilek, PinkPant, babakfeyzi, jcbv, spiderthan, tomtumx, mowafi3m, jcoronellr, milova
Threads: 769
Likes: 8,311 in 1,373 posts
Given Likes: 94
#72
06-22-2024, 04:14 AM
AISC Design Guide 1: Base Connection Design for Steel Structures (Third Edition)
Author(s)/Editor(s): Amit Kanvinde, Mahmoud Maamouri, and Joshua Buckholt | Size: 7.69 MB| Format: PDF| Quality: Original preprint| Year: 2024
[Image: 04029210568495624894.png]
This new edition of AISC Design Guide 1, Base Connection Design for Steel Structures, provides detailed analysis and design guidance on base connections. Years of research contributed to the significant expansions included in the design guide in areas of seismic design and embedded base connection design. Guidance is also offered on the simulation of base connections in finite element models. Extensive design examples are included.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 10 users Like poolmand's post:10 users Like poolmand's post
  â€¢ zrilek, tomtumx, civilfafa, PinkPant, babakfeyzi, tahmid1971, Dell_Brett, ASEC, tuanpecc1, milova
Threads: 769
Given Likes: 94
#73
09-23-2024, 01:26 PM
Design Guide 40: Rain Loads and Ponding
Author(s)/Editor(s): Mark D. Denavit, PE, PhD; James M. Fisher, PE, PhD, Dist. M.ASCE | Size: 16.38 MB| Format: PDF| Quality: Original preprint| Year: March 2024
[Image: 64141873872293417780.jpg]
This design guide provides an in-depth review of rain loads and ponding effects to help design professionals properly and efficiently design for ponding on roofs constructed with structural steel, open web steel joists, and joist girders. It includes several recommended methods of analysis that can be used to consider the effects of ponding, methods of design accounting for ponding effects, and a presentation of the SJI Roof Bay Analysis Tool. These methods are thoroughly discussed and then demonstrated with many helpful design examples.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
  â€¢ babakfeyzi, zrilek, Dell_Brett, milova
Threads: 274
Likes: 12,075 in 1,233 posts
02-19-2025, 08:08 PM
Design Guide 16 : Assessment and Repair of Structural Steel in Existing Buildings, 2025
[Image: 21390925046615078220.jpg]
Abstract: As buildings age, the need for effective structural evaluation and maintenance becomes increasingly critical. This publication discusses common considerations for initial assessments as well as methods for detailed inspection, evaluation, and nondestructive examination. It also explores several types of damage or deterioration commonly found in existing steel buildings and approaches for evaluating their structural effects. The guide offers practical advice for planning and executing repairs.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 10 users Like pezhmankhan's post:10 users Like pezhmankhan's post
  â€¢ rami1976, zrilek, babakfeyzi, spiderthan, poolmand, temp1366, Dell_Brett, tomtumx, tuanpecc1, milova
Threads: 769
Given Likes: 94
#75
08-18-2025, 06:17 AM (This post was last modified: 08-18-2025, 06:20 AM by poolmand.)
Design Guide 6: Composite Column Design (Second Ed.) + Composite Column Program
Author(s)/Editor(s): Matthew Trammell, Mark Denavit, Tiziano Perea, Jerome Hajjar, and Roberto Leon| Format: PDF| Quality: Original preprint| Year: 2025
[Image: do.php?img=7]
This new edition of Design Guide 6 provides updated and expanded information on the design of steel-concrete composite columns. Guidance for designing and detailing encased composite columns has been updated and expanded to reflect the modern requirements of the 2022 AISC Specification. This new edition now also includes direction for designing square, rectangular, and round filled composite columns.
Additionally, guidance has been given for designing square and rectangular filled composite columns with high-strength materials. Thorough design examples are included for each of these composite column types. Recommendations for designing connections to composite columns are provided. A modern spreadsheet-based tool is also provided to assist with calculating available axial, flexural, and shear strengths of composite members.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
  â€¢ zrilek, wchum, milova, tuanpecc1, temp1366
Threads: 769
Given Likes: 94
#76
06-13-2026, 09:38 AM
[CivilEA Exclusive] AISC Design Guide 41: Structural Joints Using Stainless Steel Bolts PDF
Author(s)/Editor(s): Francisco Meza, Nancy Baddoo and Jason Provines | Size: 9.11 MB| Format: PDF| Quality: Scanner| Publisher: AISC| Year: 2025
[Image: do.php?img=38]
This joint AISC and RCSC publication covers the design, fabrication, and installation of connections using stainless steel bolts, aligning with the main topics in the RCSC Specification for Structural Joints Using High-Strength Bolts. The information in this publication is relevant to bolted connections in building-type structures as well as bridges, and to bolted connections between stainless steel members and carbon steel members. It covers snug-tight, pretensioned, and slip-critical bolted connections. The guidance is based on existing design provisions and information in ANSI/AISC 370 and the Second Edition of AISC Design Guide 27. Three illustrative design examples are included.
👉 CLICK HERE 👈
👉 CLICK HERE 👈
👉 CLICK HERE 👈
[-] The following 8 users Like poolmand's post:8 users Like poolmand's post
  â€¢ subin91, toddyi, zrilek, tuanpecc1, lisine, milova, babakfeyzi, temp1366
Pages (8): « Previous 1 2 3 4 5 6 7 8
  AISC 327: Seismic Design Manual weichunc 16 15,412 06-13-2026, 09:27 AM
  AISC - Steel Construction Manual dinu69in 26 28,026 06-10-2026, 12:17 PM
  ANSI/AISC N690: Specification for Safety-Related Steel Structures for Nuclear Facil ir_71 5 13,182 08-18-2025, 07:07 AM
  AISC Model Review and Approval for Structural Steel poolmand 0 3,761 04-29-2024, 07:29 AM
  AISC BIM & VDC FOR STRUCTURAL STEEL poolmand 0 3,346 04-29-2024, 07:27 AM
  AISC Conference: Composite Construction in Steel and Concrete VIII poolmand 0 3,160 12-04-2023, 09:17 AM
  AISC: Facts for Steel Buildings tarugo 8 9,118 12-04-2023, 09:11 AM
