Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] ASCE Journal/Proceedings
[Request] ASCE Journal/Proceedings
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#671
02-07-2017, 08:11 AM (This post was last modified: 02-07-2017, 08:44 AM by ssobhan. Edit Reason: N/A )
Hysteresis Modeling of Reinforced Concrete Structures: State of the Art
The paper in first link is not complete.
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 7 users Like ssobhan's post:7 users Like ssobhan's post
  β€’ malc, RyanRS, Dell_Brett, cace-01, zrilek, ska51, PinkPant
 xnr09
User ID: 9060
Threads: 21
Likes: 1,120 in 126 posts
Given Likes: 74
#672
02-07-2017, 02:59 PM
Here it is
Cheers
xnr09
[-] The following 8 users Like xnr09's post:8 users Like xnr09's post
  β€’ zrilek, cace-01, oanm2000, RyanRS, Dell_Brett, ska51, K.Lee, PinkPant
 peixoto
Portugal
User ID: 6963
Threads: 42
Likes: 968 in 114 posts
#673
03-07-2017, 04:50 PM
  • Article/eBook Full Name:
  • Strain Wedge Model Capability of Analyzing Behavior of Laterally Loaded Isolated Piles, Drilled Shafts, and Pile Groups
  • Author(s):
  • Mohamed Ashour, M.ASCE; Gary Norris, M.ASCE; and Patrick Pilling, M.ASCE
  • Edition:
  • Journal of Bridge Engineering / Volume 7 Issue 4 - July 2002
  • Publish Date:
  • 2002
  • Published By:
  • ASCE
  • Related Links:
  • Code:
  β€’
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
#674
03-07-2017, 05:12 PM
Plz find the article in the following Link:
Article name: Strain Wedge Model Capability of Analyzing Behavior of Laterally Loaded Isolated Piles, Drilled Shafts, and Pile Groups
Authors: Mohamed Ashour, M.ASCE; Gary Norris, M.ASCE; and Patrick Pilling, M.ASCE
"Downstream is Weaker"
[-] The following 8 users Like ska51's post:8 users Like ska51's post
  β€’ freequo, zrilek, Dell_Brett, malc, cace-01, peixoto, K.Lee, PinkPant
 farhadam
User ID: 12321
Threads: 2
Likes: 0 in 0 posts
Given Likes: 6
#675
03-29-2017, 09:05 PM
Hi.I need some old papers (before 1982) from ASCE. These papers dont have digital version in ASCE library.
Bertero, V. V., and Popov, E. P. 1965. β€œEffect of Large Alternating Strains of Steel
Beams.” Journal of the Structural Division, American Society of Civil Engineers,
vol. 91, no. ST1.
Karsan, I.D. and J.O. Jirsa (1969). β€œBehavior of Concrete under Compressive Loadings,” Journal of
the Structural Division, ASCE, Vol. 95, No. ST12, pp. 2543–2564.
Park, R., M.J.N. Priestley, and W.D. Gill (1982). β€œDuctility of Square-Confined Concrete Columns,”
Journal of the Structural Division, Vol. 108, No. ST4, pp. 929–950.
Sheikh, S.A., and S.M. Uzumeri (1980). β€œStrength and Ductility of Tied Concrete Columns,” Journal
of the Structural Division, Vol. 106, No. ST5, pp. 1079–1102.
Sheikh, S.A., and S.M. Uzumeri (1982). β€œAnalytical Model for Concrete Confinement in Tied
Columns,” Journal of the Structural Division, Vol. 108, No. ST12, pp. 2703–2722.
  β€’
 spiritmedal
Indonesia
User ID: 40849
Threads: 9
Likes: 18 in 10 posts
Given Likes: 21
#676
11-16-2017, 01:13 PM (This post was last modified: 11-16-2017, 01:21 PM by BennyP. Edit Reason: Transparent links coded )
Does Anyone have following paper?.
Article name: Ultimate Wind Load Design Gust Wind Speeds in the United States for Use in ASCE-7
Author: Peter J. Vickery; Dhiraj Wadhera; Jon Galsworthy; Jon A. Peterka; Peter A. Irwin; and Lawrence A. Griffis
Author:Jon A. Peterka, Member, ASCE
Comparison of Directional and Envelope Wind Load Provisions of ASCE 7
Author:Christopher A. Trautner, P.E., S.M.ASCE; and Rasko P. Ojdrovic, P.E., M.ASCE
  β€’
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
#677
11-16-2017, 01:49 PM
Use "Preview Post" button before posting,
Then apply code tag to your links. Select links and click on button "Code".
Use Preview Post again to check if links are protected.
Only then use "Post Reply" button.
[-] The following 7 users Like lisine's post:7 users Like lisine's post
  β€’ zrilek, temp1366, ska51, PinkPant, Dell_Brett, oanm2000, malc
 Tetrapod
Indonesia
User ID: 56697
Threads: 0
Likes: 4 in 3 posts
Given Likes: 14
#678
12-21-2017, 11:56 AM (This post was last modified: 12-21-2017, 12:00 PM by Tetrapod. Edit Reason: N/A )
  • A New Linear Response History Analysis Procedure for the 2015 NEHRP Recommended Provisions and for ASCE 7-16
  • Author(s):
  • Finley Charney
  • VOL:
  • 107
  • Publish Date:
  • 2015
  • Published By:
  • Structures Congress 2015
  • Related Links:
  • Code:
  β€’
Threads: 274
Likes: 12,075 in 1,233 posts
12-21-2017, 01:44 PM
[align][align=left]
  • Author(s): Finley Charney
  • Published By: ASCE Structures Congress
  • Published Year: 2015
  • DOI: 10.1061/9780784479117.214
  • Size: 460 KB
  • Quality: Original Preprint
  • Related Link:
    https://ascelibrary.org/doi/abs/10.1061/...479117.214
  • Abstract: A new Linear Response History (LRH) analysis procedure has been approved for inclusion in the 2015 NEHRP Recommended Provisions, and will likely be included with some minor revisions in Chapter 12 of ASCE 7-16. The principal differences between the new procedure and the LRH procedure that is currently included in Chapter 16 of ASCE 7-10 are: 1) spectrum matched ground motions are required for seismic analysis, 2) the structure being analyzed is required to be modeled in three dimensions, 3) accidental torsion, where required, must be included in the analysis by offsetting the center of mass at each floor level, 4) P-Delta effects must be included directly in the analysis, and 5) peer review is not required. Additionally, requirements for scaling the results for consistency with the Equivalent Lateral Force seismic base shear demands are clarified.
[-] The following 8 users Like pezhmankhan's post:8 users Like pezhmankhan's post
  β€’ zrilek, uncblue, PinkPant, Tetrapod, oanm2000, Dell_Brett, malc, K.Lee
Threads: 307
03-12-2018, 09:08 AM
  • Article/eBook Full Name: Centrifuge and Large-Scale Modeling of Seismic Pore Pressures in Sands: Cyclic Strain Interpretation
  • Author(s): T. Abdoun et al.
  • Edition: Vol. 139, Issue 8
  • Publish Date: 2013
  • Published By: Journal of Geotechnical and Geoenvironmental Engineering
  • Related Links:
  β€’
Pages (72): « Previous 1 … 63 64 65 66 67 68 69 70 71 72 Next »
  [REQUEST] ASCE Journal of Structural Engineering Vol. 132 (2006) mistahpablo 1 2,145 03-31-2017, 04:44 AM
Last Post: pezhmankhan
  [REQUEST] ASCE Journal of the Soil Mechanics and Foundation miquan 9 5,775 12-22-2014, 08:28 PM
Last Post: f_slikken
