Civil Engineering Association Software Software Product Autodesk Products Autodesk 2024
Autodesk 2024
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,039 in 2,189 posts
Given Likes: 42508
#51
02-09-2025, 01:41 AM
Try this instead:
1. Install the software
2. Copy VERSION.DLL to
- \Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\AdskLicensingAgent\
3. Change "this_host" in LICENSE.DAT to your host name.
Setup & start license server (LMTOOLS.EXE) with LICENSE.DAT as license file
4. Run the software and choose:
- License type: Use a network license
- License server model: Single License Server
- Name of the server: 27080@your_host_name or [email protected]
5. In case software has no GUI:
- Add environment variable ADSKFLEX_LICENSE_FILE and set value 27080@your_host_name
6. Add the following strings to your "\windows\system32\drivers\etc\hosts" file:
127.0.0.1 genuine-software.autodesk.com
127.0.0.1 genuine-software1.autodesk.com
127.0.0.1 genuine-software2.autodesk.com
127.0.0.1 ase.autodesk.com
127.0.0.1 ase-cdn-stg.autodesk.com
👉 CLICK HERE 👈
[-] The following 3 users Like Dell_Brett's post:3 users Like Dell_Brett's post
  â€¢ zrilek, jorgeramos, babakfeyzi
 jorgeramos
Semi Senior Member
User ID: 3729
Threads: 20
Likes: 229 in 29 posts
Given Likes: 344
#52
02-14-2025, 02:03 PM (This post was last modified: 02-21-2025, 01:48 AM by Dell_Brett.)
(02-09-2025, 01:41 AM)Dell_Brett Wrote: Try this instead:
👉 CLICK HERE 👈
Hello Dell_Brett
On my laptop it was possible to eliminate the pop-up with the suggestion in the first part of the message (using LMTOOLS). On the desktop PC the same did not work, possibly due to the message 'FNLS failed to return TPM attributes' which does not appear on the other device. Could this be the explanation and what is the method to overcome it?
Best regards
Dell Note:
Try do block internet access in the firewall.
  â€¢
 jorgeramos
Semi Senior Member
User ID: 3729
Threads: 20
Given Likes: 344
#53
02-22-2025, 06:37 PM
thanks Dell_Brett
problem solved as suggested.
[-] The following 1 user Likes jorgeramos's post:1 user Likes jorgeramos's post
  â€¢ Dell_Brett
Pages (6): « Previous 1 2 3 4 5 6
  Autodesk Universal Patch 2020-2024 All Products Dell_Brett 2 15,279 10-04-2023, 07:10 AM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,732 04-16-2023, 09:52 AM
  Autodesk Structural Bridge Design 2024-32bit X86.ISO TAFATNEB 0 4,665 04-13-2023, 07:37 AM
  Autodesk Navisworks Simulate 2024 (x64) Multilanguage TAFATNEB 1 5,268 04-03-2023, 04:08 PM
Last Post: cargadory2k
