Civil Engineering Association Software Software Product Csi Products ETABS CSI ETABS V9
CSI ETABS V9
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
#41
01-27-2011, 07:14 PM (This post was last modified: 01-27-2011, 07:18 PM by rendel_Β©.)
Mirror:
πŸ‘‰ CLICK HERE πŸ‘ˆ
No limits to creativity
[-] The following 10 users Like jokerβ„’'s post:10 users Like jokerβ„’'s post
  β€’ zrilek, ruaumoko, rezart, yamacdere, mecheil.edwar, Mhasan, kami, Grunf, ajmf77, sodapas
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,118
Likes: 30,986 in 4,091 posts
Given Likes: 612
#42
02-12-2011, 08:48 AM
For requests use software requests subsection.
For software problems use software problems subsection.
For engineering problems go to Civil Engineering Discussion - Problems.
Posts in wrong section will be deleted and the user warned.
[-] The following 7 users Like BennyP's post:7 users Like BennyP's post
  β€’ hmwere, aslam, faxel, RANA WASEEM, mecheil.edwar, Mhasan, HerrMeier
 ingcivilpe
User ID: 25029
Threads: 0
Likes: 509 in 19 posts
Given Likes: 13
#43
03-04-2011, 07:39 PM
ETABS v9.7.2
[Image: Etabs-v9.7.2-image.jpg]
download Rapidshare: ETABS v9.7.2 + Medicine | 100MB
[-] The following 37 users Like ingcivilpe's post:37 users Like ingcivilpe's post
  β€’ malc, zrilek, mowafi3m, jferrer, erthqkengnrβ„’, mahyarov, ssi3k, blaze, addy85, maad59, hzaheer, Ende_Neu, Galileo, mnoim, cristi, mecheil.edwar, prasat, TAFATNEB, Visitante, caobangdpv, Mhasan, kopauk, ChisTeam, bigone, u4406014, salahcivil, kokosparla, faxel, ykhackhack, sodapas, bao2004, pram, nickycruz, paitaconst, chicosi, sructme, binh.ce
 ingcivilpe
User ID: 25029
Threads: 0
Given Likes: 13
#44
03-10-2011, 10:52 PM
download Megaupload: ETABS v9.7.2 + Medicine | 100MB
[-] The following 49 users Like ingcivilpe's post:49 users Like ingcivilpe's post
  β€’ blaze, zrilek, ruaumoko, Galileo, mnoim, goober, yyyready, wa_sin_29, fashion, mecheil.edwar, Ekkaia, subin91, ArissB, TAFATNEB, golpesar, jcbv, mafiyaboss, Mhasan, kiefer7, theanhpe, gmtxx, mgdario, jorgeramos, ChisTeam, MeneGol, musssa, narendra, rac123, noel, ivan1320, michaelsoe, ramilsartates, pana2, arceon, mahfuzbangla, chenamoy, llbb, u4406014, chino1409, highcivil, meetolu, tomas7hc, thebeatles, saed, pssst, orio777, jaai, masafi_15, pedzaquino
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
#45
08-13-2011, 12:18 AM (This post was last modified: 08-13-2011, 02:21 AM by kowheng.)
ETABS Version 9.7.3
[Image: 19577302899221078500.png]
ETABS MODELING
β€’ Object Based Graphical Interface
β€’ Model Templates for Most Steel & Concrete Building Systems
β€’ Models Created Using Building Terminology
β€’ Beam/Column/Brace Frame Objects
β€’ Wall/Slab/Deck Shell Objects with Internal Meshing
β€’ Story Definitions using the Concept of Similar Stories
β€’ Common Labeling of Objects between Similar Stories
β€’ Complex 2D and 3D Shear Walls Interacting with Beams & Columns
β€’ Integrated Graphical Section Designer for Complex Frame Shapes
β€’ Editing with Move, Merge, Mirror and Replicate
β€’ Accurate Dimensioning with Guidelines and Snapping
β€’ Rigid, Semi-Rigid and Flexible Floor Diaphragm Definitions
β€’ Powerful Extrusion Command for Generating Ramps
β€’ Auto Line Constraints for Mismatched Wall Meshes
β€’ Quick Draw Options for Object Creation
β€’ Draw Command for Easily Adding Openings to Floors
β€’ Support for Multiple Coordinate Systems
β€’ Powerful Grouping and Selection Options
β€’ Automatic Generation of Code Lateral Wind and Seismic Loads
β€’ Automatic-Permutation of Wind Directions and Eccentricities
β€’ Transfer of Loads from Decks/Slabs to Beams and Walls
β€’ Vertical Area Loads in Any Shape or Configuration
β€’ Cracked Properties – Property Modification Factors
β€’ Gravity, Pressure and Thermal Loading
β€’ Wind Loading on Open Structures
β€’ Sequencing Allowing Adding or Removing Objects/Loads/Supports
β€’ Buildings with Base Isolation and Inter-Story Dampers
ETABS ANALYSIS
β€’ Static/Dynamic Analysis for Frame and Shear Wall Buildings (N, P)
β€’ Response Spectrum Analysis with Eigen or Ritz Vectors (N, P)
β€’ P-Delta Analysis (N, P)
β€’ Automated Center of Rigidity Calculations (N, P)
β€’ Rigid, Semi-Rigid, Multiple and Flexible Floor Diaphragms (N, P)
β€’ Frame Objects Drawn as Members – Automatically Meshed (N, P)
β€’ Automatic Meshing of Decks/Slabs for Diaphragm Analysis (N, P)
β€’ Wall/Slab/Deck Modeled with Shell, Plate or Membrane Types (N, P)
β€’ Applied Force and Ground Displacement Loading (N, P)
β€’ Seismic Acceleration or Displacement Time History Analysis (N, P)
β€’ Wind Load Forcing Functions (N, P)
β€’ Explicit Panel-Zone Deformations (N, P)
β€’ Effects of Beam-Column Partial Fixity (N, P)
β€’ Construction Sequence Loading Analysis (N)
β€’ Frame Hinges for Axial, Flexural, Shear & Torsional Behavior (N)
β€’ Nonlinear Static Pushover Analysis (N)
β€’ Viscous Dampers (N)
β€’ Base Isolators (N)
β€’ Gap Object for Structural Pounding (N)
β€’ Nonlinear Time History Analysis with the Wilson FNA Method (N)
β€’ Large Displacement Analysis (N)
β€’ Sequential Construction Analysis (N)
SEQUENTIAL CONSTRUCTION (N)
β€’ Model Effects of Construction or Demolition
β€’ Specify Active Structure by Stories or Groups
β€’ Geometric Nonlinear P-Delta and Large Displacements
β€’ Sequential Construction Load Cases for Design
β€’ User Defined Loading
PUSHOVER ANALYSIS (N)
β€’ FEMA 273, ATC-40
β€’ Force-Deformation Relations for Steel & Concrete Hinges
β€’ Modal, Uniform, or User Defined Lateral Load Patterns
β€’ Capacity Spectrum Conversions
β€’ Effective Damping Calculation
β€’ Demand Spectrum Comparisons
β€’ Performance Point Calculation
β€’ Summary Reports including Plastic Hinge Deformations
ETABS DESIGN
β€’ Steel Frame Design for AISC-ASD & LRFD, UBC, British, Canadian,
Italian and Euro Codes
β€’ Concrete Frame Design for ACI, UBC, British, Canadian, New
Zealand, Indian, Mexican and Euro Codes
β€’ Composite Beam Design for AISC-ASD & LRFD, British and Canadian
β€’ Concrete Shear Wall Design for American, British & Canadian Codes
β€’ Automated Steel Joist (K or KCS) Selection
β€’ Design for Static and Dynamic Loads
β€’ Floor Vibration Analysis with Murray Damping
β€’ Automatic Calculation of Moment Magnification Factors
β€’ Automatic Calculation of K-Factors & P-Delta Effects
β€’ Steel Frame Design Offers Automatic Member Selection
β€’ Seismic Requirements for Special Moment-Resisting Frames
β€’ Automatic Tributary-Area Live Load Reduction
β€’ Graphical Section Designer for Complex and Built-Up Shapes
β€’ Special Moment Beam Types for Steel Frames
β€’ Virtual Work Based Optimization for Lateral Deflections
β€’ Camber and Stud Requirements for Composite Beams
β€’ Grouping for Design Envelopes
β€’ Designed for Biaxial-Moment/Axial-Load Interaction
β€’ Seismic Check of Beam/Column Joints in Concrete Frames
β€’ Automated Effects of Panel-Zone Deformations on Lateral Drift
β€’ Doubler Plate and Continuity Plate Design
β€’ Seismic Design for Concentric/Eccentrically Braced Steel Frames
β€’ Display of Reinforcing for Columns, Beams and 3D Shear Walls
β€’ Shored and Un-Shored Design for Composite Beams
[Image: homepage.png]
Mirror:
ETABS Version 9.7.3 FULL
Mirror:
[Image: comments.png]
Full CD
[-] The following 45 users Like jokerβ„’'s post:45 users Like jokerβ„’'s post
  β€’ aslam, Williams, tremonti, kowheng, Administrator , malc, yutt, pezhmankhan, Petrit, benny, engr1900, chigozie, jcbv, techno, bogdanobi, ascetic19, milvio, oanm2000, mowafi3m, zrilek, slowet, faros3000, rezart, nigema, Dell_Brett, cordoba123, struceng, TAFATNEB, marove, andersen3, waterman57, Diquan, cristi, w64bit, kamran, Safira, paulocs, engiman27, pm81, narendra, ChisTeam, ehsan_db, Galileo, zinousoft, drewpt
Threads: 57
08-13-2011, 03:17 AM (This post was last modified: 12-31-2011, 07:40 AM by kowheng.)
Stand Alone
Zip 97.53 MB(on site)
Full CD
Zip 309.42 MB
[-] The following 39 users Like kowheng's post:39 users Like kowheng's post
  β€’ araza023, yutt, Petrit, chenamoy, engr1900, chigozie, bogdanobi, Jackass, jokerβ„’, oanm2000, mahyarov, zrilek, ibg0203, orambo, slowet, rezart, Dell_Brett, cordoba123, kmmh76, mecheil.edwar, TAFATNEB, planeti_x, jareon, seriousboy, pedzaquino, waterman57, deltalead, ChisTeam, michaelsoe, ehsan_db, Galileo, zinousoft, gearplex606, ha893459, tluc, rendel_Β©, bigone, RANA WASEEM, techno
Threads: 274
Likes: 12,075 in 1,233 posts
08-13-2011, 03:52 AM
[Image: 44573600938483078435.jpg]
CSI Multi products license generator with the usage of ETABS 9.5 worked on it
[-] The following 19 users Like pezhmankhan's post:19 users Like pezhmankhan's post
  β€’ yutt, kowheng, malc, odiclas, engr1900, chigozie, bogdanobi, jokerβ„’, milvio, oanm2000, zrilek, ibg0203, mowafi3m, slowet, rezart, Dell_Brett, cordoba123, TAFATNEB, Galileo
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1668
#48
08-13-2011, 04:39 PM
PACKAGE LIST:
csimp.exe - Generator itself.
lsc.exe - used by generator. No need to start separately.
lsco.exe - used by generator. No need to start separately.
*.lic - generated license files. Naming is automatic from selected prduct, date and fingerprint. To use rename to "lservrc".
cgen.log - log file from generator. Can be deleted safely at any time.
newcodes - license log file from generator. Can be deleted safely at any time.
read.en.txt - this file.
USAGE:
1. Select product.
2. Enter yout localcode (fingerprint from echoid/wechoid).
Select license expire date (WARNING!!! 1 year max).
3. Generate your license file (it took few seconds - just wait confirmation for generator).
4. Rename generated file to "lservrc" and copy to corresponding program dir.
COPYLEFT:
sverox (RTKTEAM)
MED.link
[-] The following 23 users Like mowafi3m's post:23 users Like mowafi3m's post
  β€’ zrilek, slowet, jokerβ„’, rezart, nigema, tremonti, malc, blaze, engr1900, kowheng, dizz, Dell_Brett, oanm2000, planeti_x, jareon, pedzaquino, pm81, ehsan_db, gearplex606, ha893459, masafi_15, narendra, GMianG
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
#49
08-14-2011, 12:37 AM
Standalone installation for CSiXRevit 2009 and 2010
Download the Standalone installation for CSiXRevit 2009 and 2010
[-] The following 8 users Like jokerβ„’'s post:8 users Like jokerβ„’'s post
  β€’ blaze, mecheil.edwar, rezart, Dell_Brett, oanm2000, marove, struceng, w64bit
Away  jokerβ„’
User ID: 10925
Threads: 79
Given Likes: 2428
#50
11-10-2011, 09:45 AM
Install File
[-] The following 1 user Likes jokerβ„’'s post:1 user Likes jokerβ„’'s post
  β€’ jlrb
Pages (6): « Previous 1 2 3 4 5 6 Next »
