Civil Engineering Association Software Software Product Csi Products ETABS ETABS 2013 V13
ETABS 2013 V13
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
#41
11-11-2014, 07:04 AM
LavT License generator for ETABS 2013 13.2.0
attached
.rar   licgen CSI.ETABS.2013.v13.2.0.1130.x86.x64.rar (Size: 1.06 MB / Downloads: 756)
[-] The following 38 users Like bigone's post:38 users Like bigone's post
  • amindoxiti, joker™, bridgeengineer, jcbv, simanta, melekeen, pontiac, Jackass, malee, dl4all, oanm2000, techno, raja, learner20, marove, zrilek, albani, Andrew seah, cace-01, blaze, Dell_Brett, l_namali, promo8, jjmtz, jamesmakeez, ebzr, abilio, tospol, ionescu.silviu, rendel_©, kourepai, ibg0203, Quantumm, giga, Rainbow, andyspak2, shark, oreslaw
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,986 in 4,091 posts
Given Likes: 612
#42
11-21-2014, 07:40 PM
ETABS 13.2.1 installation (use the same license generator as previous version)
[-] The following 38 users Like BennyP's post:38 users Like BennyP's post
  • ebzr, Williams, red_pool61, zrilek, dl4all, MOSS2000, rezart, oanm2000, aslam, raja, simanta, pezhmankhan, kirankumarklk, learner20, bigone, abilio, tomtumx, jcbv, PinkPant, KhaLed-S.E, Dell_Brett, Andrew seah, cordoba123, Jackass, milvio, seriousboy, malc, Diquan, ionescu.silviu, rendel_©, visu, Erparesh, giga, amiboyz, promo8, slowet, Rami11, oreslaw
 betinnn
Mexico
User ID: 34
Threads: 8
Likes: 219 in 13 posts
Given Likes: 93
#43
12-04-2014, 01:14 AM (This post was last modified: 12-04-2014, 01:34 AM by Dell_Brett.)
ETABS 2013 v13.2.0
[img][Image: 44833505065346872913_thumb.jpg][/img]
Computers and Structures, Inc. (CSI), leader in software tools for structural and earthquake engineering, has released an update to CSI ETABS 13, is a civil engineering program that design and analyse steel and concrete structures using finite element method.
ETABS 2013 provides an unequaled suite of tools for structural engineers designing buildings, whether they are working on one-story industrial structures or the tallest commercial high-rises. Immensely capable, yet easy-to-use, has been the hallmark of ETABS since its introduction decades ago, and this latest release continues that tradition by providing engineers with the technologically-advanced, yet intuitive, software they require to be their most productive.
Significant enhancements included in ETABS 2013 version 13.2.0:
- The Auto-Relabel All option that was available in ETABS v9 has been restored.
- Russian material property and section property libraries have been added.
- ASCE 41-13 guidelines for performance-based design have been implemented for frame hinge definitions, performance-point calculations, and the behavior and acceptance criteria for panel-zones and BRBs (buckling-restrained braces).
- Masonry is now defined as a separate material rather than a type of concrete material.
- Multiple named mass-source definitions can now be created and used for different load cases.
- The Singapore National Annex has been added as an option to the Euroquote 8-2004 response spectrum function.
- Notional load patterns can now be based on snow loads as well as other gravity loads.
- User control is now provided for the handling of self-weight in the end offset portions of beam members.
- The speed of analysis has been increased for most load cases.
- The iteration strategy for nonlinear static and nonlinear direct-integration time-history load cases has been made more adaptive to typically improve convergence behavior and to reduce the time of analysis.
- The line-search algorithm is now available for nonlinear static analysis.
- Steel frame design for the Indian IS 800:2007 quote now implements the changes in Amendment Number 1.
- The display of design input parameters for steel frame design overwrites has been enhanced.
- Canadian design quotes (i.e., CSA A23.3-04 and CSA S16-09) now include snow loads in the default design combinations.
- Multiple enhancements have been made for composite beam design affecting the control of the design process, the look and functionality of the interactive design form, the format and content of the output, and other improvements.
- Shear wall design per the Indian IS 456:2000 quote now allows separate control in the major and minor directions for enforcing the minimum eccentricity due to slenderness.
- Several database tables have been added or have had their content expanded, including the listing of object unique names where applicable.
- Table set definitions are now saved in the text model file.
[-] The following 10 users Like betinnn's post:10 users Like betinnn's post
  • TAFATNEB, jcbv, slowet, PinkPant, ssobhan, seriousboy, bridgeengineer, oanm2000, giga, learner20
Likes: 9,411 in 1,161 posts
#44
12-05-2014, 11:00 AM
CSI ETABS 2013 13.2.1 November 2014| 733 MB
[Image: 83953574717394579370.jpg]
ETABS 2013 13.2.1 Enhancements
Significant enhancements included in ETABS 2013 version 13.2.0 and version 13.2.1:
- The Singapore National Annex has been added as an option to the Eurocode 8-2004 response spectrum function.
- Steel frame design for the Indian IS 800:2007 code now implements the changes in Amendment Number 1.
- Canadian design codes (i.e., CSA A23.3-04 and CSA S16-09) now include snow loads in the default design combinations.
- Shear wall design per the Indian IS 456:2000 code now allows separate control in the major and minor directions for enforcing the minimum eccentricity due to slenderness.
About Computers and Structures, Inc
Founded in 1975, Computers and Structures, Inc. (CSI) is recognized globally as the pioneering leader in software tools for structural and earthquake engineering. Software from CSI is used by thousands of engineering firms in over 160 countries for the design of major projects, including the Taipei 101 Tower in Taiwan, One World Trade Center in New York, the 2008 Olympics Birds Nest Stadium in Beijing and the cable-stayed Centenario Bridge over the Panama Canal. CSI's software is backed by more than three decades of research and development, making it the trusted choice of sophisticated design professionals everywhere!
[-] The following 14 users Like TAFATNEB's post:14 users Like TAFATNEB's post
  • oanm2000, MOSS2000, PinkPant, bridgeengineer, learner20, bigone, joker™, cace-01, Mohammad6299, knrsa, slowet, amareen2000, blaze, andyspak2
 knrsa
Semi Senior Member
Banned
User ID: 82
Threads: 42
Likes: 465 in 52 posts
Given Likes: 2171
#45
12-08-2014, 06:41 AM (This post was last modified: 12-09-2014, 10:53 AM by BennyP.)
CSI ETABS 13.2.1
Mirror of post # 29
[-] The following 15 users Like knrsa's post:15 users Like knrsa's post
  • learner20, blaze, TAFATNEB, bigone, PinkPant, cace-01, Williams, MOSS2000, oanm2000, tooraj41, stigtg, andyspak2, Andrew seah, jcbv, Quantumm
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
#46
12-24-2014, 04:13 AM
ETABS 2013 v13.2.2
[-] The following 20 users Like aslam's post:20 users Like aslam's post
  • learner20, bigone, raja, joker™, Jackass, PinkPant, zrilek, Andrew seah, rezart, oanm2000, MOSS2000, milvio, Dell_Brett, simanta, taifur, malc, Williams, rendel_©, pedronick, faros3000
 BennyP
User ID: 842
Threads: 1,128
Given Likes: 612
#47
12-30-2014, 05:35 AM
Don't forget. You can use Date Fake and this is the maximum you can reach.
[Image: 11763837577538687450.gif]
[-] The following 13 users Like BennyP's post:13 users Like BennyP's post
  • malc, zrilek, thanzawtun, Dell_Brett, learner20, Williams, rezart, PinkPant, Jackass, bigone, abdulazizk, faros3000, Arigato
 zrilek
Semi Senior Member
User ID: 3860
Threads: 12
Likes: 337 in 59 posts
Given Likes: 22025
#48
12-30-2014, 10:33 AM (This post was last modified: 12-30-2014, 10:36 AM by zrilek.)
Med only for v13.2.2. Not tested.
All credits go to LAV Team.
Password as usual.
[-] The following 9 users Like zrilek's post:9 users Like zrilek's post
  • PinkPant, Jackass, simanta, melekeen, bigone, learner20, techno, jcbv, oreslaw
 dl4all
User ID: 41680
Threads: 15
Likes: 210 in 26 posts
Given Likes: 137
#49
12-30-2014, 02:10 PM (This post was last modified: 12-30-2014, 02:43 PM by Dell_Brett.)
Note:
- The medicine of the post above is the same as posted previously!
[-] The following 1 user Likes dl4all's post:1 user Likes dl4all's post
  • MOSS2000
#50
01-09-2015, 03:42 PM
CSI ETABS 2013 version 13.2.2
[Image: 74572896014280473968.jpeg]
Significant enhancements included in ETABS 2013 v13.2.0, v13.2.1, and v13.2.2:
[-] The following 12 users Like TAFATNEB's post:12 users Like TAFATNEB's post
  • blaze, oanm2000, techno, PinkPant, slowet, mgdario, bridgeengineer, Rami11, orio777, faxel, pedzaquino, bigone
Pages (5): « Previous 1 2 3 4 5
