Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] Scitation and Sciencedirect/Elsevier JOURNAL
[Request] Scitation and Sciencedirect/Elsevier JOURNAL
 xnr09
User ID: 9060
Threads: 21
Likes: 1,120 in 126 posts
Given Likes: 74
#481
04-23-2016, 06:05 PM
here it is
cheers
xnr09
[-] The following 5 users Like xnr09's post:5 users Like xnr09's post
  • zrilek, yakwetu, f_slikken, PinkPant, ska51
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
#482
04-24-2016, 04:24 PM
Here get it;
[-] The following 5 users Like ssobhan's post:5 users Like ssobhan's post
  • zrilek, f_slikken, Dell_Brett, PinkPant, ska51
 mary
User ID: 31558
Threads: 37
Likes: 341 in 77 posts
Given Likes: 692
#483
06-21-2016, 05:41 PM
Dear all,
Requesting for two Papers listed below
  • Article/eBook Full Name:
  • Static and seismic performance of a friction piled raft combined with grid-form deep mixing walls in soft ground
  • Author(s):
  • Kiyoshi Yamashita, , Junji Hamada, Tomohiro Tanikawa
  • Edition:
  • Soils and Foundations Available online 12 May 2016
  • Publish Date:
  • 2016
  • Published By:
  • Sciencedirect
  • Related Links:
  • Code:
 mary
User ID: 31558
Threads: 37
Given Likes: 692
#484
09-26-2016, 06:21 PM (This post was last modified: 09-26-2016, 06:25 PM by mary.)
  • Numerical Analysis of Small-Scale Model Pile in Unsaturated Clayey Soil
  • Author(s):
  • Shao-Hung Chung Shu-Rong Yang
  • Related Links:
  • Code:
  • Numerical Analysis of Low Strain Testing of 3-D Axial Symmetry Viscoelastic Pile–Soil Model
  • Author(s):
  • Related Links:
  • Code:
[-] The following 1 user Likes mary's post:1 user Likes mary's post
  • freequo
 xnr09
User ID: 9060
Threads: 21
Given Likes: 74
#485
09-27-2016, 06:54 AM
Hi
Here are the papers:
- Numerical Analysis of Small-Scale Model Pile in Unsaturated Clayey Soil
- Numerical Analysis of Low Strain Testing of 3-D Axial Symmetry Viscoelastic Pile–Soil Model
Cheers
xnr09
[-] The following 8 users Like xnr09's post:8 users Like xnr09's post
  • ska51, PinkPant, cace-01, ssobhan, oanm2000, Dell_Brett, bridgeengineer, zrilek
 abouferass88
Yemen
User ID: 11928
Threads: 37
Likes: 598 in 75 posts
Given Likes: 237
#486
01-06-2017, 07:57 PM
Request: Use of applied element method for structural analysis
  • Author(s): Aliakbar Shakeri,  Khosrow BargiPublished By: Springer International Publishing AG. Published Year: July 2015DOI: 10.1007/s12205-015-0625-4Quality: UnspecifiedRelated Link:
 tomtumx
Semi Senior Member
User ID: 2851
Threads: 18
Likes: 725 in 124 posts
Given Likes: 772
#487
01-07-2017, 08:54 AM
@abouferass88  Here it is:
[-] The following 7 users Like tomtumx's post:7 users Like tomtumx's post
  • Dell_Brett, abouferass88, zrilek, malc, cace-01, lisine, oanm2000
 atram
User ID: 34120
Threads: 29
Likes: 236 in 48 posts
Given Likes: 436
#488
02-14-2017, 12:26 PM
Dear friends,
if somebody can upload, I would be very grateful:
  • On the basic phenomenon of soil-structure interaction on the free vibration response of beams: Application to railway bridges
  • Author(s):
  • A. Doménech, M.D. Martínez-Rodrigo, A. Romero, P. Galvín
  • Edition:
  • Engineering Structures, Volume 125, 15 October 2016, Pages 254-265
  • Related Links:
  • Code:
 MarcinX
User ID: 37979
Threads: 7
Likes: 31 in 6 posts
Given Likes: 71
#489
02-14-2017, 01:13 PM
Hej atram,
Here You can find the paper:
Author(s): A. Doménech, M.D. Martínez-Rodrigo, A. Romero, P. Galvín
[-] The following 5 users Like MarcinX's post:5 users Like MarcinX's post
  • zrilek, atram, ska51, oanm2000, Dell_Brett
 realbabilu
User ID: 4534
Threads: 7
Likes: 130 in 23 posts
Given Likes: 55
#490
11-02-2020, 07:40 AM (This post was last modified: 11-02-2020, 09:03 AM by lisine.)
Structural behavior of large-scale triangular and trapezoidal threaded steel tie rods in assembly using finite element analysis
  • Author(s): Wei Duan , Suraj Joshi
  • DOI: ttps://doi.org/10.1016/j.engfailanal.2013.07.024
  • Quality: Original Preprint
  • Abstract: Pre-stressed steel tie rods are used extensively as load carrying components in structures
    like suspension bridges, steering systems in automotive vehicles, wings and fuselage of aircrafts, spokes of Ferris wheels, etc. The governing variables for the bearing strength of a
    large-scale steel tie rod (of diameter usually larger than 60 mm) include the mechanical
    strength of the tie rod body, geometric configuration of the thread teeth and the number
    of turns of thread engagement. The optimal number of turns of threaded connections of
    large scale steel tie rods has been predicted by full scale rupture experiments and reported
    previously by the authors. This paper builds up further on that work and investigates the
    structural behavior of the two types of threaded connections of steel tie rods, viz. (i) the
    triangle threaded connection, and (ii) the trapezoidal threaded connection, using finite element analysis in ANSYS. The axial displacement, equivalent stress distribution, interfacial
    contact pressure and sliding distance on the engaged thread teeth under different axial
    loads are presented and analyzed. The numerical simulations verify and expound the
    results of full-scale tensile rupture experiments. The concordant comparison between
    experimental measurements and finite element analysis provides working guidelines
    and support for the design and fabrication of steel tie rods in practical operations.
[-] The following 1 user Likes realbabilu's post:1 user Likes realbabilu's post
  • civilfafa
Pages (50): « Previous 1 … 41 42 43 44 45 46 47 48 49 50 Next »
