Civil Engineering Association Software Software Product Csi Products ETABS ETABS 2013 V13
ETABS 2013 V13
 zipatton
User ID: 1594
Threads: 2
Likes: 251 in 66 posts
Given Likes: 123
#31
04-22-2014, 04:45 AM
Hi Gentlemen,
by using Run-as-Date software, it works permanently, without limitations of days.
it works for me on Windows7.
Zippat
  β€’
 kirankumarklk
User ID: 29935
Threads: 68
Likes: 960 in 135 posts
Given Likes: 280
#32
04-22-2014, 06:58 AM
Dear zipatton,
Please do let us know how to use Run-as-Date software for ETABS 2013.1.4
  β€’
 zipatton
User ID: 1594
Threads: 2
Given Likes: 123
#33
04-22-2014, 08:40 AM
Hi,
Just run RunAsDate and give the details required (especially the dates - I use today's date). A new shortcut icon for the target program will appear on your desktop. You have to use this modified icon everytime you want to use the target program.
Best regards
Zippat
[-] The following 10 users Like zipatton's post:10 users Like zipatton's post
  β€’ concreteok, malee, Andrew seah, zrilek, caifan, ting tsai huang, araza023, jaks, AndresPeper, gianniorlati
 knrsa
Semi Senior Member
Banned
User ID: 82
Threads: 33
Likes: 465 in 52 posts
Given Likes: 2171
#34
04-27-2014, 08:29 AM (This post was last modified: 04-27-2014, 09:12 AM by BennyP.)
Etabs 2013 V 13.1.3 64 Bit
πŸ‘‰ CLICK HERE πŸ‘ˆ
[-] The following 3 users Like knrsa's post:3 users Like knrsa's post
  β€’ Dell_Brett, civilgr, bigone
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Likes: 7,707 in 755 posts
Given Likes: 2168
#35
06-16-2014, 04:18 AM (This post was last modified: 06-16-2014, 07:13 AM by Dell_Brett.)
ETABS 13.1.5
ETABS 2013 13.1.5 Enhancements
Significant enhancements include:
The iteration algorithm for nonlinear direct-integration time-history analysis has been enhanced to improve the rate of convergence and to reduce the time of analysis for certain models.
32 Bit
64 Bit
[-] The following 24 users Like aslam's post:24 users Like aslam's post
  β€’ Dell_Brett, learner20, bigone, malc, zrilek, rezart, techno, Jackass, Rodmo376, jcbv, dizz, dl4all, MOSS2000, raja, ssobhan, milvio, simanta, LiviuM, golpesar, sia1, MegaMind, rendel_Β©, warbeast, nickycruz
 ripach
Semi Senior Member
Spain
User ID: 5230
Threads: 6
Likes: 259 in 49 posts
Given Likes: 78
#36
06-17-2014, 11:17 AM
CSI ETABS 2013 v13.1.5 x86+x64
Mirror here:
[-] The following 13 users Like ripach's post:13 users Like ripach's post
  β€’ jcbv, blaze, bigone, oanm2000, TAFATNEB, mowafi3m, Dell_Brett, PinkPant, Mohammad6299, cristi, lesgiu, oreslaw, learner20
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1668
#37
06-27-2014, 07:48 PM
ETABS 2013 v13.1.5 x64
License Generator
[-] The following 38 users Like mowafi3m's post:38 users Like mowafi3m's post
  β€’ malc, Dell_Brett, jcbv, Munykong, ranger, Jackass, PinkPant, zrilek, MOSS2000, oanm2000, bridgeengineer, Mohammad6299, ykhackhack, bigone, lesgiu, nickycruz, xdesi, faros3000, Kainco, l_namali, javoxo, jjmtz, oreslaw, deltalead, sodapas, KhaLed-S.E, hamzeaziz, SCREAM7890, RyanRS, HellboyRBJ, gacella, ibg0203, blaze, Andrew seah, rendel_Β©, giga, learner20, shark
 Jackass
Semi Senior Member
Banned
Bolivia
User ID: 29460
Threads: 24
Likes: 1,138 in 115 posts
Given Likes: 7399
#38
11-04-2014, 03:00 PM (This post was last modified: 11-04-2014, 03:04 PM by Jackass.)
Hi
News Etabs 2013 13.2.0
Only in Civilea
368 MB
[-] The following 13 users Like Jackass's post:13 users Like Jackass's post
  β€’ blaze, aslam, Diquan, learner20, agelos100, jokerβ„’, Mohammad6299, raja, Williams, bigone, slowet, giga, shark
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
#39
11-04-2014, 03:39 PM
Etabs 2013 13.2.0
No limits to creativity
[-] The following 26 users Like jokerβ„’'s post:26 users Like jokerβ„’'s post
  β€’ Mohammad6299, raja, rezart, aslam, learner20, red_pool61, seriousboy, zrilek, oanm2000, tooraj41, Dell_Brett, Andrew seah, malc, Williams, PinkPant, cace-01, MOSS2000, cristi, bigone, jcbv, melekeen, promo8, jjmtz, jamesmakeez, Quantumm, giga
 aslam
Abu Dhabi
User ID: 64
Threads: 284
Given Likes: 2168
#40
11-05-2014, 04:05 AM
ETABS 2013 13.2.0 Enhancements
Significant enhancements included in ETABS 2013 v13.2.0:
The Auto-Relabel All option that was available in ETABS v9 has been restored.
Russian material property and section property libraries have been added.
ASCE 41-13 guidelines for performance-based design have been implemented for frame hinge definitions, performance-point calculations, and the behavior and acceptance criteria for panel-zones and BRBs (buckling-restrained braces).
Masonry is now defined as a separate material rather than a type of concrete material.
Multiple named mass-source definitions can now be created and used for different load cases.
The Singapore National Annex has been added as an option to the Eurocode 8-2004 response spectrum function.
Notional load patterns can now be based on snow loads as well as other gravity loads.
User control is now provided for the handling of self-weight in the end offset portions of beam members.
The speed of analysis has been increased for most load cases.
The iteration strategy for nonlinear static and nonlinear direct-integration time-history load cases has been made more adaptive to typically improve convergence behavior and to reduce the time of analysis.
The line-search algorithm is now available for nonlinear static analysis.
Steel frame design for the Indian IS 800:2007 code now implements the changes in Amendment Number 1.
The display of design input parameters for steel frame design overwrites has been enhanced.
Canadian design codes (i.e., CSA A23.3-04 and CSA S16-09) now include snow loads in the default design combinations.
Multiple enhancements have been made for composite beam design affecting the control of the design process, the look and functionality of the interactive design form, the format and content of the output, and other improvements.
Shear wall design per the Indian IS 456:2000 code now allows separate control in the major and minor directions for enforcing the minimum eccentricity due to slenderness.
Several database tables have been added or have had their content expanded, including the listing of object unique names where applicable.
Table set definitions are now saved in the text model file.
[-] The following 19 users Like aslam's post:19 users Like aslam's post
  β€’ malc, Williams, learner20, Dell_Brett, dl4all, raja, PinkPant, jokerβ„’, oanm2000, cace-01, ASEC, gacella, MOSS2000, cristi, bigone, jcbv, promo8, absolutezayar, shark
Pages (5): « Previous 1 2 3 4 5 Next »
